paint code mystery
paint code mystery
Postby berdynumnum [OP] » July 11th 2010, 5:11am
I seem to have some oddball paint code for my van.....the sticker on the pass door is clearly a 528E....yet all of the local paint suppliers only list a 528F for this vehicle. Van is a 99 safari sl awd. Van still has its original paint but due to some clearcoat failure I have to respray a few panels and cannot find an exact match. I believe the color is called a dark bronze mist. The 528E and F appear to be different in that they have some different metallics. A shop I went to a few years ago ( no longer around anymore) to get spray paint put in cans for touch ups( bad idea by the way.....great for short term but just no long term durability) we ran into the same problem but they had a portable color chip chart....we took it to the van...they had several similar variations on the same chart and we were able to get an exact match. Unfortunately, all the local paint suppliers seem to have are the domestic and import colors color books but nothing like the color chart the "no longer around place did". They can mix a 528F but this is not an exact match or at least it is different enough as to be noticeable different. Beyond that they can't help me out.
Anyone have any ideas or will I be slowly be repainting the van panel by panel to 528F?
cheers and thanks
berdynumnum
Years of Membership: berdynumnum has been a member for 6 full yearsberdynumnum has been a member for 6 full yearsberdynumnum has been a member for 6 full yearsberdynumnum has been a member for 6 full yearsberdynumnum has been a member for 6 full yearsberdynumnum has been a member for 6 full years
Extra Info: 99 sl awd
  • Paint it Black
    by LaFlamaBlanca » October 27th 2016, 10:31pm in Exterior
    Last post by Astro Pop View the latest post
    October 29th 2016, 2:27am
  • OEM paint?
    by theFlyingDutchman » October 12th 2016, 6:58pm in Exterior
    Last post by theFlyingDutchman View the latest post
    October 13th 2016, 2:59am
    March 28th 2017, 8:39pm
Re: paint code mystery
Postby LEVE » July 11th 2010, 5:26am
Several automotive paint places and LAP stores will be able to shoot the paint with a gun that will tell them the make-up of the coloration. Check around... you'll find one that can do it locally.
LEVE
Years of Membership: LEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full yearsLEVE has been a member for 7 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Munken » July 11th 2010, 7:01am
Check this: http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=1999&make=Gm&model=Safari
Looks like there is no 528E.
I will check at work tomorrow and see if I can find it.
"Nothing is impossible, the impossible just takes a little longer"
Munken
Section Moderator
Section Moderator
Firing on 5 Cylinders (L2)
Years of Membership: Munken has been a member for 7 full yearsMunken has been a member for 7 full yearsMunken has been a member for 7 full yearsMunken has been a member for 7 full yearsMunken has been a member for 7 full yearsMunken has been a member for 7 full yearsMunken has been a member for 7 full years
Topics: 67
Alias (AKA): Munken the lunatic
Extra Info: LT 4.3L V6 RWD
Postby Munken » July 12th 2010, 4:37pm
I checked the Standox, Du Pont and PPG database of paint. And there is no 528E.... :think:
There are a 528F named "Dark Bronze mist". Standox have 3 variations of that color. Du Pont have only 1, PPG have 6.
I think it should be possible to get a good match with someone of the variations.
Or if you can find someone that can shoot the paint with a gun/camera.
Good Luck :thumbup:
Munken
Section Moderator
Section Moderator
Topics: 67
Postby astroturf » July 12th 2010, 11:19pm
Munken wrote:Check this: http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=1999&make=Gm&model=Safari
Great Link Munken
Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby eharston » January 5th 2011, 12:37pm
Old post, but FWIW, my 2000 Astro van has paint code 528E as well.
eharston
Years of Membership: eharston has been a member for 6 full yearseharston has been a member for 6 full yearseharston has been a member for 6 full yearseharston has been a member for 6 full yearseharston has been a member for 6 full yearseharston has been a member for 6 full years
Postby rev_les » January 5th 2011, 10:27pm
:think: .............and the plot thickens...... :lol:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Ripper » January 9th 2011, 5:23am
Any "decent" paint supplier should have a spectrophotometer and variant decks. If they don't, find one that does. Before I had my paint mixing machine, I used to need those all the time. My supplier would come to the shop and find the right color every time.
It sounds to me like your color is a variant of the usual color and that is your entire problem. I don't know why you'd have an E instead of the usual F, but if no one can find it in their color charts, it may have been a "special order" color or a limited edition.
Ripper
Years of Membership: Ripper has been a member for 6 full yearsRipper has been a member for 6 full yearsRipper has been a member for 6 full yearsRipper has been a member for 6 full yearsRipper has been a member for 6 full yearsRipper has been a member for 6 full years
Postby tank2 » August 28th 2013, 7:57pm
I know, old post, but I also have a 528e paint code. Did you resolve your issue?
tank2
Years of Membership: tank2 has been a member for 5 full yearstank2 has been a member for 5 full yearstank2 has been a member for 5 full yearstank2 has been a member for 5 full yearstank2 has been a member for 5 full years
Alias (AKA): tank2
Year: 1999
Extra Info: SLT
Return to Exterior
It is currently March 28th 2017, 8:39pm
Exterior Forum
Attached by: chevymaher
in Exterior
Comments: 13
Date: Mar 26 '17
Time: 3:30pm
Attached by: codydaniels
codydaniels
in Exterior
Date: Mar 23 '17
Time: 5:07pm
Attached by: 9T8_Safari_Guy
9T8_Safari_Guy
in Exterior
Date: Mar 21 '17
Time: 12:44am
K/4
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 10:55pm
in Exterior
Comments: 31
Date: Mar 16 '17
Time: 2:57pm
Users browsing this forum: Baiduspider [Spider] and 3 guests
