Rear Hatch on 2000 Astro stuck on passenger side
Postby webb2000astro [OP] » September 9th 2011, 1:12am
I have a 2000 Chevy Astro, and the rear hatch will unlock, but when i press the switch, only the driver's side will open. I've researched some, and it seems to be a pretty common occurrence. I tried replacing the #13 cigarette lighter fuse (I've read if this fuse blows, only one side of the hatch will open), but the same problem persisted. Are there any other fuses tied into this? Should I try to pop the panel off from the inside?
Also, I'm not sure if it may be a connected problem, but about a year ago my keychain remote stopped unlocking my doors, and next my driver's side door will only unlock/lock halfway if i use the key in any other latch EXCEPT the driver's side door...not sure if that's tied in, but figured I'd throw it in there.
I greatly appreciate any help!
webb2000astro
Years of Membership: webb2000astro has been a member for 5 full yearswebb2000astro has been a member for 5 full yearswebb2000astro has been a member for 5 full yearswebb2000astro has been a member for 5 full yearswebb2000astro has been a member for 5 full years
Alias (AKA): Billy
  • FOUND MY PASSENGER SIDE RATTLE!!!
    by Mmusicman » November 29th 2016, 8:53pm in Exterior
    November 30th 2016, 9:54pm
  • Rear hatch issues, start new or necro threads?
    by BuddyHuggs » October 3rd 2016, 6:54pm in Exterior
    Last post by BuddyHuggs View the latest post
    October 7th 2016, 4:51pm
    March 24th 2017, 6:51pm
Re: Rear Hatch on 2000 Astro stuck on passenger side
Postby RECox286 » September 9th 2011, 3:06am
There is only one solenoid that is used to unlock the hatch. If one side is unlatching, and the other is not, then probably one of the connecting rods from the solenoid to the latch has come loose of its' mounting.
Remove the center handle and plate to reveal the connecting rods, and (hopefully) you will be able to pull the pax side manually. That is, if the rod is off at the solenoid end of the assembly.
Good luck, and good hunting
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby webb2000astro [OP] » September 9th 2011, 6:32pm
Thanks for the advice, Bob. I'm about to give it a go now.
webb2000astro
Alias (AKA): Billy
Postby webb2000astro [OP] » September 9th 2011, 7:54pm
Problem solved! I just had to pop off the panel...the rod popped out of the latch...looked like the nut holding it on was stripped. I think I slammed it a little too hard! :geek:
webb2000astro
Alias (AKA): Billy
Postby RECox286 » September 9th 2011, 11:23pm
Chevy has used several different fastener types to hold the rods secure. I think the tinnerman nut style is heads over heals from the plastic bushing type. Once the rod pops out, you can be assured that there will be a repeat performance because the fastener has lost most of its' gripping power. Plastic bushings are not generally available except in the JY, and the metal fastener, as far as I know, only come with the new part as a piece of the assembly. So, it is off to the JY in either case.
Glad you got it open, and if you are up to it, try to do something to upgrade your attachments before they really leave you in a fix.
Bob
Right now I am in the throes of changing all the attachments in one of our trucks' driver side doors. Only the inside lever will operate the latch to open the door. What a pain !
RECox286
Topics: 38
Year: 1993
Postby Lobi » December 14th 2011, 4:50am
Opening up an old post here but thought I should share this thought..
I've owned 3 Astros and dealt with the one rod that always pops off and only one side of the hatch unlatches.
Yep, easy fix, removed handle etc.
But, save yourself the grief of it popping back of next month or next week or next slam shut if you have teenage boys
Pop the rod into the plastic retaining clip then use a small zip tie around the rod and the arm of the solinoid that holds the crappy retraining clip and ta-da, fixed for good!
Lobi
Years of Membership: Lobi has been a member for 5 full yearsLobi has been a member for 5 full yearsLobi has been a member for 5 full yearsLobi has been a member for 5 full yearsLobi has been a member for 5 full years
Postby fasteddy » June 3rd 2012, 10:01pm
Thanks, guys. Fixed mine, too.
fasteddy
Years of Membership: fasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full yearsfasteddy has been a member for 7 full years
Alias (AKA): eddy
Postby pjw99 » July 22nd 2012, 9:55pm
To access the solenoid and connecting rods in the rear window hatch, how exactly does one "remove the center handle"? The outside center handle has no visible screws or bolts. The inside handle has is surrounded by a plastic cover, but it does not appear to be able to be pried without breaking.
pjw99
Years of Membership: pjw99 has been a member for 4 full yearspjw99 has been a member for 4 full yearspjw99 has been a member for 4 full yearspjw99 has been a member for 4 full years
Year: 1997
Extra Info: 4.3L V6 AWD
Postby Leeann_93 » July 23rd 2012, 12:38am
Pop the little plastic covers on either side of the actual handle to reveal the bolts that hold it on. But remove the phillips-head screws on either side of the panel, then pull the door panel carefully, you're popping metal clips on plastic posts out of their holes. You just need enough to get your hand in there and pull on the rod on the offending side.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Return to Exterior
It is currently March 24th 2017, 6:51pm
Exterior Forum
Attached by: codydaniels
codydaniels
in Exterior
Time: 5:07pm
Attached by: 9T8_Safari_Guy
9T8_Safari_Guy
in Exterior
Date: Mar 21 '17
Time: 12:44am
K/4
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 10:55pm
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 2:57pm
Pikston
in Exterior
Date: Mar 16 '17
Time: 2:31am
