Noise in rear end when turning at low speed
Postby 2 H.B. [OP] » December 29th 2010, 1:50am
I've got a 2000 AWD Safari, about a month ago the rear end (limited slip)started making noise when turning at slow speed. Like rubbing or grinding. If you are going maybe 10 or 15 MPH the problem disappears.
I stopped in at a dealer and they said to replace the fluid with their special Grape scented synthetic GM fluid, and if that doesn't work the first time, do it again. They also said $35 per Quart. I went to the Auto parts store and bought 2 Quarts of Valvoline full synthetic 75/90 for $10 a quart, drove the van for a few hundred miles, no significant improvement. Went to another dealer, and got the same recommendation, in fact they said sometimes it takes 3 times before it works.
They say they are familiar with this problem.....
Anyone here know about this?
2 H.B.
Years of Membership: 2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years2 H.B. has been a member for 8 full years
Alias (AKA): Mattstro2.0
Extra Info: AWD SLE 247000M
  • Rear End Oil
    by astronot » March 16th 2017, 2:57pm in Rear-End
    Last post by Lumpy View the latest post
    March 19th 2017, 3:05pm
  • Knocking from rear end when accelerating
    by cesarch2 » February 7th 2017, 12:57am in Rear-End
    Last post by toolguy73 View the latest post
    February 7th 2017, 1:47am
    85
    May 25th 2017, 2:28am
Re: Noise in rear end when turning at low speed
Postby chevymaher » December 29th 2010, 2:06am
I new to Astro/safari posi but I have dealt with the rest of the rear wheel drive GM line with posi.When you add fluid there a posi additive you put in as well or it will slip to much and burn clutches.ASSUMEing all else being same.I am sure there is supposed to be additive tho.For the noise I would check the bearings for wear.If I not in the know about something somebody be along soon with that info
Topics: 83
Year: 1994
Postby 2 H.B. [OP] » December 29th 2010, 2:50am
Thanks for the post. You're right about the additive, I forgot to mention it, but it's in there.
2 H.B.
Postby gtkane » December 29th 2010, 3:15am
What dealers are telling you to change the fluid repeatedly? We could not get away with that up here!
Sometimes, the clutches will get dry because of centrifugal(sp) force, esp after driving for extended periods on the highway, and will make noise.
The no-dollar fix is to find a big empty parking lot, and drive in tight circles(steering in full lock) to the left and then to the right. About a dozen circles each way. This will work the gear oil into the clutches.
It may not fix your problem, but the price is right!
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby Rags » December 29th 2010, 3:15am
I also had this problem when I clicked 30,000 miles. It was random at first, and then became near regular at low speeds. Mine was more of a thud like it was shifting gears around the 10-15 mph mark. Once accelerated over 15 mph, van ran smooth as butter with absolutely no noise.
Again, my noise was a deep thud and didn't hear any grinding. Sounded more like a broken down CV joint on a front wheel drive car.
I took the van to the local Chevrolet dealership to get their take. They concluded that the transfer case between the tranny & rear differential needed the oil flushed out. And that oil was a high cost item along with the procedure. I believe they flushed it 2X. I don't recall them saying it was the "Grape" scented type.
The outcome was that iIT DID fix my noise issue, although I had serious doubts the flushes would fix it. I paid around around $150 for some type of deductible with warranty work. Now sitting around 66K, I've hear the thudding noise once, and that was last week during fluctuating temperature drops. If the noise starts to become regular, I'll probably suck up the costs and let them do it--as much as I don't like anyone else working on my van.
You stated you heard grinding, so your issue may not be the same as mine. Does the dealership know that? Maybe they can have their mechanic to test ride your van to suggest what the problem may be and isolate the transfer case or differential as the problem area.
I may still have my receipt that details the work they did if you're interested. It should the type off oil used, labor fees, etc. Let me know.
Rags
Years of Membership: Rags has been a member for 6 full yearsRags has been a member for 6 full yearsRags has been a member for 6 full yearsRags has been a member for 6 full yearsRags has been a member for 6 full yearsRags has been a member for 6 full years
Extra Info: LT AWD
Postby 2 H.B. [OP] » December 29th 2010, 4:15am
I'm in Connecticut, two different dealers said the same thing. GTKane, what you said makes sense. You drain it and put 3.6 pints or whatever including the additive, what's going to happen to that fluid? Does it go bad, or get contaminated?
I figured it's got to get in to the clutch plates. I didn't know that they can get dry, but that makes sense. It drags and moans pretty good when you turn the wheel. I've tried driving faster on curvy roads, hoping the lube will get in there, but I've been trying not to push my luck- lots of three point turns when parking.
Rags-The fluid for the transfer case is Auto Trak II, and it solves a lot of problems. Its blue in color but not scented that I've noticed. It's about $10 a quart. The Grape thing is just for the rear end. Mine doesn't thud, it almost sounds and feels like the tire is rubbing on something as you turn.
Maybe I'll spring for the GM fluids and then try the parking lot maneuver GTKane recommended.
Thanks for the posts!
2 H.B.
Postby Phantom » December 29th 2010, 4:35am
Does anyone have a part number for the grape scented additive? I would like to look into this more , years ago the additive was a deep red color and made from whale oil , but I have heard that they don't use that anymore , i 'm curious what the new additive is , is it synthetic or what?
Phantom
Firing on 7 Cylinders (L4)
Postby Philly758 » December 29th 2010, 4:37am
2HB, where in CT are you from? I'm from CT and have an AWD safari myself.
:auto-gmcredsmiley:
2000 GMC Safari SLE, AWD - 150k+
- Lifted with 22-687 leaf springs and 2" blocks
- Cooper AT3 30x9.5's on Cragar Soft 8's
- Hellwig Rear Sway Bar
- TruCool Trans Cooler
- Corvette Servo
- Moog steering
- Bilstein HD's
- 3.73 G80
Philly758
Years of Membership: Philly758 has been a member for 6 full yearsPhilly758 has been a member for 6 full yearsPhilly758 has been a member for 6 full yearsPhilly758 has been a member for 6 full yearsPhilly758 has been a member for 6 full yearsPhilly758 has been a member for 6 full years
Topics: 36
Extra Info: SLE AWD
Postby 2 H.B. [OP] » December 29th 2010, 4:57am
The Grape stuff is Synthetic Gear Oil. The additive is unscented as far as I know. When I get some I can post the #'s
Philly- I'm in Hartford. I see you are in Bridgeport. I used to drive through there all the time, but not so much these days.
2 H.B.
Postby Leeann_93Leeann_93 is online! » December 31st 2010, 4:32am
2 H.B. wrote:The Grape stuff is Synthetic Gear Oil. The additive is unscented as far as I know. When I get some I can post the #'s
And I'm from West Simsbury. I only get back up there about once a year, though.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby doyoulikeithere » December 31st 2010, 7:28am
a long time ago, mine made a kinda grinding noise if I made a tight uturn on dry pave.
I chalked it up to the G80 locking, and one wheel dragging a bit on the pave, shuddering a bit.
Isnt that what G80's supposed to do , under 100 rpms? (10-15MPH?)
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full years
Topics: 26
Images: 11
Postby 2 H.B. [OP] » January 4th 2011, 2:47am
Thanks for the replies, I took the weekend off! West Simsbury...is that where Tulmeadow Farms is? That's a pretty nice area, still a lot of woods and wildlife.
As for the van, it is supposed to push both wheels, that is true, but it never grunted and groaned before, put it that way. It sounds really nasty. The description of the clutch plates drying out seems to fit, but driving in tight circles hasn't fixed it, unfortunately.
I put in the GM synthetic kool-aid and additive, and I've put about 300 miles on it since.
I almost want to change the fluid to some super low viscosity oil- no limited slip additive- just to get something to penetrate and lube things up. I think I'd rather have it slipping, and then go back to the recommended stuff to fix that.
On the other hand,Is there some way to manually get at the plates with the cover off, without taking all the gears out?
2 H.B.
Postby Leeann_93Leeann_93 is online! » January 4th 2011, 3:25am
2 H.B. wrote:Thanks for the replies, I took the weekend off! West Simsbury...is that where Tulmeadow Farms is? That's a pretty nice area, still a lot of woods and wildlife.
Yup. I grew up playing in their pastures...winter and summer. They make THE BEST ice cream around - fruit is all from their orchard, cream from their cows....it's awesome.
For a pic of my Bravada's limited slip diff, 3.73 gears, with the cover off, if that helps:
Image Image
Topics: 27
Year: 2002
Postby chevymaher » January 4th 2011, 3:29am
.Leeann bravada rear fit the van?
Topics: 83
Year: 1994
Postby Leeann_93Leeann_93 is online! » January 4th 2011, 3:39am
The insides interchange, but the offset is different. The Astro's offset is one-of-a-kind.
My Astro does not have a G80 but is also 3.73. I haven't pulled the cover to look at that one yet.
Image Image
Topics: 27
Year: 2002
Postby chevymaher » January 4th 2011, 3:41am
Thank you. That works for me the bravada easier to find posi in.
Topics: 83
Year: 1994
Postby 2 H.B. [OP] » January 4th 2011, 3:58am
Yeah, their ice cream is really great!
That's just like the inside of mine, I just don't know what to do with it..can I get the fluid between the plates somehow?
2 H.B.
Postby Leeann_93Leeann_93 is online! » January 4th 2011, 4:15am
I didn't disassemble it any further since I didn't need to, so I'm not sure about getting fluids into the clutches directly. If no one else answers in the meantime, I'll find the applicable pages in the service manual when I can get to them.
Image Image
Topics: 27
Year: 2002
Postby 2 H.B. [OP] » January 4th 2011, 4:29am
Thanks so much, I guess you're talking about a GM manual. The Haynes doesn't really get into it.
I took a walk out in those fields with my wife about a month ago, and I noticed 2 or 3 Astros or Safaris here and there, I forgot about that until just now, but I remember thinking they have good taste in vans at Tulmeadow Farms.
2 H.B.
Postby 2 H.B. [OP] » January 21st 2011, 3:23am
Well, for a while it wasn't getting any worse, but I'm not sure that's true anymore. It just seems to be locked now at slow speeds, so it's hopping and jerking around, and I'm sure it puts a lot of stress on the rest of the drivetrain.
Is there a way to just disable the clutch mechanism that anyone knows of? It still works fine as long as I'm over 15 MPH.
Thanks
2 H.B.
Return to Rear-End
It is currently May 25th 2017, 2:28am
Rear-End Forum
Moderator: 1297chevastro
Funaticus
in Rear-End
Date: Apr 04 '17
Time: 4:36am
gordo999
in Rear-End
Comments: 21
Date: Apr 04 '17
Time: 2:53am
astroconvert
in Rear-End
Date: Apr 01 '17
Time: 10:18pm
Attached by: 97cargocrawler
97cargocrawler
in Rear-End
Date: Mar 16 '17
Time: 4:10pm
97cargocrawler
in Rear-End
Comments: 20
Date: Mar 15 '17
Time: 11:18pm
