03 astro climate control bulbs
Postby 1lowcab [OP] » February 6th 2017, 12:33am
Just seeing if anybody knows the bulb type/size for the climate control panel offhand, also how many are in there.
Pic pulled from the interwebs so you know what I'm talking about.
I don't feel like taking it apart and checking as it's cold out, LOL!
2003 Astro AWD G80
1lowcab
Topics: 25
Images: 101
Year: 2003
Extra Info: AWD G80
  • How to remove seatbelts from 98 Astro?
    by Astrodawn » February 28th 2017, 5:06pm in Interior
    Last post by Wimpazz View the latest post
    March 4th 2017, 2:33am
  • 87 Astro Cluster Swap
    by shinguki » January 3rd 2017, 6:41am in Interior
    Last post by shinguki View the latest post
    January 3rd 2017, 10:29pm
    7
    47
    March 28th 2017, 9:08am
Re: 03 astro climate control bulbs
Postby Lumpy » February 6th 2017, 6:47pm
194 style bayonet base bulbs are what's in my 89. Same thing that's in the rear side marker lamps and lic plate illumination. They replace nicely with 194 incandescents (get the kind WITH the plastic base installed on the lamp) or with LED replacements. The LEDs don't dim quite as smoothly as the incandescents but that's not a problem with me.
I think there were something like four lamps in my main speedo/gauge cluster, 1 or 2 in the HVAC area. But mine is very different than yours, I'd think.
Websites like Sylvania or other bulb makers have cross ref charts for vehicles that will tell you the part numbers. The bulbs are super inexpensive. So buying a dozen is just a couple dollars. Don't have to worry much about buying the exact number.
Year: 1989
Postby 1lowcab [OP] » February 7th 2017, 1:30am
Well, it was nice and warm today so I pulled apart the dash to check the hvac bulbs.
The 194's would be too big for an 03, on mine I have 2 bulbs, 1 is marked FWG203 and is 6mm wide x 13mm long. The other bulb has no markings and is 5mm wide x 7mm long.
hvac bulbs
Here is the single bulb in the headlight switch, no markings, 5mm wide x 7mm long
And here is the instrument bulbs with its T10 ice blue LED replacement.
All lit up
Now I have to try and find leds to replace the hvac and headlight switch bulbs.
2003 Astro AWD G80
1lowcab
Topics: 25
Images: 101
Year: 2003
Extra Info: AWD G80
Postby Lumpy » February 7th 2017, 1:40am
Here's a cross reference site -
http://www.bulbs.com/Automotive_Lighting/results.aspx
SBL LEDs also has a pretty good cross ref.
Year: 1989
Postby 1lowcab [OP] » February 7th 2017, 2:25am
Awesome, thanks for the info lump!
On my way to full ice blue dash lights.
2003 Astro AWD G80
1lowcab
Topics: 25
Images: 101
Year: 2003
Extra Info: AWD G80
Postby Birdshake » February 7th 2017, 2:47am
They're a neo wedge led light. Either T5 4 or 3 I can't quite remember the sizes from when I ordered them. The ones off eBay have a shorter base than the stock lights so I pulled the led's out of the bases from eBay and soldered new leads into the chips and put them in the stock bulb base.
They were similar to these but the ones I got were SMD
http://www.ebay.ca/ulk/itm/201787774902
Birdshake
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Birdshake has been a member for 5 full yearsBirdshake has been a member for 5 full yearsBirdshake has been a member for 5 full yearsBirdshake has been a member for 5 full yearsBirdshake has been a member for 5 full years
Images: 4
Year: 2005
Extra Info: 4.3 AWD CARGO G80
Return to Interior
It is currently March 28th 2017, 9:08am
Interior Forum
jakegnaw
in Interior
Comments: 242
Date: Mar 18 '17
Time: 4:59am
Attached by: nosxjeep
nosxjeep
in Interior
Comments: 24
Date: Feb 23 '17
Time: 10:24pm
nosxjeep
in Interior
Comments: 24
Date: Feb 23 '17
Time: 8:30pm
Attached by: chopsaw209
chopsaw209
in Interior
Comments: 242
Date: Feb 17 '17
Time: 5:20pm
chopsaw209
in Interior
Comments: 242
Date: Feb 14 '17
Time: 5:48am
Users browsing this forum: Yahoo [Bot] and 4 guests
