Windshield Top leak
Windshield Top leak
Postby DjPcEra [OP] » May 18th 2011, 2:48am
I't rained all night and I didn't notice till this morning around 10am that there is a leak.
What can I do to stop it? some transparent caulking/crazy glue (lol?) ? :confused: :feedback:
1998 Chevy Astro : RWD 4.3L LS
DjPcEra
Years of Membership: DjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full yearsDjPcEra has been a member for 5 full years
Topics: 26
Alias (AKA): Mr.Gee
Extra Info: LS 4.3L V6 RWD
Re: Windshield Top leak
Postby chevymaherchevymaher is online! » May 18th 2011, 3:32am
Go to auto paint shop buy clear silicon in small tube.Stick point behind trim and run a bead on both sides of trim around leak.
Topics: 79
Year: 1994
Postby paintdrying » May 18th 2011, 3:35am
I used clear silicone. Probably not a good way to go. Maybe wipe it with acetone first. I had to smear it thin and wide. The first bead I ran was laser thin and perfect, It did not stick . The thin and wide bead stopped the leak and that made me happy. It lasted for years that way. Looked like a child had chalked it, but as I get older things like that bother me less and less.
paintdrying
Topics: 94
Extra Info: 108 000
Postby DjPcEra [OP] » May 18th 2011, 3:59am
paintdrying wrote:I used clear silicone. Probably not a good way to go. Maybe wipe it with acetone first. I had to smear it thin and wide. The first bead I ran was laser thin and perfect, It did not stick . The thin and wide bead stopped the leak and that made me happy. It lasted for years that way. Looked like a child had chalked it, but as I get older things like that bother me less and less.
thanks both of you... :) will be stopping at home depot !!! :ty: :ty: :ty: :ty:
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Postby NY Safari TONKA » May 18th 2011, 5:34am
I used silicone for home windows(Home Depot) right at the connection of the seal on top of psngr side windshield just clean real good... :dance:
NY Safari TONKA
Years of Membership: NY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full yearsNY Safari TONKA has been a member for 5 full years
Extra Info: AWD EXT 4.3L V6
Postby crazedfox » May 18th 2011, 11:51am
If,
__you have full coverage, hit it with a small rock. & go call yer' agent.
:rofl:
Bad,boy down,down :whack:
Some choose to shift.
While others, choose not to.
98' Astro AWD W-Eng. code.
crazedfox
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: crazedfox has been a member for 5 full yearscrazedfox has been a member for 5 full yearscrazedfox has been a member for 5 full yearscrazedfox has been a member for 5 full yearscrazedfox has been a member for 5 full years
Postby DjPcEra [OP] » May 18th 2011, 5:12pm
crazedfox wrote:If,
:rofl:
:goodpost: NOT!
For all others thanks :)
how long does it take for it 2 dry up in humid/rain :shrug:
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Postby paintdrying » May 18th 2011, 11:13pm
Humid rain, to the touch, maybe a few hours. You could drive it around town after maybe 8 hours. A full day and maybe you could take it on the highway. You do nt want the force of the wind tearing the seal. If there is no flex in your joint you should be good by morning. I know the label always says 24 hours to full cure, but the humidity thing makes it tricky.
paintdrying
Topics: 94
Extra Info: 108 000
Postby DjPcEra [OP] » May 19th 2011, 10:07pm
paintdrying wrote:Humid rain, to the touch, maybe a few hours. You could drive it around town after maybe 8 hours. A full day and maybe you could take it on the highway. You do nt want the force of the wind tearing the seal. If there is no flex in your joint you should be good by morning. I know the label always says 24 hours to full cure, but the humidity thing makes it tricky.
this said fine with 50% humid
but Im gonna apply another layer today
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Postby paintdrying » May 20th 2011, 1:56am
one thing I fail to mention is you will not see the caulking for awhile, then dirt will cling to it, reveling itself as a dirt seal instead of the invisible chalk you first put on.
paintdrying
Topics: 94
Extra Info: 108 000
Postby DjPcEra [OP] » May 20th 2011, 2:21am
paintdrying wrote:one thing I fail to mention is you will not see the caulking for awhile, then dirt will cling to it, reveling itself as a dirt seal instead of the invisible chalk you first put on.
you can't really see it.. since it's inside that black plastic :)
DjPcEra
Topics: 26
Alias (AKA): Mr.Gee
Postby AK1 » June 10th 2015, 11:14pm
chevymaher wrote:Go to auto paint shop buy clear silicon in small tube.Stick point behind trim and run a bead on both sides of trim around leak.
I also have a leak in the cabin, dripping right by the rear view (but it could just be collecting in the center).
I'm thinking of ordering this: http://cart.autopartswarehouse.com/basket?ai=true
But silicone would be faster and cheaper - are you saying to apply it on the exterior or interior underneath the headliner?
Thanks!
AK1
Years of Membership: AK1 has been a member for 1 full year
Images: 11
Year: 2000
Postby chevymaherchevymaher is online! » June 10th 2015, 11:42pm
Thanks!
Just get tube with a small pointed end. Jam it under the rubber trim on the outside. Run a bead around the windsheild on both sides of the rubber trim. Whipe the excess that squirts out off. Just keep rubbing as it hardens and it peels off easily and leaves no visible trace.
It you let it harden and then try to clean it off it wont come off and leaves a messy looking seal.
EDIT; aquarium sealer really works good to. It is clear.
Topics: 79
Year: 1994
Postby AK1 » June 17th 2015, 7:21pm
I tried some black silicone and it worked in some spots, but didn't complete the job... Could be partially my fault, too. I got some 3M weatherstrip sealer which did the job again and it worked much better. :mrgreen:
AK1
Images: 11
Year: 2000
Postby LumpyLumpy is online! » June 17th 2015, 7:24pm
AK1 wrote:I tried some black silicone and it worked in some spots, but didn't complete the job... Could be partially my fault, too. I got some 3M weatherstrip sealer which did the job again and it worked much better. :mrgreen:
Could you detail how you installed/used the goo please? Were you going for the space between metal and rubber or rubber and glass?
Topics: 257
Year: 1989
Postby AK1 » June 17th 2015, 7:30pm
Hey Lump - I peeled back the the weatherstrip to get the nozzle underneath it; then I squirted enough in so that it was overflowing out of the entire length of the weatherstrip. I also made sure to squirt some in the corners where the door overlaps. Once it dried I detailed it a bit by hand so it didn't look messy. The silicone was thinner and although I did it the same way it didn't seal it completely. Again, though, it would probably work had I put in more time and effort. In sum, though, the 3M product was a 5 minute process and there is no more leaking.
AK1
Images: 11
Year: 2000
Postby LumpyLumpy is online! » June 17th 2015, 9:04pm
Thanks. And is it 3M Weatherstrip Adhesive? Or do they have a product called Weatherstrip Sealer?
Topics: 257
Year: 1989
Postby AK1 » June 18th 2015, 12:48am
Lumpy wrote:Thanks. And is it 3M Weatherstrip Adhesive? Or do they have a product called Weatherstrip Sealer?
This is the exact one I picked up at O'Reilly's:
http://www.steelerubber.com/weatherstri ... 96-8011-96
It doesn't say "sealer" and I didn't see any that said that, either. It seems if you google it, the more common one that comes up is:
http://www.amazon.com/3M-08008-Black-We ... B00063X38M
That one apparently is "super" and does gaskets, too.
AK1
Images: 11
Year: 2000
Postby AK1 » June 18th 2015, 12:49am
And a side note, Lump - you're van is frikin' awesome, man! Love the pics too. :rockon:
AK1
Images: 11
Year: 2000
Postby LumpyLumpy is online! » June 18th 2015, 2:27am
Thanks and thanks.
Now that I know the right sealer to use, maybe it'll be even frickiner awesome.
tnx
Topics: 257
Year: 1989
Return to Exterior
It is currently January 24th 2017, 2:14pm
Exterior Forum
hurley1718
in Exterior
Date: Today
Time: 2:54am
Attached by: chopsaw209
chopsaw209
in Exterior
Comments: 19
Time: 5:52am
Echo
in Exterior
Comments: 20
Date: Jan 22 '17
Time: 10:22pm
Attached by: kennyj
kennyj
in Exterior
Comments: 20
Date: Jan 22 '17
Time: 9:42pm
AstroNuts
in Exterior
Time: 12:57am
