Carpet-to dye it or replace it? New Pictures added
Postby crusader1xxx [OP] » September 1st 2013, 2:46am
So I pulled all the carpet today out of the van. Dumbass me left the windows open last night and we had a storm so the inside was soaked...I pulled it all out and yup, soaking wet all the way though to the underlay.
While it is out and drying, i was hoping to clean it up a bit and have heard that you can spray paint it with the same type of paint used on trim...is this true? I also heard about dying it but have no experience with that, how does that work?
Also some of the underlay was in just horrible condition, is there a place to get replacement?... is there a better alternative to what the factory uses?
Any information would be appreciated.. :thumbup:
Last edited by crusader1xxx on September 1st 2013, 8:44pm, edited 1 time in total.
crusader1xxx
Years of Membership: crusader1xxx has been a member for 3 full yearscrusader1xxx has been a member for 3 full yearscrusader1xxx has been a member for 3 full years
Topics: 25
Images: 16
Alias (AKA): Andy
Year: 1994
Extra Info: RwD
  • Interior dye
    by nonhog » November 17th 2016, 9:05pm in Interior
    Last post by nonhog View the latest post
    November 22nd 2016, 3:20am
  • Replaced carpet
    by dantheman » August 29th 2016, 3:37am in Interior
    Last post by dantheman View the latest post
    September 13th 2016, 3:05am
    February 24th 2017, 9:01am
Re: Carpet-to dye it or replace it?
Postby gavio » September 1st 2013, 3:05am
Before gearing up to dye it, try scrubbing the stains with a mixture of about 1 tsp laundry soap and 2 tablespoons of vinegar in 16 ounce jar of warm water - use a stiff brush and you may be amazed at how much will come out (I usually am)..... Then if the stains persist, move on to dyeing....
Some of the products made for dyeing vinyl will work on carpet, other's won't.....Also, some products made for fabric upholstery will work on carpet....I haven't done any for a long time, so I'm not current on what brands are the best now..... If you google up carpet dye, you'll find a few choices - be sure to read the reviews because some of them aren't very good.....
Just using a plastic paint won't do much good over the long term as it will just wear off the surface.....
Problem will be that the carpet in our vans is light colored, and it's hardest to dye a light color over a dark stain without whatever made the satin bleeding through the finished product.... It's easier to dye a darker color, but then you have to do the whole carpet, which is a rather larger project..... On the other hand, if your problem is just fading, then re-dying may be just the ticket....
The padding is usually a jute product (though I must admit I haven't looked under the carpet of my astro), but it's denser than the kind used in houses.... probably best to look for some in your local boneyard - most american vans, trucks and cars use the same material, so chances are good you can score some.... Otherwise, you can get it from companies that sell automotive carpeting - again google is your friend, there are a lot of suppliers out there.....
Good luck
gavio
Firing on 8 Cylinders (L1)
Years of Membership: gavio has been a member for 3 full yearsgavio has been a member for 3 full yearsgavio has been a member for 3 full years
Topics: 43
Year: 2004
Postby Jasen » September 1st 2013, 4:06am
I've used cases and cases of the commercial grade aerosol and shampoo dye's with good result's. the shampoo dye's are good for light discoloring and sun fade, aerosol's are better for more extreme cases. as far as longevity, it all depends on how much your in the rig, dirt, sand, mud etc. the key is a clean carpet, if you have a carpet shampooer great, if not do it with a scrub brush or take it to the car wash and have at it with the pressure washer.
what ever you use, make sure it's bone dry before using an aerosol dye and most importantly, before re installing or you'll end up with slimy windows this winter and a nice mildew smell followed by foliage.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby crusader1xxx [OP] » September 1st 2013, 4:28am
That is why I pulled it today, to dry it out. The carpet is original, and like a 20 yr old carpet (wait that didn't sound right) :confused: :rofl:
it is actually in decent shape with most of the wear and tear on the front section. I would love to replace it with new but I need the color to be right (as the wheel wells etc are in perfect shape).
Tomorrow I am going to pull the backing off (which is kind of rotten anyway) and give it a good cleaning.
For the backing is it just a standard carpet padding or some kind of special automotive stuff?? :shrug:
crusader1xxx
Topics: 25
Images: 16
Alias (AKA): Andy
Year: 1994
Extra Info: RwD
Postby Zwett » September 1st 2013, 5:04am
its probably synthetic felt home depot and lows has carried this in the past if they dont have it find a flooring supplier, for flooring installers, they should have some in quantity.
Zwett
Years of Membership: Zwett has been a member for 3 full yearsZwett has been a member for 3 full yearsZwett has been a member for 3 full years
Alias (AKA): Zwett
Year: 1999
Extra Info: 4.3 v6 RWD
Postby Jasen » September 1st 2013, 5:58am
should be chopped cotton, a mish-mash of fabric chunk's and peaces. it offers sound deadening, better then house foam carpet padding, and holds up well.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Re: Carpet-to dye it or replace it? Now with pictures
Postby crusader1xxx [OP] » September 1st 2013, 8:43pm
So here are a few pictures of the backing of the carpet...as you can see it is very wet in places, the drives side was ruined...
A few pictures of the inside, not bad for a 20 yr old van. only real rust was drives side, found a nice little hole there too... :doh:
crusader1xxx
Topics: 25
Images: 16
Alias (AKA): Andy
Year: 1994
Extra Info: RwD
Re: Carpet-to dye it or replace it? New Pictures added
Postby Jasen » September 1st 2013, 11:12pm
wire wheel up that rust and slather some rust convert on it. do the same to the bottom side if need be.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Return to Interior
It is currently February 24th 2017, 9:01am
Interior Forum
Attached by: nosxjeep
nosxjeep
in Interior
Comments: 13
Time: 10:24pm
nosxjeep
in Interior
Comments: 13
Time: 8:30pm
Attached by: chopsaw209
chopsaw209
in Interior
Comments: 237
Date: Feb 17 '17
Time: 5:20pm
chopsaw209
in Interior
Comments: 237
Date: Feb 14 '17
Time: 5:48am
chopsaw209
in Interior
Comments: 237
Date: Feb 12 '17
Time: 4:55am
