P0107 MAP sensor (Where?)
Postby mmaclean [OP] » July 25th 2011, 6:29pm
I have a 2000 Astro AWD. My code reader shows P0107 for a MAP sensor.
The Haynes manual is too vague. Where can I find the MAP sensor to test. I found the Mass Air Flow Sensor, but I believe this vehicle has both otherwise the code would have read P0101 if it was the MAF.
Any help would be great.
mmaclean
Years of Membership: mmaclean has been a member for 6 full yearsmmaclean has been a member for 6 full yearsmmaclean has been a member for 6 full yearsmmaclean has been a member for 6 full yearsmmaclean has been a member for 6 full yearsmmaclean has been a member for 6 full years
Topics: 13
  • Oxygen sensor voltages
    by installman » February 9th 2017, 1:29am in Technical Information
    Last post by Lumpy View the latest post
    February 18th 2017, 5:26pm
  • mass air flow sensor/air box
    by Johnnysparx » May 25th 2017, 3:52pm in Technical Information
    Last post by TurnNburn View the latest post
    May 25th 2017, 5:19pm
    May 30th 2017, 12:11pm
Re: P0107 MAP sensor (Where?)
Postby chevymaher » July 25th 2011, 7:02pm
Top of black plastic manifold
map sensor.jpg (130.93 KiB) Viewed 4756 times
Topics: 83
Year: 1994
Postby Leeann_93 » July 25th 2011, 10:07pm
And it's easier to see/get to from inside the vehicle. Remove the doghouse, lay across the passenger seat and shine your flashlight towards the right side of the intake hat. You will see it.
'00 Astro LS AWD vin W - WIP
Image Image
Topics: 27
Year: 2002
Extra Info: LS 4.3L AWD
Postby mmaclean [OP] » July 26th 2011, 2:01pm
Thanks guys, I figured I would have to take off the doghouse. The diagram will help.
mmaclean
Topics: 13
It is currently May 30th 2017, 12:11pm
Technical Information Forum
Date: May 21 '17
Time: 7:47pm
Comments: 13
Date: Apr 05 '17
Time: 10:06pm
Date: Mar 10 '17
Time: 2:17am
Comments: 14
Date: Feb 28 '17
Time: 6:05pm
Comments: 14
Date: Feb 18 '17
Time: 10:24pm
