Double Torque Rearend
Postby miniVan [OP] » November 25th 2010, 2:17am
Few years back when I had my rear end/axle serviced/repaired, my mechanic told me that my truck (97 Astro) has a "double torque" rear differential and that it had more towing capabilities than the standard rearend. They mentioned that I can tow more than the specified/recomended weight because of this feature. Can someone explain to me abit more how a double torque rear end works compared to a standard one?
miniVan
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: miniVan has been a member for 4 full yearsminiVan has been a member for 4 full yearsminiVan has been a member for 4 full yearsminiVan has been a member for 4 full years
Topics: 25
  • Need a RearEnd OverHaul
    by My1988Astro » November 26th 2012, 6:13am in Rear-End
    Last post by chevymaherchevymaher is online! View the latest post
    November 27th 2012, 2:43am
  • 8.8 Explorer rearend measurements
    by HotrodDaddy44 » January 30th 2013, 3:04am in Rear-End
    Last post by HotrodDaddy44 View the latest post
    January 30th 2013, 11:38pm
    52
    May 19th 2013, 9:20pm
Re: Double Torque Rearend
Postby Gary » November 25th 2010, 3:45am
It would help a bunch if you told us which van you own. :confused:
Keeping it real.
Gary
Firing on 4 Cylinders (L3)
Years of Membership: Gary has been a member for 5 full yearsGary has been a member for 5 full yearsGary has been a member for 5 full yearsGary has been a member for 5 full yearsGary has been a member for 5 full years
Topics: 124
Extra Info: high top
Postby Big_kid » November 25th 2010, 3:49am
I've never heard of a "double torque" rear end. I'd find another mechanic if he thinks a beefed up differential increases your vehicle's tow rating or what you can tow safely.
There is MUCH more to a tow rating than how torque gets from the driveshaft to the wheels. Braking, traction, braking, suspension, braking, transmission/steering/engine cooling, braking, suspension, steering, braking and suspension all play important parts. Did I mention suspension and braking? To me, they're more important than the differential when it comes to towing.
I found this to be a good read:
http://www.nhtsa.gov/cars/problems/equi ... /index.htm
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
  • rearend
    by toxictaz » September 16th 2012, 9:58pm in Rear-End
    September 17th 2012, 11:17am
    16Replies
    111Replies
  • rearend
    by toxictaz » September 18th 2012, 11:28pm in Rear-End
    Last post by toxictaz View the latest post
    October 1st 2012, 11:02pm
  • size of the rearend
    by lv383 » September 16th 2009, 4:30am in Rear-End
    Last post by lv383 View the latest post
    September 17th 2009, 3:20am
  • Just Swap My First Rearend
    1, 2Attachment(s) by grandamle91 » October 25th 2009, 3:34am in Rear-End
    Last post by grandamle91 View the latest post
    March 12th 2011, 5:05pm
  • Rearend Whine
    by truebrite » October 1st 2011, 9:00am in Rear-End
    Last post by throrope View the latest post
    October 2nd 2011, 12:00am
Return to Rear-End
It is currently May 19th 2013, 9:20pm
Rear-End Forum
Moderator: 1297chevastro
Attached by: chevymaher
in Rear-End
Date: May 06 '13
Time: 1:09am
crash77
in Rear-End
Date: Apr 30 '13
Time: 2:26pm
Attached by: TaxiVan
TaxiVan
in Rear-End
Date: Apr 16 '13
Time: 5:38am
Attached by: choochooastro
choochooastro
in Rear-End
Date: Apr 03 '13
Time: 2:56pm
mervchapman
in Rear-End
Comments: 27
Date: Mar 17 '13
Time: 5:02pm
