Stuck Hood, Please help...
Postby doyoulikeithere [OP] » April 1st 2009, 1:58am
Hi. I went to move one of my vans. The battery was dead, so I needed to jump it...
The hood wont open when I pull the release in the cab.
So, I get my son to pull and wiggle the handle while I try to pull and wiggle the hood around, hopeing to pop it open. No luck. I really need to move the van. Can I get at it from the ground under the rad or something? Anyone else figured out this problem yet?
Any sugestions?
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full yearsdoyoulikeithere has been a member for 9 full years
Topics: 26
Images: 11
  • New hood and grill
    by zzimmer3 » June 26th 2017, 3:32am in Exterior
    June 26th 2017, 7:03pm
  • Hood swap safari to astro
    by Rockridge » December 31st 2016, 3:44pm in Exterior
    January 1st 2017, 5:08pm
    9
    60
    June 28th 2017, 10:03pm
Re: Stuck Hood, Please help...
Postby RydQlty » April 1st 2009, 6:08am
Mine gets stuck occasionally, it doesnt open if I pull it open.
But if I push it down, and have a friend pull the release and hold it, it opens after I let the hood go.
A little lube fixes that for me...hope it helps.
2004 Astro AWD
RydQlty
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: RydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full years
Alias (AKA): The Big Easy
Postby CaptSquid » April 1st 2009, 6:39am
Unless you have several U-Joints in your arm, you're going to have to resort to pushing down on the hood while a helper pulls the cable on the inside. Once you get the hood open, lube the latch with MOTOR OIL, not grease. You can get enough from your dipstick.
Mike
92 Safari SLE with Z motor
Look for the MISSING Alien in the Right Seat -- AL, PHONE HOME!
CaptSquid
Years of Membership: CaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full yearsCaptSquid has been a member for 9 full years
Topics: 10
Postby doyoulikeithere [OP] » April 1st 2009, 2:57pm
Thanks, Ive tried and tried the push/pull scenario. not workin...
Thats why I've posted looking for further advice. Its snowing today, so maybe when it warms up...
:twisted:
doyoulikeithere
Topics: 26
Images: 11
Postby smokamoto » April 1st 2009, 5:39pm
Ok, same issue with mine. I've lubed, readjusted (bent) the latch so it works, it eventually goes back to stuck. Right now, it's stuck, so I grab the front edge of the hood with my fingers and wiggle up & down, it then pops up (of course after pulling the inside release lever).
smokamoto
1998 Astro 2WD 8 passenger
120k miles
Previous Astros-'95 passenger, '90 passenger
smokamoto
Years of Membership: smokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full yearssmokamoto has been a member for 9 full years
Alias (AKA): smokamoto
Year: 1998
Extra Info: 8 passenger RWD
Postby Matrixx » April 1st 2009, 9:31pm
Hi doyoulikeithere
Does the hood release handle feel like the cable is still pulling on the hood release mechanism or do you think the cable is broken? If it feels like it's still releasing the hood latch, then maybe get a set of needle nose pliers and grab the end of the cable where it hooks into the hood release handle and "gently" give it a pull that way.
If you feel the cable is broken then your going to have to think out side of the box and fashion a devise that will slip in between the hood and grille with an angle to it at the end to get up into the latch area to release it from that point. A long thin flat head screw driver may work with an angle at the end of it to grab the latch and release it. Just a thought.:)
PS: Here is a view of the hood latch in relation to the grille:
gallery2.php?g2_itemId=465
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby Matrixx » April 2nd 2009, 9:55am
Hi doyoulikeithere
Just another thought here, is to take the dog house off and try to access the hood latch from their. I'm sure you could find something long enough to reach it from that point. Hopefully something here will help, please keep us updated, Thanks.:)
Matrixx
Postby astro355 » April 2nd 2009, 11:49am
Matrixx wrote:Hi doyoulikeithere
Isn't there two bolts that have to be removed from the engine compartment before the doghouse can be taken off? Or is that on 1st gen vans?
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full yearsastro355 has been a member for 9 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby Matrixx » April 2nd 2009, 11:57am
All the fasteners are on the inside of cab to remove the dog house with the 96 and newer vans.:)
Matrixx
Postby astro355 » April 2nd 2009, 11:59am
Well, they did make some kind of improve from the 1st gen to 2nd gen vans, didn't they? :mrgreen: My bad, I didn't know what year the OP's van was.
astro355
Year: 1989
Postby Matrixx » April 2nd 2009, 12:32pm
Well you bring up a good point about the year of his van. I thought it was 96, but you have me thinking now, hmm, I'm not very good at this Cloak and Dagger stuff, hehe. I guess we'll find out soon enough.:)
Matrixx
Postby CaptSquid » April 2nd 2009, 8:07pm
Matrixx wrote:All the fasteners are on the inside of cab to remove the dog house with the 96 and newer vans.:)
On my 92, they're on the inside, not in the engine compartment.
Mike
CaptSquid
Topics: 10
Postby astro355 » April 2nd 2009, 8:27pm
And I wish my 89 was that way. Its only two bolts in the engine compartment but for some reason, it just makes it seem more complicated. :confused:
astro355
Year: 1989
Postby gillbates » April 3rd 2009, 2:07am
I use to have this problem as well. I got pretty good at hitting the hood just above the grill about 4-5 inches from the center, on the drivers side, with the palm of my hand while someone pulled the release. I also had the interior piece the the release is mounted in off one time and it worked perfectly.
The problem, which I discovered on this board, is that the latch is binding against the side of the either the front or the back of the female side. You should be able to tell which by looking at the marks made from strikes. If you bend it away from where it's binding it will open correctly.
gillbates
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: gillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full yearsgillbates has been a member for 9 full years
Topics: 7
Alias (AKA): Gill Bates
Extra Info: rwd
Return to Exterior
It is currently June 28th 2017, 10:03pm
Exterior Forum
Attached by: astrotardis
astrotardis
in Exterior
Date: Today
Time: 8:16pm
astrotardis
in Exterior
Date: Today
Time: 2:39am
Attached by: nosxjeep
nosxjeep
in Exterior
Comments: 24
Date: Jun 26 '17
Time: 4:09pm
astrotardis
in Exterior
Comments: 21
Date: Jun 26 '17
Time: 4:10am
astrotardis
in Exterior
Comments: 21
Date: Jun 25 '17
Time: 6:36pm
