Just Swap My First Rearend
Postby grandamle91 [OP] » October 25th 2009, 3:34am
Got Sick Of The Vibrating And Noise, And It would Of Been Cheap And Faster To Swap Rears. Rides Nice Now :layrubber:
Now I Got To Try And Find Out What The Old Gears Were Because The Gear Box Sticker Is Gone, Can't Seem To Find It On The Rear End, Any Other Way To Figure That Out
It Only Took 4 Hours (with A 30min Lunch) To Pull Both And Pull The New One In
Donor Pulled
Donor 3.42 Gears
Donor
Old One
Donor Bolted In
Side shot
-Evan
"MONSTRO" 97 Chevy Astro AWD 6.0 LS2 232k Lifted 20in GT4 G80 20s
98 Pontiac Grand Prix GTP 3.8 E-85 234k Lowered
http://www.astrosafari.com/viewtopic.php?f=13&t=17180
grandamle91
Firing on 8 Cylinders (L1)
Years of Membership: grandamle91 has been a member for 5 full yearsgrandamle91 has been a member for 5 full yearsgrandamle91 has been a member for 5 full yearsgrandamle91 has been a member for 5 full yearsgrandamle91 has been a member for 5 full years
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Extra Info: LT 6.0 AWD E-85
  • Need a RearEnd OverHaul
    by My1988Astro » November 26th 2012, 6:13am in Rear-End
    Last post by chevymaherchevymaher is online! View the latest post
    November 27th 2012, 2:43am
  • 8.8 Explorer rearend measurements
    by HotrodDaddy44 » January 30th 2013, 3:04am in Rear-End
    Last post by HotrodDaddy44 View the latest post
    January 30th 2013, 11:38pm
    May 18th 2013, 9:11am
Re: Just Swap My First Rearend
Postby Mr_Bowtie » October 25th 2009, 4:00am
Good work! Swapping rearends on these Vans looks pretty straight forward. Good pics too! 8-)
'96 Astro AWD 206K miles!
31" tires LIFTED 4" total with tires! Pushbar, KC lights, CB radio, Tach....REDNECK!
'01 Crown Vic P71(not stock) 14.7@94mph
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full years
Topics: 69
Images: 8
Year: 1996
Extra Info: Lifted AWD
Postby grandamle91 [OP] » October 25th 2009, 4:12am
Ya the only problem i have were tring to get the bolts that run though the leaf off, they should of put a geaseable bolt in there
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby Mr_Bowtie » October 25th 2009, 4:21am
Its just nice seeing a vehicle were you don't have to drop the exhaust and gas tank to even get to the rearend.
You still trying to figure out the rearend gear ratio?
If so you can jack the wheels off the ground and spin the wheels(helps to mark the tire) once around in neutral. Count how many times around the driveshaft goes. So, 3 and almost a half turn would be 3.42 gears.
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Topics: 69
Images: 8
Year: 1996
Postby grandamle91 [OP] » October 25th 2009, 4:49am
Thank i'll give it a try when the sun comes back
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby Jasen » October 25th 2009, 4:49am
There should be some numbers cast into the pumpkin that will lead you in the right direction. Don't know which ones you need but a dealers parts guy should know.
Or you can pop the cover and count teeph
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Postby Infidel » October 25th 2009, 2:15pm
If you have any doubt, you can get the numbers off of the ring gear:
Why be difficult when with a bit of effort you can be impossible?
1998 Chevy Astro - VIN W - 223K miles original engine and transmission
Infidel
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Infidel has been a member for 3 full yearsInfidel has been a member for 3 full yearsInfidel has been a member for 3 full years
Alias (AKA): Infidel
Extra Info: Stock but workin
Postby Big_kid » October 25th 2009, 2:26pm
Mr_Bowtie beat me to it. I did it the other way though, I turned the driveshaft yoke and counted the turns until the wheel went around one time. Either way, same principle.
BTW- I figured the van had enough problems to warrant parting it out. They don't always show in pics.
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
Postby grandamle91 [OP] » October 25th 2009, 4:23pm
Sounds like the easy way would be to pop off the diff cover, the rear end is going to the scrap yard, unless someone needs a houseing
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby Mr_Bowtie » October 25th 2009, 4:25pm
Probably a good idea to give it some fresh fluid anyways.
I'm gonna guess it has 3.42 gears. :D
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Topics: 69
Images: 8
Year: 1996
Postby grandamle91 [OP] » October 25th 2009, 4:45pm
i know the donor has 3.42 gears, atleast thats what the sticker said, mine on the other hand has had the interior replaced, i know i ketp my old glove box for that reason, but trying to find somthing in my garages
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby toddb » October 25th 2009, 4:57pm
grandamle91 wrote: but trying to find somthing in my garages
That's too funny. I know how you feel. After twenty years in the same house (actually closer to 35 being as bought my parents home) and many many projects of all types and flavours. Add to that of being somewhat of a pack rat and messy and finishing alot of projects with 1 beer too many. My next project is to clean up my mess. LOL
BTW good job on the swap. Did you figure out what the old ratio was yet?
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 4 full yearstoddb has been a member for 4 full yearstoddb has been a member for 4 full yearstoddb has been a member for 4 full years
Postby grandamle91 [OP] » October 25th 2009, 5:40pm
Ya i'm a big pack rat, i took the diff cover off and only thing i could find was: 11:41-7.58, but i did push it round the yard and the yoke spun 3 1/2 time to one wheel
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby Jasen » October 25th 2009, 5:47pm
i did push it round the yard and the yoke spun 3 1/2 time to one wheel[/quote]
I'da bought the beer to have seen that :lol:
Topics: 249
Images: 68
Year: 1997
Postby rev_les » October 25th 2009, 7:01pm
Amen on that!
Count the teeth on the ring gear, and the pinion, divide the teeth on the ring gear, by the teeth on the pinion, there's your ratio.
NRA Lifetime Member
2'nd amendment supporter
'99 Astro, 296K 4.3 "W" 3.73's RIP
91 Sable wgn, 43K
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full yearsrev_les has been a member for 4 full years
Topics: 37
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Mr_Bowtie » October 25th 2009, 7:43pm
+1 on that! :cheers:
Sounds like 3.42 gears in the old one!
'97 Blazer 4x4 127K
'02 Caravan 290K
Mr_Bowtie
Topics: 69
Images: 8
Year: 1996
Postby doyoulikeithere » November 9th 2009, 5:05am
Cmon you guys, like, dontcha even know?
He says it has 11-41 stamped on it.
11-41 exactly represents how many teeth are on the pinion (11) and crown (41)
11 goes into 41 exactly 3.72727273 times, it was a 3.73:1 axle.......
The reply on page 1 showed a stamp = 13-42
13 goes into 42 exactly 3.23076923 times, it was a 3.23:1 axle.......
Pretty basic stuff, once you know what it means.
:twisted:
doyoulikeithere
Years of Membership: doyoulikeithere has been a member for 5 full yearsdoyoulikeithere has been a member for 5 full yearsdoyoulikeithere has been a member for 5 full yearsdoyoulikeithere has been a member for 5 full yearsdoyoulikeithere has been a member for 5 full years
Topics: 25
Images: 11
Postby grandamle91 [OP] » November 9th 2009, 6:28am
doyoulikeithere wrote:Cmon you guys, like, dontcha even know?
So whats the speed difference in 3.42 (new gears) and 3.73 (Old gears)
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
Postby Kirkus » December 23rd 2009, 10:14am
This looks like a very good job from the pics!
I am in the middle of swapping my rear diif. right now. everything was pretty much straight forward and it started to come out. The only issue I am having is with those Godforsaken bolts on the back of the Leaf Springs! How did you gt yours out? Im so close right now but the things will not budge!
Jerome The Bus is his name and taking care of Kirkus is his game. :layrubber: 1992 GMC Safari XT 4.3L 262 RWD At least 240,000 Mi Orig eng and tranny
Kirkus
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Kirkus has been a member for 3 full yearsKirkus has been a member for 3 full yearsKirkus has been a member for 3 full years
Alias (AKA): Kirk
Extra Info: 262 Z
Postby grandamle91 [OP] » December 23rd 2009, 4:59pm
Kirkus wrote:This looks like a very good job from the pics!
Yea its a easy swap till it comes to those bolts, the bolts on my black van wouldn't move even with a wrench and a pipe on it. so cut them, but the ones on the blue van cam right off. i would recommend replaceing them with greaseable bolts, i did just in case
-Evan
grandamle91
Topics: 112
Images: 2
Alias (AKA): Evan
Year: 1997
  • rearend
    by toxictaz » September 16th 2012, 9:58pm in Rear-End
    September 17th 2012, 11:17am
    13Replies
    126Replies
  • rearend
    by toxictaz » September 18th 2012, 11:28pm in Rear-End
    Last post by toxictaz View the latest post
    October 1st 2012, 11:02pm
  • size of the rearend
    by lv383 » September 16th 2009, 4:30am in Rear-End
    Last post by lv383 View the latest post
    September 17th 2009, 3:20am
  • Rearend Whine
    by truebrite » October 1st 2011, 9:00am in Rear-End
    Last post by throrope View the latest post
    October 2nd 2011, 12:00am
  • rearend bearing
    by bigr » September 5th 2012, 2:28am in Rear-End
    Last post by MadMaxiVan View the latest post
    September 5th 2012, 3:16am
Return to Rear-End
It is currently May 18th 2013, 9:11am
Rear-End Forum
Moderator: 1297chevastro
Attached by: chevymaher
in Rear-End
Date: May 06 '13
Time: 1:09am
crash77
in Rear-End
Date: Apr 30 '13
Time: 2:26pm
Attached by: TaxiVan
TaxiVan
in Rear-End
Date: Apr 16 '13
Time: 5:38am
Attached by: choochooastro
choochooastro
in Rear-End
Date: Apr 03 '13
Time: 2:56pm
mervchapman
in Rear-End
Comments: 27
Date: Mar 17 '13
Time: 5:02pm
