Better motor cover cupholders?
Postby BobM [OP] » August 10th 2009, 6:10am
Does anyone have a good idea about converting the motorcover cupholders into something that will actually HOLD a cup? :banghead:
Our '97 only has the factory plastic cupholders and they are terrible! I have already put a post on the classified "wanteds" list but no joy there. I also answered a coupla of adds for parts vans but, still no joy.
If i weren't so terrible at woodworking, I'd try to make something myself! :roll:
$100 Astro van SOLD! ('89 shorty)
'97 Mark III van with W engine
K&N drop-in filter
Gibson cat-back
'84 vette (pampered of course)
'03 Silverado
'99 tahoe
BobM
Years of Membership: BobM has been a member for 3 full yearsBobM has been a member for 3 full yearsBobM has been a member for 3 full years
Topics: 22
Extra Info: Mark III
  • OEM seat cover/foam sources? Leads/Links??
    by swharris » April 11th 2013, 6:02pm in Interior
    Last post by swharris View the latest post
    May 20th 2013, 8:41pm
    7
    96
    May 24th 2013, 8:44pm
Re: Better motor cover cupholders?
Postby Matrixx » August 10th 2009, 7:16am
Hi BobM
Plastic? hmm, you should have a rubber insert in each Plastic holder for the cups to sit in. I know the McDonalds and Tim Hortons cups fit nicely in those holders,hehe.
As for anything larger than that in cup sizes, what people usually do is go online and by a Center Console to fit in between the seats with the larger cup holders their. Their isn't anymore room up at the doghouse to make anything bigger. Something to think about.:)
Matrixx
Years of Membership: Matrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full yearsMatrixx has been a member for 5 full years
Postby ihatemybike » August 10th 2009, 1:14pm
Rubber inserts FTW! Whenever I get another '96 or newer Astro if they are missing it's usually the second purchase I make. The first purchase is fresh keys cut by the VIN from the dealer.
Aaron
1999 Astro (Green - Daily Driver) - 2WD, 4.3L, 3.23, 220k+ miles, FE2 steering
Prev Astros:97, 00, 94, 87, 86
ihatemybike
Firing on 5 Cylinders (L2)
Years of Membership: ihatemybike has been a member for 4 full yearsihatemybike has been a member for 4 full yearsihatemybike has been a member for 4 full yearsihatemybike has been a member for 4 full years
Topics: 62
Postby castle_Rock » August 12th 2009, 2:25am
if you don't want to spend alot/any money on a console - you can use a cardboard box with the lid, and buy a cupholder with organizer from walmart for under $20, worked for me until I get around to getting an actual center console.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 3 full yearscastle_Rock has been a member for 3 full yearscastle_Rock has been a member for 3 full years
Topics: 35
Postby astro355 » August 12th 2009, 3:37am
ihatemybike wrote:Rubber inserts FTW! Whenever I get another '96 or newer Astro if they are missing it's usually the second purchase I make. The first purchase is fresh keys cut by the VIN from the dealer.
Quoted for truth.
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full yearsastro355 has been a member for 4 full years
Year: 1989
Extra Info: 355 V8 700R4
Postby BobM [OP] » August 24th 2009, 3:49am
Well how about using 3" PVC pipe? I had an old PVC fitting ( 3" NPT to 3" female PVC) The threaded 3" NPT end fits down into the cup holder and the 3" female PVC end extends up enough to hold both 12 oz cans and 20 oz plastic bottles. However, when I attempted to buy another fitting at Lowes, I found that not all 3" fittings are the same. When I tried a 20 oz plastic bottle in the new fitting, it would not fit. I will have to look for the original fitting or use a file/dremel tool to relieve the opening. A little grey paint and some felt......?
K&N drop-in filter
Gibson cat-back
'03 Silverado
'99 tahoe
BobM
Topics: 22
Postby Matrixx » August 24th 2009, 8:42am
That's not a bad idea BobM. As long as it works, that's the main thing.:)
Matrixx
Postby castle_Rock » August 25th 2009, 5:56am
Well at least his cupholders aren't in a awkward position under the stinkin dash, my 94 is almost as stupid as they come.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby 'cudapaul » August 25th 2009, 6:10am
That's because it was made before 7-1 introduced the "BIG GULP!"
'cudapaul
Years of Membership: 'cudapaul has been a member for 5 full years'cudapaul has been a member for 5 full years'cudapaul has been a member for 5 full years'cudapaul has been a member for 5 full years'cudapaul has been a member for 5 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby castle_Rock » August 25th 2009, 6:45am
'cudapaul wrote:That's because it was made before 7-1 introduced the "BIG GULP!"
Yeah, thats true :D
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby Coach » August 31st 2009, 4:14am
Funny / odd, I was going to post a question regarding cup holders too. I have similar but slightly different problem. I have a 1995 GMC Safari and my doghouse doesn't extend far enough from the dash so that I can't place a bottle water or any tall cup. Does anyone have an idea of what to do, or, can anyone post a photo of the consol?
Thanks for allowing me to ask a similar question and I hope you don't consider this a "threadjack" because I certainly don't intend it to be that way.
Coach
Coach
Years of Membership: Coach has been a member for 4 full yearsCoach has been a member for 4 full yearsCoach has been a member for 4 full yearsCoach has been a member for 4 full years
Topics: 5
Postby BobM [OP] » August 31st 2009, 4:58am
Coach wrote:Funny / odd, I was going to post a question regarding cup holders too. I have similar but slightly different problem. I have a 1995 GMC Safari and my doghouse doesn't extend far enough from the dash so that I can't place a bottle water or any tall cup. Does anyone have an idea of what to do, or, can anyone post a photo of the consol?
Coach
Hey, no problem. We used self sticking felt in the bottom of the original cupholder and along the side to stop unwanted movement and can rattle. We were in a hurry (note the black felt showing around the left cupholder). There is also ducktape wrapped around the threads for the same purpose. We tried them out on a trip to Ky yesterday and they worked fine. They are a little tall for 12 oz cans, but I usually go for BIG drinks anyway! ;) Here is how my first attempt came out:
and:
K&N drop-in filter
Gibson cat-back
'03 Silverado
'99 tahoe
BobM
Topics: 22
Postby ihatemybike » August 31st 2009, 1:16pm
1995 and older van really have pretty worthless cup holders for anything over 12oz. For these van the best thing I've found is to use a floor console from Walmart or the like. The cup holders are adjustable, they hold the drinks nicely, and you get an extra cubby for your crap.
Aaron
ihatemybike
Topics: 62
Postby tommckay » August 31st 2009, 6:46pm
The doghouse pictured is of a newer van, the '95s cupholders are tucked under the radio a bit. Anything larger than a Medium McDonalds cup or 12oz can won't fit.
ihatemybike has the best solution for the 95 & others like it.
Why do it if it ain't fun?
95 Astro Cargo (for winter and RC hauling)
90 Honda Goldwing (Ridden as much as possible)
07 Kia Rondo (Wife's car)
tommckay
Years of Membership: tommckay has been a member for 3 full yearstommckay has been a member for 3 full yearstommckay has been a member for 3 full years
Topics: 18
Year: 1995
Extra Info: 4.3 RWD Cargo
Postby Coach » September 1st 2009, 1:48am
Yes, I have the 95 and the cup holder is indeed worthless for anything over 12 oz. Thank you for the Walmart floor console idea.
Coach
Coach
Topics: 5
Return to Interior
It is currently May 24th 2013, 8:44pm
Interior Forum
Moderator: rev_les
Attached by: SilverBullet1997
SilverBullet1997
in Interior
Comments: 19
Time: 3:58pm
Attached by: Starrshine
Starrshine
in Interior
Date: May 22 '13
Time: 1:52am
Attached by: TaxiVan
TaxiVan
in Interior
Comments: 19
Date: May 21 '13
Time: 10:20pm
Starrshine
in Interior
Date: May 21 '13
Time: 4:30pm
Attached by: icebrrg3rd
icebrrg3rd
in Interior
Date: May 03 '13
Time: 1:33pm
