Help with noisy speedo cable
Postby jsmitherson [OP] » February 24th 2012, 4:55am
Good evening all, been lurking for a bit and finally registered.
Quick question - using some guidance from other posts in this forum, I was able to replace my headlight switch successfully. I wanted to lubricate the gas gauge and oil the speedo cable while I was in there (speedo is getting increasingly noisy lately) but I just wasn't able to get the IP out far enough to even see the back, let alone get a hand back there to disconnect the cable. Any tips or pictures of where the cable's connected? Should I just go ahead and yank on the IP a little more? I was getting about an inch of play at most.
Also, I've heard not to use wd-40 for the speedo cable - what should I use? Same for the gas gauge (sticks, even with vehicle off).
Thanks!
jsmitherson
Years of Membership: jsmitherson has been a member for 5 full yearsjsmitherson has been a member for 5 full yearsjsmitherson has been a member for 5 full yearsjsmitherson has been a member for 5 full yearsjsmitherson has been a member for 5 full years
Year: 1986
Extra Info: motorhome
Re: Help with noisy speedo cable
Postby Phantom » February 24th 2012, 5:14am
The older vans with speedo cable have a clip you need to pres down on while pulling the cable off from the rear side , Gen2 speedo you can pull from the front , but the older Gen1 you have to reach behind the dash and pull cable from the backside, you can lubricate the speedo cable with graphite powder , you'll need to disconnect it from the transmission as well
here how someone lubed thier gas gauge
viewtopic.php?f=76&t=13422&p=143208&hilit=fuel+gauge#p143208
Phantom
Firing on 7 Cylinders (L4)
Postby jsmitherson [OP] » February 24th 2012, 9:25am
I guess I just don't know what I'm looking for under there. Are you saying that with the trim pieces off I should be able to reach up and disconnect the speedo cable without moving the IP forward first?
Why would I need to remove the cable from the transmission in order to lubricate it? Isn't the noise pretty much just on the dash end?
jsmitherson
Year: 1986
Postby Jasen » February 24th 2012, 12:14pm
You should pull the cable out of the casing and lube the whole thing. Graphite has been mentioned but I've never used it, I just use lithium grease.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby RECox286 » February 24th 2012, 6:34pm
Graphite is the recommended lubricant, anything else will gel and collect dirt, making it worse. You may want to think about
pulling the cable and replacing it with a new one in the old sheath. They do break occasionally. Sometimes if you are pulling
on the I/P, the "clip" will not release easily, in which case you will want to push on the I/P while trying to work the clip. Not
the easiest, because of the lack of hand room behind the panel, but doable.
Not sure about what the problem is with the gas gage. It is an electrical device, and should not need lubrication. If you mean
that the needle is sticking and you have to use repair proceedure number one, then just give it a tap now and again. Is the
needle bent and catching on the scale ?
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby jsmitherson [OP] » April 12th 2012, 12:40am
How often is the cluster itself the culprit? I'm still getting noise after lubricating the cable.
jsmitherson
Year: 1986
Return to Interior
It is currently March 28th 2017, 8:40pm
Interior Forum
jakegnaw
in Interior
Comments: 243
Date: Mar 18 '17
Time: 4:59am
Attached by: nosxjeep
nosxjeep
in Interior
Comments: 24
Date: Feb 23 '17
Time: 10:24pm
nosxjeep
in Interior
Comments: 24
Date: Feb 23 '17
Time: 8:30pm
Attached by: chopsaw209
chopsaw209
in Interior
Comments: 243
Date: Feb 17 '17
Time: 5:20pm
chopsaw209
in Interior
Comments: 243
Date: Feb 14 '17
Time: 5:48am
