rear door wont open...HELP
Postby txpatriot [OP] » March 8th 2011, 7:19pm
99 astro with three doors on back
only one side will pop open
how can i get the door open
SSGT. Rogers
Texas State Guard
1st Sergeant Co. A
3rd Battalion 8th Regiment
txpatriot
Years of Membership: txpatriot has been a member for 6 full yearstxpatriot has been a member for 6 full yearstxpatriot has been a member for 6 full yearstxpatriot has been a member for 6 full yearstxpatriot has been a member for 6 full yearstxpatriot has been a member for 6 full years
Topics: 7
Extra Info: awd
  • any trick to removing rear door panels
    by andy_b » December 18th 2016, 7:21pm in Interior
    December 21st 2016, 6:04am
  • fabrication: inside rear cargo barn door handle pics
    by AstroNuts » January 23rd 2017, 1:17am in Interior
    January 31st 2017, 11:41pm
    33
    February 26th 2017, 1:59am
Re: rear door wont open...HELP
Postby RECox286 » March 9th 2011, 2:01am
You should be able to get the center handle and trim cover off the upper door which will give you access to the pull rods that go to the side locks. Good possibility that the rod has come off the release lever in the center. Reach in and pull the rod by hand.
Good luck
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby txpatriot [OP] » March 9th 2011, 3:47am
RECox286 wrote:You should be able to get the center handle and trim cover off the upper door which will give you access to the pull rods that go to the side locks. Good possibility that the rod has come off the release lever in the center. Reach in and pull the rod by hand.
Good luck
Bob
the handle on the inside?
SSGT. Rogers
Texas State Guard
1st Sergeant Co. A
txpatriot
Topics: 7
Extra Info: awd
Postby great mech creature » March 9th 2011, 1:03pm
These 2 replys are correct. One additional note... You must have access this way to also change any rear tail lights that may be out. Might want to go ahead and replace the bulbs at this time also .. The rods are attached at the center to a metal toggle and on each end are white center plastic grommmets... Theses go bad over time and will need replacing Where are the old Jesus clips of the old days? doors will fuction again.
great mech creature
Years of Membership: great mech creature has been a member for 5 full yearsgreat mech creature has been a member for 5 full yearsgreat mech creature has been a member for 5 full yearsgreat mech creature has been a member for 5 full yearsgreat mech creature has been a member for 5 full years
Extra Info: 4.3 v6 AWd
Postby bobb789 » March 10th 2011, 7:02am
If this complaint concerns the "barn doors" check to see if the rear bumper has been hit. This causes the vinyl strip on the bumper to curl slightly up and catch the bottom lip of the barn door. Try sliding a thin piece of plastic along the bottom of the door and pull at the same time. ....Worked for me.
bobb789
Years of Membership: bobb789 has been a member for 5 full yearsbobb789 has been a member for 5 full yearsbobb789 has been a member for 5 full yearsbobb789 has been a member for 5 full yearsbobb789 has been a member for 5 full years
Alias (AKA): bobb789
Extra Info: 4.3l RWD
Postby gillbates » March 11th 2011, 1:50am
There's a handle on the inside of the stuck door. It has two plastic access covers, one on each end. Using a small screw driver pop them off. Be careful as they are easy to break. The tabs are on the top and bottom so if you slide your small screwdriver in from the side you can push up on the top and then pull them off. Under the covers are 10mm bolts, remove them and the handle and a plastic plate will come off. Under there you will find a 3-4 inch slot that's maybe 1/2" high. There's a silver rod that comes across that slot from the left (drivers) side of the van. At the end it turns 90 degrees towards the rear of the van. Near that turn you will see a metal thing with a plastic sleeve in it that has a hole in it just big enough for the metal rod. Slip the rod into the plastic sleeve and you will be able to open your door. Now it just might stay there if you make a point of not slamming the back door but if you have kids, like me, odds are it's going to pop out again. Use some wire to hold it in place if you don't want to do it again.
gillbates
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: gillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full yearsgillbates has been a member for 8 full years
Topics: 7
Alias (AKA): Gill Bates
Extra Info: rwd
Return to Interior
It is currently February 26th 2017, 1:59am
Interior Forum
Attached by: nosxjeep
nosxjeep
in Interior
Date: Feb 23 '17
Time: 10:24pm
nosxjeep
in Interior
Date: Feb 23 '17
Time: 8:30pm
Attached by: chopsaw209
chopsaw209
in Interior
Comments: 237
Date: Feb 17 '17
Time: 5:20pm
chopsaw209
in Interior
Comments: 237
Date: Feb 14 '17
Time: 5:48am
chopsaw209
in Interior
Comments: 237
Date: Feb 12 '17
Time: 4:55am
