Anti-Seize on wheel studs?
Postby Houston_Astro [OP] » October 24th 2008, 4:42am
How many of you are using anti-seize on your wheel studs and what are you torquing the lug nut to?
Houston_Astro
Years of Membership: Houston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full yearsHouston_Astro has been a member for 8 full years
Re: Anti-Seize on wheel studs?
Postby timelessbeing » October 24th 2008, 5:27am
100 ft-lbs and a dab of ordinary grease.
2000 Astro AWD Passenger
4.3L CSFI V6 • 3.73 G80 • 4" OV lift • 30" AT tires
timelessbeing
Years of Membership: timelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full yearstimelessbeing has been a member for 8 full years
Topics: 38
Extra Info: Lifted AWD 4.3
Postby Big_kid » October 25th 2008, 10:50pm
I keep 'em dry. 100Ftlbs here.
Firing on 5 Cylinders (L5)
Topics: 133
Images: 49
Extra Info: 2WD conversion
Postby Mat Mobile » October 27th 2008, 1:45am
I use anti-seize. It really helps and it's better in my opinion than grease in this case. I forget if I torque to 90 or 95 ft-lbs.
Mat Mobile
Years of Membership: Mat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full yearsMat Mobile has been a member for 8 full years
Postby Matrixx » October 27th 2008, 3:32am
I use a very small amount of Nickle based anti-seize on my wheel studs. Torque specs on the astro/safri vans is 100 ft lbs. Hope this helps. :)
Matrixx
Years of Membership: Matrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full yearsMatrixx has been a member for 8 full years
Postby SSAstro » October 29th 2008, 12:46am
use hub grease they use it on vw's and other cars that use the lug bolts b/c they build up rust on the back of the rotor and hub. i've seen studs stretch from using antiseize i don't know why its happened but it has happened
SSAstro
Years of Membership: SSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full yearsSSAstro has been a member for 8 full years
Postby PJorgen » August 27th 2012, 8:17pm
Always use anti-seize. BTW, wheel nut torque varies by year, 125 ft-lbs for 2003, increased to 140 ft-lbs for 2004-05.
2003 AWD Safari - being converted into the "Troutmobile"
PJorgen
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: PJorgen has been a member for 4 full yearsPJorgen has been a member for 4 full yearsPJorgen has been a member for 4 full yearsPJorgen has been a member for 4 full years
Topics: 25
Year: 2003
Postby redfury » August 27th 2012, 11:01pm
Stretching is caused by over torquing them, and by adding anti seize, you can use less torque to get the same hold...someone here made the comparison. Antiseize makes the threads slippery which means less resistance when coming to the torque spec, making it easier to turn vs the non greased threads which would hit the torque limit faster.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Postby Ragenme » August 27th 2012, 11:19pm
The ideal behind wheel lugs is to keep the wheel on. If you lubricate them with something to keep the loose, in theory and in time they could back off. I leave they dry. I suggest a good cleaning from time to time or just rotate your tires. Then torque to 100lbs.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full yearsRagenme has been a member for 4 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Year: 1998
Extra Info: SLX 4.3 V6 RWD
Postby tedanderson » August 28th 2012, 12:01am
I agree. I keep them dry. It's something about that squeeky-cracking noise that verifies that the lugs are tight.
tedanderson
Years of Membership: tedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full yearstedanderson has been a member for 7 full years
Topics: 74
Alias (AKA): 2Big4aMiniVan
Postby Rolling_Rock » August 28th 2012, 12:34am
anti-seize and 'lightly-snug' / under-torqued - I hate tight lug nuts. I hate them, so I keep minez loose.
The design of the 'tapered' lug nut causes the nut to 'tighten itself' when driving
In my expereince whenever I remove a wheel that I 'loosley' put on months before - when I go to take it off its always 'tighter' than I rmemeber... thats w/ anti-seize... just my opinion - do as you will..
Rolling_Rock
Years of Membership: Rolling_Rock has been a member for 5 full yearsRolling_Rock has been a member for 5 full yearsRolling_Rock has been a member for 5 full yearsRolling_Rock has been a member for 5 full yearsRolling_Rock has been a member for 5 full years
Topics: 26
Year: 2002
Extra Info: cargo version
Postby RECox286 » August 28th 2012, 12:41am
Zip em on dry with 1/2" gun. Never had a wheel come off, or a stud break.
Uncle Bob
RECox286
Topics: 37
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby chevymaher » August 28th 2012, 12:44am
Actually that is why chrysler had left hand and right hand lug nuts. One side stays tight from rotational forces as the tire turns. The other loosened. So they changed the thread direction on one side so they all would tend to tighten.
Clean threads are the best. With slight lubrication. Follow me here.
Any force used to turn the lug. Be it rust, stripped/warped threads, or just dry. That force is subtracted from the torque needed to press the lug against the rim, and the clamping force is reduced.
If it is taking 10 lbs to turn the lugnut. Then that is 10 lbs not being applied to the wheel.
Or what uncle Bob just said.
Topics: 79
Year: 1994
Postby cowboydan » August 30th 2012, 4:50pm
i used brake anti sieze. no wheel should leave any shop without being torqued. 100lbs. if not you run the risk of racing your wheel. i also use anti sieze on the valve stem threads. i have green alluminum caps on brass threads so i need to. dry works for me too as long as the tire(s) are remove frequently.
2006 sebring 2.7 touring: DD
cowboydan
Firing on 8 Cylinders (L2)
Years of Membership: cowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full yearscowboydan has been a member for 6 full years
Topics: 67
Alias (AKA): cbd
Year: 1997
Extra Info: 4.3w CL AWD
Postby Lumpy » August 30th 2012, 5:19pm
Light anti-seize and 100 lb by hand. Never an air gun.
That's my method.
Topics: 257
Year: 1989
Postby Bread Van » August 30th 2012, 6:18pm
I once asked my friend, an engineer for Harley Davidson, about using Anti-seize.
He told me that it was a lubricant and that using a lubricant on a bolt causes you to stress the bolt MORE by the time you achieve a designated torque. Torque specifications are inherent to the material, grade and size of the fastener (nut, bolt, etc) being used. As such, if you apply a lubricant and use the same torque spec you are potentially damaging your fastener by stretching it.
That said I still use anti-seize anytime I'm working with a fastener that gets used so infrequently it will rust in place (suspension components usually). I still use the same torque but go real slow and easy to reach the torque spec. A futile effort to limit the effect mentioned above. My wheels and tires get removed enough that I don't think anti-seize is necessary
Bread Van
Years of Membership: Bread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full yearsBread Van has been a member for 6 full years
Topics: 36
Alias (AKA): mapper
Year: 2003
Extra Info: AWD 2 inch lift
Postby chevymaher » August 30th 2012, 6:33pm
My information comes from when I worked at Fartstone doing tires. Procedure is their policy. We had to attend lectures about putting on tires.
My brother is a engineer. I dropped out of college for construction, money now deal. So I am not lost either.
But basically it shows top of the line experts don't always agree. I am sure Fartstone researched it well before instituting policy. Because it holds up in court of law and they will not be held liable. Which is their main concern.
Topics: 79
Year: 1994
Postby RECox286 » August 30th 2012, 6:36pm
chevymaher wrote:Actually that is why chrysler had left hand and right hand lug nuts. One side stays tight from rotational forces as the tire turns. The other loosened. So they changed the thread direction on one side so they all would tend to tighten.
I was going to elaborate about L & R hand threaded studs on D/C vehicles, but the bride was banging on the wall to let me know that din-din
was on the table. anyway, excellent points made CM. One note: our neighbor worked for many years as a heavy equipment operator for the
Township Public Works Dept. One time, coming over the bridge to the Island, he noticed a wheel gaining speed as it passed the truck he was
driving. One of the rear wheels broke all the studs, because the lugs were not installed tight enough. True story.
Guys, you should try a Torque Limiter extension, if you dare. It will give you an exact torque, and save you a lot of time. But, even w/o a T.L.
you will be able to feel the torque that the gun is giving you, once you get a "feel" for it. Most "old" mechanics will agree with me. Not saying you
are wrong to do it as you say, just saying that if you need to speed up production, there are other suitable ways of doing the job to book specifications.
(It ain't rocket science.) As far as dry or wet goes, when you set a torque, it is kind of a personal thing, unless the FSM, or SAE recommends one way
or t'other. I also have my preferences when torquing fasteners; some dry, some wet, all reused fasteners chased to clean the threads before assembly
Uncle Bob
RECox286
Topics: 37
Year: 1993
Postby Lumpy » September 3rd 2012, 8:10am
RECox286 wrote:
... you will be able to feel the torque that the gun is giving you, once you get a "feel" for it. Most "old" mechanics will agree with me...
I think for stock, steel wheels, pretty much any method of application is probably acceptable. So I'm not bonking anyone's use of guns, but consider this...
I've heard all my life about old mechanics that can "feel" a certain torque through a gun. But there's no way to test that they really can or not. Putting a torque wrench on in reverse doesn't tell us how much torque was used to put it on in the tighten direction. And putting a TR on in the forward direction will only tell us that it's AT LEAST the setting on the wrench. ie a TR set to 100 Ft/Lb will click/read/bend the needle to 100 if the nut is at 100, 110, 200, 500 lbs.
I take my wheels off several times a year. So for me, anti-seize and torque'em. I'll take the lugs OFF with a gun, but to put 'em on I want a bar and two hands.
Topics: 257
Year: 1989
Postby chevymaher » September 3rd 2012, 11:16am
I am old, and I hold the extension and spin the lugs on after starting them by hand. I am pretty good at it. I then torque them. I usually get less than a 1/8 turn before it clicks.
Topics: 79
Year: 1994
Return to Exhaust
It is currently January 23rd 2017, 3:42pm
Exhaust Forum
Voltsmith
in Exhaust
Date: Dec 25 '16
Time: 6:57pm
Attached by: markmitch
in Exhaust
Comments: 21
Date: Dec 05 '16
Time: 2:14am
astrobill
in Exhaust
Date: Dec 02 '16
Time: 9:37pm
in Exhaust
Date: Nov 15 '16
Time: 11:57pm
Astrox2
in Exhaust
Comments: 30
Date: Nov 05 '16
Time: 7:38pm
