97 instrument cluster dead
Postby 97safarinodash [OP] » June 3rd 2009, 7:11pm
At first all gauges would intermittently shut off for just a brief second, continued to get worse until now they wont work at all. I removed the cluster and found some cold soldered joints. I re-soldered them but still nothing. The dash lights work but no gauges or turn signals. I bought a used cluster on e-bay and installed but it doesn't work either. What would you suggest trying next? Any help is much appreciated.
97safarinodash
Years of Membership: 97safarinodash has been a member for 3 full years97safarinodash has been a member for 3 full years97safarinodash has been a member for 3 full years
Re: 97 instrument cluster dead
Postby fungus2k » June 3rd 2009, 10:46pm
could be the computer
fungus2k
Years of Membership: fungus2k has been a member for 4 full yearsfungus2k has been a member for 4 full yearsfungus2k has been a member for 4 full yearsfungus2k has been a member for 4 full years
Postby Leeann_93 » June 4th 2009, 4:11am
Also could be a bad ground. Look around at the wiring behind the cluster.
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby ghostrider1061 » June 4th 2009, 4:19am
this may sound silly but my astro has a fuse for the inst. cluster. have you checked that. sometimes the best repairs are the simple ones. whenever i have a problem that i think is elec. thats the first place i head to.
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 4 full yearsghostrider1061 has been a member for 4 full yearsghostrider1061 has been a member for 4 full yearsghostrider1061 has been a member for 4 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby astro355 » June 4th 2009, 3:58pm
Leeann_93 wrote:Also could be a bad ground. Look around at the wiring behind the cluster.
:goodpost:
Intermittent electrical problems are usually wiring problems. Since all of the gauges malfunctioned at the same time, I would look for a ground or other connector in common.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby 97safarinodash [OP] » June 4th 2009, 9:54pm
I was thinking ground, il look around, do you know what fuse is for the cluster?Thanks for the replies!
97safarinodash
Return to Interior
It is currently May 19th 2013, 5:36am
Interior Forum
Moderator: rev_les
Attached by: icebrrg3rd
icebrrg3rd
in Interior
Date: May 03 '13
Time: 1:33pm
Attached by: SilverBullet1997
SilverBullet1997
in Interior
Comments: 9
Date: May 02 '13
Time: 2:36am
SilverBullet1997
in Interior
Comments: 9
Date: Apr 30 '13
Time: 3:57pm
SilverBullet1997
in Interior
Comments: 9
Date: Apr 29 '13
Time: 9:18pm
SilverBullet1997
in Interior
Comments: 9
Date: Apr 26 '13
Time: 4:08pm
