i'm going to build a center console
Postby 95-1ton [OP] » May 14th 2010, 1:32pm
i've been working with an idea in my head to make this console... although i have an oak one from a junkyard van, it isn't long enough, it's a little too tall, and it won't hold my tv...
so i decided that i'm going to build this thing out of some 7/16" plywood i have in my basement already, then throw some resin and possibly 'glass mat on it, and cover it in some fabric... it'll have a hinged, padded arm rest between the seats so it can hold things; it will hold the tv and i'm going to put a little drawer under it to hold some DVDs; and the best thing i can think of - it'll be long enough to reach the dashboard, and get molded in... i'll be putting wider, deeper cup holders in it and a little storage compartment next to them... plus lights and stuff in there... i started marking out my plywood yesterday until the mail came and brought my new fuel pump - then i went outside and stripped the floor and sides of the van to get ready to cut a hole...!
pic of my center console idea:
i'll take some pics later of the bare walls...
2000 AWD Astro... GU6 3.42 gears, Cadet Blue Met... Blue on Blue - and I hate Blue...! slowly getting a Gray interior...
95-1ton
Fueling (Full tank)
Fueling (Full tank)
Years of Membership: 95-1ton has been a member for 3 full years95-1ton has been a member for 3 full years95-1ton has been a member for 3 full years
Topics: 10
Alias (AKA): Ryan
Extra Info: LS 4.3 AWD
  • 1997 center console item identify..
    by daedaestoy » February 11th 2013, 5:27am in Interior
    Last post by chevymaherchevymaher is online! View the latest post
    March 2nd 2013, 1:41pm
    37
    May 25th 2013, 7:32am
Re: i'm going to build a center console
Postby astroturf » May 14th 2010, 2:40pm
Console idea good. Cutting a hole in van floor bad.
astroturf
Years of Membership: astroturf has been a member for 3 full yearsastroturf has been a member for 3 full yearsastroturf has been a member for 3 full years
Topics: 112
Extra Info: 2wd Passenger
Postby 95-1ton [OP] » May 14th 2010, 3:43pm
i'm cutting the hole to replace my fuel sending unit... i don't trust the lines or straps to work with me, so i'm going the only other way i can think of... i'm going to the junkyard before i do this to do a ton of measuring, and while i'm there i'm going to put a tank back into a van to make some cuts before i do it to mine... i'm also going to take a big chunk of floor out of one to put back into mine...
95-1ton
Fueling (Full tank)
Fueling (Full tank)
Topics: 10
Alias (AKA): Ryan
Postby astroturf » May 14th 2010, 4:32pm
Ah... OK
astroturf
Topics: 112
Postby chevy57bert » May 14th 2010, 4:42pm
95-1ton wrote:i'm cutting the hole to replace my fuel sending unit... i don't trust the lines or straps to work with me, so i'm going the only other way i can think of... i'm going to the junkyard before i do this to do a ton of measuring, and while i'm there i'm going to put a tank back into a van to make some cuts before i do it to mine... i'm also going to take a big chunk of floor out of one to put back into mine...
look at this viewtopic.php?f=27&t=2934&p=19323&hilit=fuel+tank+drop#p19323
chevy57bert
Section Moderator
Section Moderator
Years of Membership: chevy57bert has been a member for 3 full yearschevy57bert has been a member for 3 full yearschevy57bert has been a member for 3 full years
Topics: 66
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby LEVE » May 14th 2010, 4:47pm
And how will you make it for easy access to remove the doghouse? That sure seems like a recipe for regret . :doh:
LEVE
Years of Membership: LEVE has been a member for 3 full yearsLEVE has been a member for 3 full yearsLEVE has been a member for 3 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Big_kid » May 14th 2010, 11:41pm
Don't forget ventilation and a cooling fan if you want that TV to last more than one DVD.
Firing on 3 Cylinders (L4)
Years of Membership: Big_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full yearsBig_kid has been a member for 4 full years
Topics: 66
Images: 39
Extra Info: 2WD conversion
Postby Jasen » May 15th 2010, 3:36am
Nice design.
We'll be waiting for the photo rich build thread :D
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Postby 95-1ton [OP] » May 15th 2010, 12:43pm
my plan is to use another j/y 'glovebox' and remove the hinged part, then molding it in to the rest of what's left... i've definitely considered making this removable for access to the dog house... like i said, i've already got an oak console, which is heavy as hell, so i have to remove that every time i want to access the dog house... i'm not sure if anyone's following my 'molding it in' deal, but when i get closer (i've got most of it rough cut out now) i'll take more pics...
i thought about the tv overheating and figure i will leave space behind it ennough to put a smaller fan or 2... the tv will stick out a bit in the back, and it will have room to 'breathe' i believe...
chevy57bert - that's an awesome link and i appreciate it very much...!
95-1ton
Fueling (Full tank)
Fueling (Full tank)
Topics: 10
Alias (AKA): Ryan
Postby Jasen » May 15th 2010, 3:08pm
Pick up a computer cooling fan for the TV, you can get them pretty cheap, I think I paid $10at at Best Buy. I put a 32 CFM fan in my amp box and it moves enough air that I don't think the fans on the amps have ever turned on.
Topics: 249
Images: 68
Year: 1997
Postby Leeann_93 » May 15th 2010, 5:34pm
Ditto - they move a ton of air and are virtually silent.
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby LEVE » May 15th 2010, 6:53pm
If you do install a fan, which is a great idea, then also filter that air so that you're not blowing dust from the floor area into the electronics.
LEVE
Topics: 18
Postby 95-1ton [OP] » May 16th 2010, 5:29am
Jasen wrote:Pick up a computer cooling fan for the TV, you can get them pretty cheap, I think I paid $10at at Best Buy. I put a 32 CFM fan in my amp box and it moves enough air that I don't think the fans on the amps have ever turned on.
[ http://www.astrosafari.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=13034 ]
Awesome Jasen, thanks...!
95-1ton
Fueling (Full tank)
Fueling (Full tank)
Topics: 10
Alias (AKA): Ryan
Postby castle_Rock » May 17th 2010, 6:15pm
cool idea - I'm still using the old fashioned cardboard box in the middle seat as a console with a cheap organizer from Wally-World. Does what I need, I need to do something different now though. Now that its beginning to be summer... :banana:
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 3 full yearscastle_Rock has been a member for 3 full yearscastle_Rock has been a member for 3 full years
Topics: 35
Postby astroturf » May 17th 2010, 10:14pm
castle_Rock wrote:cool idea - I'm still using the old fashioned cardboard box in the middle seat as a console with a cheap organizer from Wally-World. Does what I need, I need to do something different now though. Now that its beginning to be summer... :banana:
Castle, I have found an excellent fix for my business needs. Are you looking for a glamorous fix or a functional one? Jim
astroturf
Topics: 112
Postby castle_Rock » May 18th 2010, 7:23pm
Just a simple wood framing perferred, but leaning more functionally.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby astroturf » May 18th 2010, 9:31pm
castle_Rock wrote:Just a simple wood framing perferred, but leaning more functionally.
This is what I began using. It fits perfectly in between the front seats on my 05. It partially blocks usage of the recline lever, but that doesn't bother me. I recently added a second on top. they stack nicely. It is at a height that is similar to the door window ledge. I love it. I don't have to f with the arm rests... It Is Perfect.
Jim
rubbermaid file box External Dimensions 10 3 4 Height x 18 Width x 14 Depth .jpg
astroturf
Topics: 112
Postby castle_Rock » May 19th 2010, 6:06pm
cool, thanks.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Return to Interior
It is currently May 25th 2013, 7:32am
Interior Forum
Moderator: rev_les
akkid
in Interior
Comments: 0
Time: 11:09pm
Attached by: SilverBullet1997
SilverBullet1997
in Interior
Comments: 19
Date: May 23 '13
Time: 3:58pm
Attached by: Starrshine
Starrshine
in Interior
Date: May 22 '13
Time: 1:52am
Attached by: TaxiVan
TaxiVan
in Interior
Comments: 19
Date: May 21 '13
Time: 10:20pm
Starrshine
in Interior
Date: May 21 '13
Time: 4:30pm
Users browsing this forum: Google [Bot] and 5 guests
