'93 Sliding door repair
Postby Cooper24 [OP] » February 1st 2010, 4:27am
Unfortunately the rollers on the door wore out over the years and ended up busting the post that the door locks onto. It flops around, but I can get it to latch enough to hold it closed. I need to fix the door so I figured that the best thing to do is fix all the rollers first. Anyone know where I can get the replacement rollers for the door??? Also, any suggestions for fixing the post? I haven't started on it yet, but thinking I may need to weld it. Any help or suggestions appreciated.
'93 Astro EXT 250k
'93 BMW 525 235k
'79 Porsche 928 75k
'77 Fiat Spider 100k
'00 Ford F250 V10 124k
Cooper24
Years of Membership: Cooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full yearsCooper24 has been a member for 8 full years
Alias (AKA): Cooper24
Re: '93 Sliding door repair
Postby Astroboy303 » February 1st 2010, 4:42am
post some pics
thanks munken for the awsome avatar Image
Astroboy303
Years of Membership: Astroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full yearsAstroboy303 has been a member for 7 full years
Extra Info: ZZ4.CE
Postby Big_kid » February 1st 2010, 2:01pm
Are you talking about the strike that mounts on the door pillar, the one with the torx head? It's adjust able and should tighten back up. If not, replace it and the "nut plate" inside the pillar that holds it.
I'd look at a junk yard/dealer/rock auto.com for replacement rollers.
Firing on 7 Cylinders (L5)
Topics: 140
Images: 72
Extra Info: 2WD conversion
Postby Bertscova » February 1st 2010, 10:10pm
I just bought the only one on ebay about 1hr ago but here is a diagram and the part # is 15022100 its # 13 in the diagram You can buy them from this web site they are the ones that gave me the part # http://www.gmpartsdirect.com/
Can anyone here explain how to R+R this piece
Horsies sell cars Torque wins races
1990 2wd Astro Van
1990 5.7 TBI w/roller cam upgrade
1.6 roller tip rockers
700R4
Stock Distributor w/ Upgraded electronics
Bertscova
Years of Membership: Bertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full yearsBertscova has been a member for 8 full years
Topics: 54
Alias (AKA): Bert
Extra Info: TBI 5.7 Roller
Postby chevy57bert » February 1st 2010, 11:03pm
remove inner upholstery , remove all bolts, there also a bolt behind the taillight. (not in pic.)
get a piece of wood for under the sliding door ( it`s heavy)
pull out 15. repalce part 13. piece off cake..
ps thanks for the part number ( I need one)
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Topics: 68
Images: 68
Alias (AKA): Bertjuh
Year: 1992
Extra Info: Ext 4.3L rwd
Postby Bertscova » February 2nd 2010, 12:10am
That is what i thought. I was hoping that i didn't have to remove the interior panels. Thanks for the info
1990 2wd Astro Van
700R4
Bertscova
Topics: 54
Alias (AKA): Bert
Postby RydQlty » March 21st 2010, 7:02am
Bertscova wrote:That is what i thought. I was hoping that i didn't have to remove the interior panels. Thanks for the info
Just an FYI...
I replaced my Slider today, and did not have to remove any interior pieces. It took about 10 minutes.
Removed the sliding rear door latch far enought to remove the sliders pin. Before removing the pin, I placed a floor jack under the sliding door for support, then removed the pin. Pull the rear of the sliding door away from the body of the van, making sure its still secured nicely on the jack stands.
Then slid the slider down the track to the front and removed. Placed the new one back and reinstalled.
This was on a 1996 astro, and was amazingly easy to do.
RydQlty
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: RydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full yearsRydQlty has been a member for 8 full years
Alias (AKA): The Big Easy
Postby rev_les » March 21st 2010, 7:18am
thanks guys..... this should help a lot of people, myself included , repairing our sliders!!
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Gary » March 21st 2010, 7:54am
Just an FYI...
:goodpost:
Gary
Firing on 4 Cylinders (L3)
Years of Membership: Gary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full yearsGary has been a member for 9 full years
Topics: 136
Extra Info: high top
Return to Exterior
It is currently April 23rd 2017, 6:41pm
Exterior Forum
Attached by: 97cargocrawler
97cargocrawler
in Exterior
Comments: 14
Date: Apr 20 '17
Time: 4:31pm
ironhead79
in Exterior
Comments: 14
Date: Apr 20 '17
Time: 2:00am
noahsaark
in Exterior
Date: Apr 20 '17
Time: 12:03am
noahsaark
in Exterior
Date: Apr 19 '17
Time: 10:48pm
Attached by: akforceten
akforcetenakforceten is online!
in Exterior
Comments: 14
Date: Apr 19 '17
Time: 3:35pm
