Fabbing a push bar.
Fabbing a push bar.
Postby WoodMotorsports [OP] » September 2nd 2011, 2:53am
I started building my push bar today. I've seen the adapted Avalanche bars used by a few members, but being a two wheel drive I'm going for more of a police style "urban assault vehicle" look, so I decided to roll my own...
First, the upright template:
Then, transfer to some metal. I had some .25"x4" flat stock at the shop, but needed 6"...so I welded two pieces together. That's why that weld line is there:
Now on to the mounting brackets. Made them out of some monster angle iron I had in the scrap pile. Luckily the stock bumper bolts let me line the upright up with the grill separation at the headlights. I did have to heat up the angle and tweak it to line up "square" with the van, because of the curve of the bumper:
Here are the uprights mocked up on the brackets:
That's as far as I got today, which isn't to bad since I was actually working for a living while doing this side project. I did tweak the uprights to match the angle of the line where the grill meets the headlight/turn signals. I've still got to decide what size tubing for the top tube, and will probably use oval or rectangular tubing for the bottom "rung" where you would mount lights.
98 Cargo, making me money daily.
WoodMotorsports
Years of Membership: WoodMotorsports has been a member for 5 full yearsWoodMotorsports has been a member for 5 full yearsWoodMotorsports has been a member for 5 full yearsWoodMotorsports has been a member for 5 full yearsWoodMotorsports has been a member for 5 full years
Extra Info: Cargo RWD
Re: Fabbing a push bar.
Postby chevymaher » September 2nd 2011, 12:01pm
Very nice a general Lee push bumper.
Topics: 79
Year: 1994
Postby icebrrg3rd » September 2nd 2011, 4:15pm
+1
That's what I'm looking for too, something for the center. Looks great.
-Andrew
81 Yamaha Maxim 650XJ 650cc, 67k mi
83 Yamaha Venture 1300cc, 91k mi
91 Chevy Astro 5.7L 5-speed, Ford 9", 250k mi
02 Chrysler Sebring Conv. 2.7L 5-speed, 181k mi
10 Chrysler Town & Country 3.8L, 128k mi
icebrrg3rd
Firing on 8 Cylinders (L2)
Years of Membership: icebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full yearsicebrrg3rd has been a member for 7 full years
Topics: 43
Alias (AKA): Andrew
Year: 1991
Postby Jasen » September 2nd 2011, 5:01pm
Looking good man. I'd think 3" would look good for the cross bars. 2" seems a bit small and 4" way to big. JMO
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Images: 101
Year: 1997
Postby RECox286 » September 2nd 2011, 9:50pm
If and when I have to push another vehicle, I tie a wheeless tire to the front of the truck, suspended from the hood latch, and that gives me a real good cushy bumper between the pusher and pushee.
Works like a charm, is cheap, and makes me look more "civilian" than "smokey". What I intend on doing is rigging permanent jumper cables under the hood with a battery disconnect switch on the +.
Not against the push bar idea, don't get me wrong, but I have had to jump more times than push. If push came to shove, it might be better to have a tow bar on the front of the truck so you wouldn't need a
tow truck, and usually the cops are only interested in getting a disabled car clear of the road to allow traffic to pass, not long distance hauling/pushing.
Other than that, what you are doing "Looks" very chick. I supose you are going to put a good bit of rubber on the front side ?
Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby WoodMotorsports [OP] » September 2nd 2011, 11:06pm
This is mainly for looks, though I'm happy the bumper bolts worked out to be in the correct spot for my brackets. I do plan to use some 1" or 1.5" flat stock on the front edges of the uprights, and hopefully find some rubber "C" channel trim to clip over that. The Westin bar on my old dually had that, but so far I'm not finding anything online for the rubber trim.
I did chop off a piece of 2" tubing just to get ideas on tubing size, and it's pretty close to what I'm after. I made the uprights close enough to the grill that I'm going to need to contour whatever the top tube ends up being just to clear the point of the hood.
Didn't get a lot accomplished on it today other than painting and permanently mounting the brackets, and drill the mounting holes for the uprights.
WoodMotorsports
Postby Jasen » September 2nd 2011, 11:50pm
Wood try googling loading dock pumpers, semi truck accessories or tow truck supplies,for the rubber bumpers. I think one time searching for the latter I ran across nice thick solid up you can glue on, like you see on tow truck push plates.
200k
Ultra gauge
Images: 101
Year: 1997
Postby WoodMotorsports [OP] » September 4th 2011, 12:34am
Jasen, that got me going with the right "google fu", found a couple places that have what I need.
Here is todays pics. Just a couple mocked up top bar shots. Feel free to advise on the look of this. It's 2 1/8" tubing. As you can tell I had to do some cut/fit to get the curve close to where I want it. I'm thinking this one and another similar down just below the top edge of the bumper. Will also do something just above the bumper line as a light bracket point.
WoodMotorsports
Postby Jasen » September 4th 2011, 12:45am
Glad I could point you in the right direction.
I like it. Why not just one tube in front the the bumper and then run some tabs back over the bumper for the lights, or maybe a 1.5" tube running between the tabs set back in over the bumper for the lights.
200k
Ultra gauge
Images: 101
Year: 1997
Postby redfury » September 4th 2011, 2:46am
damn, I wish I had metal working skills.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby WoodMotorsports [OP] » September 5th 2011, 9:52pm
Getting close to phase 1 being finished. I'm still planning to weld flat stock to the leading edge of the uprights to attach the rubber C channel, but for now I'm painting and riding as is. The C channel will have to be ordered, and I'm waiting for the company to contact me with prices and options. I really wanted it mounted today, but humidity is to high for my paint to dry quickly, so it's spending the night at the shop tonight.
WoodMotorsports
Postby chevymaher » September 5th 2011, 10:38pm
It is looking awsome.My brothers dukes of Hazzard charger jealous now.That is going to look good when your finished.
Topics: 79
Year: 1994
Postby Jasen » September 5th 2011, 11:17pm
Lookin good
200k
Ultra gauge
Images: 101
Year: 1997
Postby WoodMotorsports [OP] » September 6th 2011, 2:43pm
Not the nicest day to be taking photos, but I did get it mounted up this morning:
WoodMotorsports
Postby Jasen » September 6th 2011, 5:19pm
That'll make those prius drivers get out of your way.
200k
Ultra gauge
Images: 101
Year: 1997
Postby redfury » September 6th 2011, 11:00pm
Jasen wrote:That'll make those prius drivers get out of your way.
they won't see the bar though, the alignment of the uprights is almost perfectly inline with the grill lines.
:bow:
redfury
Topics: 53
Images: 13
Year: 1998
Postby Jasen » September 7th 2011, 1:58am
:bow:
The will when it's rubbing up against their head rest :mrgreen:
200k
Ultra gauge
Images: 101
Year: 1997
Postby Lumpy » September 7th 2011, 2:21am
Jasen wrote:The will when it's rubbing up against their head rest :mrgreen:
And when you honk those six cadillac Astro Blaster horns behind the grille.
Lump... :layrubber:
Topics: 256
Year: 1989
Postby Jasen » September 7th 2011, 2:32am
Alright Lumpy, sound off
[youtube]<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/73R2UTpmjy0&hl=en_US&feature=player_embedded&version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/73R2UTpmjy0&hl=en_US&feature=player_embedded&version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></embed></object>[/youtube]
200k
Ultra gauge
Images: 101
Year: 1997
Postby drmmhmd » September 7th 2011, 3:52am
redfury wrote:damn, I wish I had metal working skills.
skills?
drmmhmd
Years of Membership: drmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full years
Extra Info: AWD 400 CID
Return to Exterior
It is currently January 18th 2017, 11:10pm
Exterior Forum
in Exterior
Date: Jan 16 '17
Time: 10:29pm
ironhead79
in Exterior
Date: Jan 16 '17
Time: 2:53am
ironhead79
in Exterior
Date: Jan 16 '17
Time: 1:48am
ironhead79
in Exterior
Date: Jan 15 '17
Time: 10:51pm
Attached by: Astro Pop
Astro Pop
in Exterior
Comments: 141
Date: Jan 06 '17
Time: 7:15am
