2002 astro fuel pump relay signal problem.
Postby Bigblaine301 [OP] » March 29th 2012, 3:02am
This is frustrating. My 02 astro was do for smog. I went to get in to start but just cranked over. Nothing at all for firing. I checked the ignition there was spark. I checked the fuel pump no action. So I checked fuel pump relay on bench, perfect. I checked signal voltage on relay block, 11.8 volts. Hmm? I then wired relay with some jumper clips to relay block. No relay engage. So I took volt meter to it with relay wired up. 0.78 volts. Thins is with relay in place. Not enough current for some reason. Do you fellas have a diagram or magic powder? Thanks guys. :screaming:
Bigblaine301
Years of Membership: Bigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full yearsBigblaine301 has been a member for 7 full years
Alias (AKA): Big blaine
Re: 2002 astro fuel pump relay signal problem.
Postby paintdrying » March 29th 2012, 1:09pm
Did you hear the pump prime? Did you try and just jump the relay? Could be the bulkhead connections, you can try the wiggle method.
paintdrying
Topics: 94
Extra Info: 108 000
Postby Bigblaine301 [OP] » March 30th 2012, 7:32am
Well here's the update, I read a persons post on the 2 second rule for power timeout, this was true for me. I then turned key on for 2 seconds off for a second. Did this 5 times then cranked it. This method started it. So there is a problem somewhere with fuel system not building pressure when trying to cold start. :screaming:
Bigblaine301
It is currently June 24th 2017, 7:50pm
Technical Information Forum
Date: Jun 09 '17
Time: 6:58pm
Date: Jun 09 '17
Time: 6:45pm
Nick
Date: Jun 09 '17
Time: 6:07pm
Comments: 0
Date: Jun 01 '17
Time: 4:14pm
Date: May 21 '17
Time: 7:47pm
