Airbag Light is on: Why?
Postby longyard [OP] » May 17th 2011, 5:31am
My airbag light came on today for the first time. It occasionally goes off, but will soon come on again when driving. Any ideas? Thanks!
longyard
Years of Membership: longyard has been a member for 6 full yearslongyard has been a member for 6 full yearslongyard has been a member for 6 full yearslongyard has been a member for 6 full yearslongyard has been a member for 6 full yearslongyard has been a member for 6 full years
Topics: 35
  • Check engine light query
    by eddbuck2017 » June 13th 2017, 1:56am in Interior
    Last post by eddbuck2017 View the latest post
    June 13th 2017, 2:07am
    94
    June 25th 2017, 6:19am
Re: Airbag Light is on: Why?
Postby rev_les » May 19th 2011, 2:20am
Check the wiring and connectors to the airbags and SRS module and make sure a connector didn't get knocked loose or one of the wires got chafed or broken. If you have a friend with a Tech 2, it might be a good time to pull a favor! I don't know of any inexpensive scanners that will read SRS codes.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby longyard [OP] » May 19th 2011, 5:22pm
rev_les wrote:Check the wiring and connectors to the airbags and SRS module and make sure a connector didn't get knocked loose or one of the wires got chafed or broken. If you have a friend with a Tech 2, it might be a good time to pull a favor! I don't know of any inexpensive scanners that will read SRS codes.
Thanks for the suggestion. I'm wondering if some moisture got into the SRS module connection while I've been doing a major "refreshing" of many components.
longyard
Topics: 35
Postby rev_les » May 24th 2011, 9:04pm
It's possible moisture could have gotten in one . If you've been running wire under the carpet or cutting anywhere near the harnesses or the carpet, I'd look there too. Checking for airbag lights is a daily ritual for me, lol...we reupholster new cars with leather, and occasionally ya knock a plug loose or one doesn't reconnect completely. You'd be amazed at how elaborate the SRS system is on these new vehicles....weight sensors in the seat tracks,passenger sensors ( and kiddy seat sensors) in the passenger seat, some of these damned cars have rear airbags now too, aside from the "curtain" airbags..........pretty soon it'll be like "Demolition Man" where it just instantly fills the car up with foam to retain you, lol.
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby Boazmojica » May 24th 2012, 2:41pm
I am having the same issue with my Astro, airbag light. Can you explain to me where the SRS sensor is and when you say air bags, how do I get to them? Also the wiring harness that was mentioned in the latter post. Thanks
Boazmojica
Years of Membership: Boazmojica has been a member for 5 full yearsBoazmojica has been a member for 5 full yearsBoazmojica has been a member for 5 full yearsBoazmojica has been a member for 5 full yearsBoazmojica has been a member for 5 full years
Alias (AKA): Boaz
Extra Info: LT 4.3L V6 RWD
Return to Interior
It is currently June 25th 2017, 6:19am
Interior Forum
Attached by: Jasekcco
Jasekcco
in Interior
Comments: 0
Date: Jun 23 '17
Time: 1:39am
dennis7815
in Interior
Date: Jun 11 '17
Time: 9:23pm
Attached by: 1lowcab
1lowcab
in Interior
Comments: 19
Date: Jun 01 '17
Time: 11:34pm
1lowcab
in Interior
Comments: 19
Date: Jun 01 '17
Time: 11:29pm
1lowcab
in Interior
Comments: 19
Date: Jun 01 '17
Time: 11:04pm
