Just a heads up for anybody on the board who is from Southern Ontario Canada... I have a small part time business named BCR Electronics Reycling. The website is http://www.bcrelectronics.ca
I've been doing this for 4 years now. The main focus of my business is the actual recycling of various electronics, mostly computers. However I also do board level repair on motherboards and computer power supplies. If you have a computer that is randomly shutting off and rebooting itself, you have either bad capacitors on your motherboard and power supply or a combination of both.
I can save you the hassle of re-installing Windows if I get the motherboard in time. Also with power supplies they need to be absolutely clean and free of dust inside. This is the biggest reason why power supplies fail, the heat inside becomes excessive and in turn the capacitors inside get to hot and they go bad. Provided the power supply is still working, I can replace any bad capacitors inside and change out fans if need be. :ty:
