Changed oxy sensors still get P0420
Postby JuneauCabbie [OP] » June 11th 2011, 2:59am
This is driving me nuts! When I purchased my '03 Safari last November, it appeared that the entire exhaust system had been replaced --- when we had it up on the lift during the pre-purchase inspection, the exhaust pipe, cat converter, and muffler all looked new, with no dirt or rust.
I knew that it needed a tune, and had the plugs, plug wires, cap, and rotor replaced about 2 months after I bought it. During the winter, I spent time idling because you can't stay warm in a taxi at 10 degF if you can't run the heater.
I began having a problem with the "check engine" light coming on --- my wrench put his scanner on it, got a code P0420, reset it, and it would be fine for a week or so. Then it began happening all the time, whenever the engine was warmed up and I would be driving at 55mph or so for 10-12 miles, it the "check engine" light would come on with at Code p0420 when I would stop and idle at a stoplight.
I got an Ultragauge and was able to clear the code, but I've been doing it every time I stop and idle. We replaced the Bank 1 oxy sensors but that didn't fix the problem.
Any clues about this run at 1600-2000 rpm for 10-12 miles and get a P0420 when you stop and idle at 600 rpm? Should I get the exhaust analyzed? Should I be checking something other than oxy sensors?
FYI gas mileage and performance have improved with the new oxy sensors.
JuneauCabbie
Years of Membership: JuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full yearsJuneauCabbie has been a member for 8 full years
Topics: 30
Images: 21
Alias (AKA): JuneauCabbie
Year: 2003
Extra Info: SXT 4.3L V6 AWD
Re: Changed oxy sensors still get P0420
Postby Leeann_93 » June 11th 2011, 3:19am
Yeah, you need to check the engine coolant temperature sender - the one that talks to the PCM, not the one that talks to the gauge.
Your wrench should be able to view what it's saying on his scan tool. If it's off from the gauge, it probably needs to be replaced.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby 1997funbox » June 11th 2011, 5:15am
P420 is usually a bad catalytic assembly :(
1997funbox
Years of Membership: 1997funbox has been a member for 6 full years1997funbox has been a member for 6 full years1997funbox has been a member for 6 full years1997funbox has been a member for 6 full years1997funbox has been a member for 6 full years1997funbox has been a member for 6 full years
Alias (AKA): Carlos Hernandez
Extra Info: Lt
Postby NY Safari TONKA » June 11th 2011, 6:27am
You only have one O2 sensor on your System? :rolling:
NY Safari TONKA
Years of Membership: NY Safari TONKA has been a member for 6 full yearsNY Safari TONKA has been a member for 6 full yearsNY Safari TONKA has been a member for 6 full yearsNY Safari TONKA has been a member for 6 full yearsNY Safari TONKA has been a member for 6 full yearsNY Safari TONKA has been a member for 6 full years
Extra Info: AWD EXT 4.3L V6
Postby JuneauCabbie [OP] » June 11th 2011, 8:36am
Leeann_93 wrote:Yeah, you need to check the engine coolant temperature sender - the one that talks to the PCM, not the one that talks to the gauge.
My Scangauge says the coolant temp is 194.6 when the engine is warmed up. Since it connects to the ODBC connector, isn't it reading the sensor that talks to the PCM?
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby JuneauCabbie [OP] » June 11th 2011, 8:39am
NY Safari TONKA wrote:You only have one O2 sensor on your System? :rolling:
No. If you read what I wrote a little closer, my wrench changed BOTH Bank 1 sensors.
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby Leeann_93 » June 11th 2011, 1:47pm
JuneauCabbie wrote:My Scangauge says the coolant temp is 194.6 when the engine is warmed up. Since it connects to the ODBC connector, isn't it reading the sensor that talks to the PCM?
Then the ECT is fine - forgot you had a ScanGauge.
He replaced both upstream O2 sensors? The usual culprit in the P0420 is the downstream O2 sensor (bank 1 sensor 3), not the upstream.
Other culprits are: exhaust leak prior to the cat and a bad cat (along with bad ECT).
Image Image
Topics: 27
Year: 2002
Postby NY Safari TONKA » June 11th 2011, 7:26pm
Sorry incomplete question...You saying both...what about Bank 1 No.3 sensor also change?..and all wires on them are good and O2s are not coming out?...Do you here like a Thin(sink)..noise after van its turned off?
NY Safari TONKA
Postby paulo57509 » June 26th 2011, 8:37pm
Your '03 Safari has three O2 sensors; Bank 1, Bank 2 and a post-cat.
It's not clear, but it appears that the OP is stating that both the Bank 1 and post-cat sensors were changed. If so, I agree with the others that this might be a bad cat issue.
The ECM looks at the upstream sensor (Bank 1 and 2) wave forms and the downstream sensor (post-cat) wave forms and compares the two. The upstream sensor wave forms should fluctuate while the downstream wave form should remain pretty steady. If both wave forms are similar, P0420 code is set.
You might check for an exhaust leak upstream of the cat.
Edit: OP mentions that the code is set after running for a while and then idling. Sounds like a weak or defective cat.
paulo57509
Years of Membership: paulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full yearspaulo57509 has been a member for 7 full years
Topics: 23
Year: 2003
Extra Info: RWD
Postby paintdrying » June 26th 2011, 10:09pm
I wonder if long periods of idling with a rich mixture may have killed the cat. I have heard cats do not die, they are murdered.
paintdrying
Topics: 94
Extra Info: 108 000
Postby JuneauCabbie [OP] » July 2nd 2011, 9:16am
Been gone, stopped checking for updates while the site was down...
1. No exhaust leaks. None. The exhaust system was new when I purchased the van, and my mechanic carefully checked for any leaks.
2. The cat converter seems to be working properly. My wrench doesn't have an exhaust gas analyzer available, but there is no hydrogen sulfide rotten egg smell or acid sulfite odor from my tailpipe. Spark plugs were not fouled.
But the problem is still happening. Don't have a scope available to check waveforms.
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby JuneauCabbie [OP] » July 27th 2011, 8:23am
Well, I got the answer I didn't want! Finally took Taku 73 to our local muffler shop, on the premise that if you want answers in a specific area like the exhaust system, go to the expert. I've known Brillo, the owner, since I was dating his older sister years ago, and he knows his stuff. He's the local Flowmaster shop.
He didn't charge me to run his scanner on my rig and let me look at the waveforms produced by the 3 oxy sensors. His conclusion was that the replacement exhaust system installed just before I bought the car has an undersized cat converter. It's marginal, operating just fine when the rig is warming up, or while I'm cruising on the expressway, but failing when it's hot and I'm idling at a stoplight after cruising at 55 or 60. I can get away with resetting the check engine light with the ScanGuage until I can actually afford to replace it without causing any damage to the engine (no emissions testing requirements here).
It won't be cheap to replace it with a robustly sized one, and I'll have him do it instead of my regular wrench, who has been blowing me off when I want these questions answered in spite of the substantial amount of money I spend at his shop. If I could find a better shop that would give taxis priority (which he does because he knows our rigs are our livelihood), I'd go there, but haven't found one yet.
I'm still suffering the trauma from the retirement 2 years ago of the mechanic I had for 40 years, a man I could always count on to do whatever was needed, and work with me to make it affordable, and that was before I was driving my own cab. When my income totally depends on my vehicle, having a good wrench that can take care of problems instantly is critical.
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby rev_les » July 28th 2011, 4:30am
Aside from the chance that the converter is dead, make ABSOLUTELY SURE that your wrench is using Delphi, Delco, or Nippon O2 sensors.......and especially NOT A BOSCH sensor. A brand spankin' new Bosch sensor, will continue to throw codes on these vans. I believe somewhere on here another member figured out that the resistance is incompatible with the PCM, but either way, they will NOT operate correctly. ( I have 3 of them I bought prior to learning this that I tossed and replaced with Nippon's, and the problem miraculously went away.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby redfury » July 28th 2011, 5:02am
rev_les wrote:Aside from the chance that the converter is dead, make ABSOLUTELY SURE that your wrench is using Delphi, Delco, or Nippon O2 sensors.......and especially NOT A BOSCH sensor. A brand spankin' new Bosch sensor, will continue to throw codes on these vans. I believe somewhere on here another member figured out that the resistance is incompatible with the PCM, but either way, they will NOT operate correctly. ( I have 3 of them I bought prior to learning this that I tossed and replaced with Nippon's, and the problem miraculously went away.
I'm running Standards in my van with no issues, and try to find non Bosche O2 sensors around here! I'd have to order Delco's.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby Corsemoto » July 29th 2011, 4:57pm
Very good point, last year when doing a 100K service on my '04 Astro AWD, I replaced the three oxygen sensors with Bosch and had it throw codes. Replaced with old sensors, codes disappeared and sent back to Rock Auto (great about returns/credits). I've been getting occasional P0420 so replacing now with Denso O2 sensors (oem), cheaper too.
Corsemoto
Firing on 4 Cylinders (L3)
Years of Membership: Corsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full yearsCorsemoto has been a member for 9 full years
Topics: 36
Images: 13
Year: 2004
Extra Info: LT AWD
Postby MadMid » August 7th 2011, 4:53pm
Was there also. Replaced it all and would still get a 420 after 30 miles or so of driving. Clear the codes and continued on. Couple weeks ago started buying alcohol free fuel. Tank and half later no 420 code. Maybe the fuel, maybe not.
MadMid
Years of Membership: MadMid has been a member for 6 full yearsMadMid has been a member for 6 full yearsMadMid has been a member for 6 full yearsMadMid has been a member for 6 full yearsMadMid has been a member for 6 full yearsMadMid has been a member for 6 full years
Extra Info: AWD Cargo
Postby JuneauCabbie [OP] » August 12th 2011, 10:19am
The replacement sensor was a Delco.
JuneauCabbie
Topics: 30
Images: 21
Year: 2003
Postby rev_les » August 13th 2011, 10:26pm
You should be good on the sensor then. Ironically, a few days ago, a bud changed his O2 sensors on his Town N Country with Bosch....same thing, it started throwing more codes than it had to begin with....I told him about the problems we have on Astro's with them, and my suspicions. He swapped to Densos, original problem AND new problems solved.
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby Leeann_93 » August 13th 2011, 10:43pm
My local parts house doesn't even stock Bosch O2 sensors, only Denso. They'll get the Bosch if you insist, but they'll hand you Denso otherwise. They got tired of the returns.
Image Image
Topics: 27
Year: 2002
Postby chevymaher » March 22nd 2012, 4:02am
Something I stumbled across. This guy is usually right to.
[youtube]5icTmYItwiE&feature=context&context=G2367b1dRVAAAAAAAACA[/youtube]
Topics: 84
Year: 1994
  • p0420
    by justinf89 » May 27th 2010, 6:44am in Exhaust
    Last post by Matrixx View the latest post
    June 5th 2010, 10:35am
    7Replies
    119Replies
    June 22nd 2017, 1:10pm
  • P0420
    by kirklaut » July 1st 2015, 5:51am in Exhaust
    Last post by paulo57509 View the latest post
    July 3rd 2015, 10:20pm
  • $2 P0420 fix ???
    Attachment(s) by sadglad » March 25th 2014, 7:43am in Exhaust
    Last post by Corsemoto View the latest post
    April 28th 2014, 2:26am
  • stupid P0420
    Attachment(s) by drewsk81 » March 10th 2015, 2:02am in Exhaust
    March 13th 2015, 6:23am
  • intermittant P0420 code
    by crgastro » October 9th 2015, 3:33am in Exhaust
    Last post by Sailing_Faith View the latest post
    October 11th 2015, 1:49am
Return to Exhaust
It is currently June 22nd 2017, 1:10pm
Exhaust Forum
Attached by: Coaster
CoasterCoaster is online!
in Exhaust
Date: May 20 '17
Time: 2:33am
in Exhaust
Date: May 19 '17
Time: 12:58pm
Attached by: Cologne
Cologne
in Exhaust
Comments: 0
Date: May 18 '17
Time: 6:29am
Cologne
in Exhaust
Date: May 17 '17
Time: 5:59pm
Cologne
in Exhaust
Date: May 15 '17
Time: 2:59am
