Differential Pinion Seal Leak
Postby stewartmcgann [OP] » September 21st 2010, 7:30pm
The vehicle is a 1995 Astro AWD About a week ago my van start make a pop noise followed by a whirring noise for about 100 ft then stop. I was just gonna let it go til i had a day off to get under and take a look at it as this only happened maybe once a day. Well yesterday i pulled out and it immediately made much louder pop and whir noise and repeated the pop whir several times in about a 3 mile run so i parked it and got underneath it and noticed what appears to be differential fluid spun out of the pinion seal area. It has been parked all day and has not dripped any fluid i am not sure if this means it is bone dry or it can only leak while spinning. I know i need to replace the seal but i was wondering if i need to go ahead and replace all four bearings or if i can top it off and crank a few thousand more out of em if they are already making noise. also are there any other components that could be damaged and need replaced while i am in there i had a bad u joint replaced about 2 months ago and think that this could have lead to the seal failure.
stewartmcgann
Years of Membership: stewartmcgann has been a member for 6 full yearsstewartmcgann has been a member for 6 full yearsstewartmcgann has been a member for 6 full yearsstewartmcgann has been a member for 6 full yearsstewartmcgann has been a member for 6 full yearsstewartmcgann has been a member for 6 full years
  • Need an entire rear axle/differential for my 91 Astro
    by JohnK4321 » January 4th 2017, 2:54am in Rear-End
    Last post by MI_Ghost View the latest post
    January 4th 2017, 4:41pm
  • 2004 RWD differential to 2003 AWD
    by WDMICKJR » April 19th 2017, 7:19pm in Rear-End
    Last post by WDMICKJR View the latest post
    April 28th 2017, 10:44am
    7
    35
    May 23rd 2017, 11:46pm
Re: Differential Pinion Seal Leak
Postby astroturf » September 21st 2010, 9:08pm
stewartmcgann wrote:The vehicle is a 1995 Astro AWD About a week ago my van start make a pop noise followed by a whirring noise for about 100 ft then stop. I was just gonna let it go til i had a day off to get under and take a look at it as this only happened maybe once a day. Well yesterday i pulled out and it immediately made much louder pop and whir noise and repeated the pop whir several times in about a 3 mile run so i parked it and got underneath it and noticed what appears to be differential fluid spun out of the pinion seal area. It has been parked all day and has not dripped any fluid i am not sure if this means it is bone dry or it can only leak while spinning. I know i need to replace the seal but i was wondering if i need to go ahead and replace all four bearings or if i can top it off and crank a few thousand more out of em if they are already making noise. also are there any other components that could be damaged and need replaced while i am in there i had a bad u joint replaced about 2 months ago and think that this could have lead to the seal failure.
Have a look here:
viewtopic.php?f=108&t=4572&p=31898&hilit=diff+rebuild#p31898
Hope it helps, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby stewartmcgann [OP] » September 21st 2010, 9:27pm
This does give me some insight into it but it appears i failed to mention that it is the front differential and not the rear that i am having to replace any info on the front.
stewartmcgann
Postby astroturf » September 21st 2010, 10:30pm
Hey, You got me on that one...
I am currently a 2wd Guy.
Someone will chime in and hook you up. Hang in there.
Jim
astroturf
Topics: 112
Postby stewartmcgann [OP] » September 21st 2010, 11:38pm
Do you think it would be proper to post this under the transmission section as it has more to do with the front end and not the rear end.
stewartmcgann
Return to Rear-End
It is currently May 23rd 2017, 11:46pm
Rear-End Forum
Moderator: 1297chevastro
Funaticus
in Rear-End
Date: Apr 04 '17
Time: 4:36am
gordo999
in Rear-End
Comments: 21
Date: Apr 04 '17
Time: 2:53am
astroconvert
in Rear-End
Date: Apr 01 '17
Time: 10:18pm
Attached by: 97cargocrawler
97cargocrawler
in Rear-End
Date: Mar 16 '17
Time: 4:10pm
97cargocrawler
in Rear-End
Comments: 20
Date: Mar 15 '17
Time: 11:18pm
Users browsing this forum: Yahoo [Bot] and 4 guests
