AWD?
AWD?
Postby frw [OP] » March 24th 2008, 11:14pm
This may seem like a stupid question, but I am going to ask it anyway. I just recently bought an 02 AWD Astro, and was wondering about the AWD unit. Is it full time AWD like my wife's Land Cruiser where all 4 wheels are engaged at all times, or is it like the AWD setting in my Tahoe where the front wheels are only engaged when there is slipping in the rear (unless I have it in 4Hi or 4Lo)? This is not an earth shattering issue just curious. I am guessing by the steering feel it is like the Tahoe, i.e two wheel rear most of the time with the fronts only pulling when needed.
frw
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: frw has been a member for 5 full yearsfrw has been a member for 5 full yearsfrw has been a member for 5 full yearsfrw has been a member for 5 full yearsfrw has been a member for 5 full years
Topics: 18
  • can i convert a 3.42 AWD to posi
    by stormblue » March 10th 2013, 1:27am in Rear-End
    Last post by chevymaherchevymaher is online! View the latest post
    March 11th 2013, 11:54pm
    39
    May 24th 2013, 5:58pm
Re: AWD?
Postby betz » March 25th 2008, 11:10pm
Yes, the AWD on your Astro is setup like the AWD on your Tahoe. When the rear wheels slip, the AWD is electronically engaged.
betz
Years of Membership: betz has been a member for 5 full yearsbetz has been a member for 5 full yearsbetz has been a member for 5 full yearsbetz has been a member for 5 full yearsbetz has been a member for 5 full years
Re: AWD?
Postby timelessbeing » March 25th 2008, 11:14pm
What about the 2000 model?
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full yearstimelessbeing has been a member for 5 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Re: AWD?
Postby betz » March 26th 2008, 3:11am
Yes, the 2000 model is also the same. It was either 97 or 98 when they switched to the electrical engagement method. Previous to that it was mechanically operated and always putting power to the front wheels.
betz
Re: AWD?
Postby frw [OP] » March 26th 2008, 6:51pm
Thanks that is what I thought but just wanted to be sure.
frw
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 18
Re: AWD?
Postby timelessbeing » May 4th 2008, 8:40pm
I've heard different stories as to when they switched the Astro transfer cases from viscous-coupled to electronic. I've heard anywhere from '97 to '02, so what is it? Will any of my RPO codes indicate what's being used?
timelessbeing
Topics: 38
Re: AWD?
Postby timelessbeing » May 4th 2008, 8:49pm
Found this snippet on Consumer Guide:
1999 Chevrolet Astro: Astro's all-wheel-drive system was revised so that power was only sent to the front wheels when needed for maximum traction. Other changes included a standard overhead console on LS and LT trimmed models.
http://consumerguideauto.howstuffworks.com/1990-to-2004-chevrolet-astro.htm
EDIT: Just checked the tag on the unit itself and it's an NVG 136.
timelessbeing
Topics: 38
Re: AWD?
Postby timelessbeing » May 5th 2008, 7:02am
And here is a schematic and description of how the New Venture Gear 136 works:
http://www.gminsidenews.com/forums/1311746-post2.html
timelessbeing
Topics: 38
Re: AWD?
Postby creativers » May 8th 2008, 1:47am
I have a 1995 AWD Safari. We got hit with a heavy late snow last month, so I tried out my AWD on our steep driveway. It initially had better traction than our new AWD Ford Edge, but when I stopped, then gunned it, either the front or rear wheels would spin while the others sat there. So apparently there is no posi-traction mechanism in the differential (what is this called?) between the front and rear. Is that expected?
creativers
Years of Membership: creativers has been a member for 5 full yearscreativers has been a member for 5 full yearscreativers has been a member for 5 full yearscreativers has been a member for 5 full yearscreativers has been a member for 5 full years
Re: AWD?
Postby ScottS » May 8th 2008, 2:30am
I don't think it is supposed to work that way and it makes me think your fluid needs replaced- but I am doing some research
Interesting article on AWD- I did not know the AWD on the Astro/Safari was made by FF
also found this
http://home.comcast.net/~eliot_www/awd.html
and unrelated but really inetesting- this
http://www.hptuners.com/forum/showthrea ... 225&page=2
1995 Safari AWD
1998 Safari AWD
ScottS
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: ScottS has been a member for 5 full yearsScottS has been a member for 5 full yearsScottS has been a member for 5 full yearsScottS has been a member for 5 full yearsScottS has been a member for 5 full years
Re: AWD?
Postby creativers » May 15th 2008, 12:33am
That is a very informative article. I've heard some of the words kicked around before, but this helps. Thanks.
creativers
Re: AWD?
Postby mystrovan » May 22nd 2008, 12:30am
Hey there creativers. You were saying on a snowey slope one front wheel breaks loose and a rear wheel too, thats normal if you don't have any positrack differentials. Once one on the back and one on the front slip it just sits there like a two wheel drive! Mines the same. The trans-case is doing its thing to send power to the front too, obviously you have seen one front wheel spinning, but beyond the trans-case it can't make anymore wheels grab if theres no positrack.. I had a F**D Aerostar ( :o ) once, it was 2WD and it had possitrack in the back and I loved it. It ploughed through snow like a tank. Not saying my astro don't....just keep the momentum up!
1998 Chev Astro AWD.
mystrovan
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: mystrovan has been a member for 5 full yearsmystrovan has been a member for 5 full yearsmystrovan has been a member for 5 full yearsmystrovan has been a member for 5 full yearsmystrovan has been a member for 5 full years
Return to Rear-End
It is currently May 24th 2013, 5:58pm
Rear-End Forum
Moderator: 1297chevastro
Attached by: chevymaher
in Rear-End
Date: May 06 '13
Time: 1:09am
crash77
in Rear-End
Date: Apr 30 '13
Time: 2:26pm
Attached by: TaxiVan
TaxiVan
in Rear-End
Date: Apr 16 '13
Time: 5:38am
Attached by: choochooastro
choochooastro
in Rear-End
Date: Apr 03 '13
Time: 2:56pm
mervchapman
in Rear-End
Comments: 27
Date: Mar 17 '13
Time: 5:02pm
