po155 code: which sensor is it? also, one more question
Postby dapperdan7 [OP] » November 18th 2011, 1:45am
i know there are 3 on the 2000 safari but my question is: it the one on the passenger or drivers side. I'm pretty sure its one of the two before the cat converter.
aslo, after the first one coming out as easy as butter, the second one i managed to strip the nut on the other sensor. best way to get the **** out? i already have the proper wrench and i still messed it up. heat? vise grips?
thanx
cars like relationships are never easy!
dan
dapperdan7
Years of Membership: dapperdan7 has been a member for 6 full yearsdapperdan7 has been a member for 6 full yearsdapperdan7 has been a member for 6 full yearsdapperdan7 has been a member for 6 full yearsdapperdan7 has been a member for 6 full yearsdapperdan7 has been a member for 6 full years
Topics: 9
Extra Info: awd
Re: po155 code: which sensor is it? also, one more question
Postby Jasen » November 18th 2011, 1:48am
O2S Heater Circuit
Malfunction
(Bank 2, Sensor 1)
P0155 This DTC determines if
the O2 sensor heater is
functioning properly by
monitoring the amount of
time necessary for the O2
sensor to become active
after start - up.
The elapsed time to obtain  .150V
from the mean O2 bias voltage.
*Time based on table: Time Vs
Average Air Flow
System Voltage > 11.7 but < 17 Volts except 4.3L C/K/G
which is voltage >11.7 but < 18 volts.
(NOTE: If voltage remains outside this window for 4
consecutive seconds, the test is void for this cold start.)
Air Flow < 27 g/sec 4.3L (21 g/s 4.3L M/L only - Denso
Sensors; 35 g/s - 5.7L only)
Engine run time > 2 seconds
ECT < 33C
IAT < 33C
 ECT-IAT  5C
From cold start to a maximum
time of - 115 seconds.
*Time determined by table.
Lt Duty=B
Federal Hvy
Duty=C
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Images: 101
Year: 1997
Postby Phantom » November 18th 2011, 3:12am
It the PCM measures the time elapsed (based on coolant temp) that too much time passed before the oxygen sensor began operating properly, if it sees that it has it sets the code , it is often the passenger side , but it seems as you are doing the best thing in replacing all 3 , , be sure to take time to carefully inspect the connecters and wiring condition as they too can set the code by having a short or open or high resistance in wiring harness or harness connectors.
It is best to use heat like a torch before trying to remove , sometimes the only way to get them to move , and it sometimes can take a few tries ,
Phantom
Firing on 7 Cylinders (L4)
Postby Leeann_93 » November 19th 2011, 9:36pm
Yep, heat the bung (not the sensor) with a MAPP gas torch or Oxy-Acetylene torch first, then break loose with breaker bar and O2 sensor socket. Before heating, though, spray several times with PB Blaster or other penetrating oil (WD40 need not apply) and tap with something metal - it helps capillary action. The heat helps draw the oil into the threads further along with expanding the bung a little.
On mine, a propane torch wasn't hot enough, but mine were seriously rusted.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 26
Year: 2002
Extra Info: LS 4.3L AWD
Postby SatWorld » March 12th 2012, 4:00am
OK, so what's the answer to the original question? :D I have the same code but can't find which sensor is which.
99 Astro Cargo, 319,000+ miles pulling a trailer
4.3L V6 A/C CMFI AWD (that's disconnected)
SatWorld
Years of Membership: SatWorld has been a member for 4 full yearsSatWorld has been a member for 4 full yearsSatWorld has been a member for 4 full yearsSatWorld has been a member for 4 full years
Images: 7
Year: 1999
Extra Info: 4.3L Cargo 319000mi
Return to Exhaust
It is currently January 23rd 2017, 3:49pm
Exhaust Forum
Voltsmith
in Exhaust
Date: Dec 25 '16
Time: 6:57pm
Attached by: markmitch
in Exhaust
Comments: 21
Date: Dec 05 '16
Time: 2:14am
astrobill
in Exhaust
Date: Dec 02 '16
Time: 9:37pm
in Exhaust
Date: Nov 15 '16
Time: 11:57pm
Astrox2
in Exhaust
Comments: 30
Date: Nov 05 '16
Time: 7:38pm
