Time to change egr valve and map sensor
Postby khundan [OP] » June 7th 2012, 2:25am
I have a '94 4.3L with a z vin. It threw off codes to replace the egr valve and the map sensor. I replaced the map sensor but am feeling nervous with the egr valve. I believe it is 10 mm bolt on it but it feels a little loose. Someone suggested it could be a 9.5 mm but that seems way to odd. I started it up after the map sensor and there is no code, but it is running a little rough.
I'm feeling like I should change the egr valve. Could someone tell me what bolt size that is? I really do not want to strip it and have to use an easy out. Any help would be greatly appreciated.
khundan
Years of Membership: khundan has been a member for 4 full yearskhundan has been a member for 4 full yearskhundan has been a member for 4 full yearskhundan has been a member for 4 full years
Year: 1994
Extra Info: 4.3L V6 RWD Z vin
  • Dumb Question - Replacing EGR Valve Gasket
    by Fortran » October 22nd 2016, 9:17pm in Exhaust
    Last post by Fortran View the latest post
    October 23rd 2016, 1:36am
  • EGR and catalytic converter advice
    by Jawon » February 23rd 2017, 1:44am in Exhaust
    March 5th 2017, 2:22pm
    72
    March 26th 2017, 1:59pm
Re: Time to change egr valve and map sensor
Postby gg/ss » July 19th 2012, 6:40am
try a 3/8 socket
gg/ss
Years of Membership: gg/ss has been a member for 4 full yearsgg/ss has been a member for 4 full yearsgg/ss has been a member for 4 full yearsgg/ss has been a member for 4 full years
Alias (AKA): will
Year: 1993
Extra Info: tbi 305
Postby Leeann_93 » July 20th 2012, 2:59am
They are 10mm. Try another 10mm socket, prefrably 6 pt, or a box-end wrench.
Oh, and most EGR valves don't die, they get plugged. Pull it off, clean it, reinstall it with a clean screen gasket by Dorman/HELP!
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Return to Exhaust
It is currently March 26th 2017, 1:59pm
Exhaust Forum
Jawon
in Exhaust
Comments: 25
Date: Mar 05 '17
Time: 6:32am
Jawon
in Exhaust
Comments: 25
Date: Mar 04 '17
Time: 12:17am
Jawon
in Exhaust
Comments: 25
Date: Feb 24 '17
Time: 2:17am
Attached by: chevymaher
in Exhaust
Comments: 20
Date: Jan 30 '17
Time: 1:05pm
installman
in Exhaust
Comments: 20
Date: Jan 30 '17
Time: 1:49am
