hatchback storage box silicone ?
Postby webcat [OP] » February 9th 2011, 3:30am
I made a hatchback storage box thats accessible from the outside of the vehicle , its made of wood so i weatherproofed it and i'm planning on painting the box flat black and paint the louvers red before i install , my problem is i dont know what would be the best silicone to use between the wood and the vans metal door to keep the rain out?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
  • Welding a new foot box?
    by Echo » December 4th 2016, 3:13am in Exterior
    Last post by Echo View the latest post
    December 4th 2016, 5:49pm
    7
    28
    March 26th 2017, 1:59pm
Re: hatchback storage box silicone ?
Postby Mr_Bowtie » February 9th 2011, 3:49am
Very interesting! You got a lot of cool ideas! :clap:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Year: 1985
Extra Info: 350 with 700r4
Postby WoodButcher » February 9th 2011, 3:58am
I like using EPDM lap sealant for this kind of thing. I'd be interested in seeing more pics on this hatch, weathersripping of the door in particular.
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 449
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby webcat [OP] » February 9th 2011, 4:12am
WoodButcher wrote:I like using EPDM lap sealant for this kind of thing. I'd be interested in seeing more pics on this hatch, weathersripping of the door in particular.
I woud just use the rubber weather stripping that went around the hole for the window but its kinda thick and since i'm using (2) 1/4" pieces of plywood it would stick out to far so i was going to put a bead of silicone around the window hole instead.
webcat
Topics: 253
Postby WoodButcher » February 9th 2011, 4:47am
Never found a silicone I liked, the only thing I'll guarantee it sticks to is itself,, I've also read that it causes / promotes rust. If I was needing a clear there is a product called Geocel I've used, also a roofers product that adheres to everything I've tried. It is made for metal roofs.
http://www.geocelusa.com/php/oic/produc ... gory_id=30
WoodButcher
Topics: 28
Images: 449
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby webcat [OP] » February 9th 2011, 4:57am
Thats all i have for pictures right now .
It says its excellent adhesion to many building materials , thats what i'm looking for.
Thanks
webcat
Topics: 253
Postby WoodButcher » February 9th 2011, 5:14am
No problem, I have seen it at home depot or lowes, can't recall which.
WoodButcher
Topics: 28
Images: 449
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby alexalexanders » February 10th 2011, 1:56am
Thats a pretty sweet idea!
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
Postby webcat [OP] » February 12th 2011, 2:18am
WoodButcher wrote:No problem, I have seen it at home depot or lowes, can't recall which.
Do they keep it in the roofing department or paint department?
webcat
Topics: 253
Postby webcat [OP] » February 12th 2011, 2:37am
webcat
Topics: 253
Postby WoodButcher » February 12th 2011, 3:00am
Not sure, sorry, I did happen to see it in a local hardware store today.
WoodButcher
Topics: 28
Images: 449
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby rev_les » February 12th 2011, 11:22am
Use non-acetic silicone, it doesn't cause rust ( no acid ) a local auto body supply should have it, if not, Crest supply, or CR Laurance should have it. Worst case, I'm road tripping to W Des Moines next month, I could bring you a tube of it. :mrgreen: ( My mother in law's moving here, I gotta help her out) !
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby webcat [OP] » February 13th 2011, 11:20am
The box goes on the inside of the van , the 1/4" piece of plywood with the square cut into it goes where the window use to be on the outside of the van and will have screws mounting it to the box .
The piece at the very top is another piece of 1/4" plywood but is solid instead of having a square cut into it and its there so the hinges at the top have something to mount to and also to give the louver rigidity because there made of very thin plastic.
when there closed it should be a very solid piece to protect it from wind and rain.
Also going to try and put struts on it to hold the door open but not sure how thats going to work out.
Should look pretty sweet after i get the louvers painted dark metalic toreador red
webcat
Topics: 253
Postby icebrrg3rd » February 14th 2011, 8:57pm
If the door is light, you might not want to put struts on it, as they might "push" too hard and deform the material. Maybe just a prop rod, that would be fairly easy to construct. Or maybe a table drop leaf hinge support. Those would auto lock open, but still be easy to close.
Keep the updates coming, can't wait to see it installed.
-Andrew
81 Yamaha Maxim 650XJ 650cc, 67k mi
83 Yamaha Venture 1300cc, 91k mi
91 Chevy Astro 5.7L 5-speed, Ford 9", 250k mi
02 Chrysler Sebring Conv. 2.7L 5-speed, 181k mi
10 Chrysler Town & Country 3.8L, 128k mi
icebrrg3rd
Firing on 8 Cylinders (L2)
Years of Membership: icebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full years
Topics: 43
Alias (AKA): Andrew
Year: 1991
Postby webcat [OP] » February 15th 2011, 1:24am
i'm gonna haveto work on the gap at the top , probally put bigger tubular seal on it
webcat
Topics: 253
Postby B-rad » February 19th 2011, 4:43am
Thats cool.. I been thinking about doing something like that with my side rear quorter widnows... They are just covered on the inside anyway and woud be awesome to have access on the outside like that on the sides! nice idea :banana:
1996 Safari SLT AWD, T-bars cranked, S-10 Springs, Rancho Shocks, 31"BFG's, Realtree CamoWrap, Conversion van sofa/ sleeper, 5 passanger, family fun camping/hunting van! (Manual Trans. Case, 3" BL To be installed)
B-rad
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: B-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full yearsB-rad has been a member for 7 full years
Extra Info: AWD SLT
Postby AstroCan » February 19th 2011, 5:24am
So what are you going to use that box for?
2004 Astro LS AWD
AstroCan
Years of Membership: AstroCan has been a member for 6 full yearsAstroCan has been a member for 6 full yearsAstroCan has been a member for 6 full yearsAstroCan has been a member for 6 full yearsAstroCan has been a member for 6 full yearsAstroCan has been a member for 6 full years
Topics: 59
Extra Info: LS
Postby webcat [OP] » February 22nd 2011, 6:32am
AstroCan wrote:So what are you going to use that box for?
Tools
webcat
Topics: 253
Return to Exterior
It is currently March 26th 2017, 1:59pm
Exterior Forum
Attached by: codydaniels
codydaniels
in Exterior
Date: Mar 23 '17
Time: 5:07pm
Attached by: 9T8_Safari_Guy
9T8_Safari_Guy
in Exterior
Date: Mar 21 '17
Time: 12:44am
K/4
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 10:55pm
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 2:57pm
Pikston
in Exterior
Date: Mar 16 '17
Time: 2:31am
