'95 Astro OBD? Code Reader?
Postby Casey [OP] » March 23rd 2009, 4:53pm
Which code reader/scanner should I get for my '95 Astro? I see '96 and up, but I also see it mentioned that the OBD I scanners might work on '94s and '95s. Is there a definite answer as far as which ones work on a '95?
Just picked this van up (90k miles and on the drive home the SES light came on, but it drove fine. Today, i start driving it and five minutes into the trip, the idle drops really low and it dies at a stop light. Fired it back up but had to step on the throttle to make sure it kept running as it wants to idle very very low and almost die. I'm thinking it's EGR related, but with no scan tool, I can't be sure. :think:
I had a similar issue on my '90 Astro with the CEL and a new EGR fixed it. No experience with newer Astros, though...
I don't really want to spend $300 on a code reader/scanner, but $100 is do-able. TIA,
Casey
Casey
Years of Membership: Casey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full yearsCasey has been a member for 8 full years
Topics: 24
Year: 1995
Extra Info: 4.3L LT 5-speed
  • Got my OBD II bluetooth adapter
    by kennysmoke » February 18th 2017, 11:12pm in Technical Information
    Last post by Wimpazz View the latest post
    February 27th 2017, 2:29pm
  • P0300 code diagnoses help
    by waldenwithwheels » March 31st 2017, 2:14am in Technical Information
    March 31st 2017, 3:23am
    7
    89
    June 28th 2017, 9:58am
Re: '95 Astro OBD? Code Reader?
Postby Casey [OP] » March 23rd 2009, 6:35pm
Ok, I used the ground-out method on the OBD port and got a code "32" to flash via the SES light, which means a problem in the EGR circuit. Sounds like I need a new EGR valve (and gasket). :dance:
Casey
Topics: 24
Year: 1995
Postby Matrixx » March 23rd 2009, 7:08pm
Their was a lot of talk about this common EGR problem in the Old Forum section. Adding a screen seemed to help prevent the EGR from getting plugged up which is the most common problem with them. It might be a worth while search to do. Just a thought.:)
Matrixx
Years of Membership: Matrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full yearsMatrixx has been a member for 9 full years
Postby Casey [OP] » March 23rd 2009, 9:24pm
Thanks, I have checked out some old posts and saw the screen mentioned. I installed a new EGR valve and gasket and cleared the code, so I'll take it for a drive later and see if it idles better once it's at normal operating temperature. The SES light is off and no codes flash, so that's a good sign for now.
It still 'feels' like it's idling a bit low to me, but the van is so new to me it's hard to say for sure.
When the EGR is replaced, does the EGR vacuum solenoid reset/re-calibrate and adjust to the new EGR, provided it was the EGR that was bad? Just wondering if I should be able to notice an immediate change or if it takes a bit of driving and some miles for everything to return to normal. :?
Casey
Topics: 24
Year: 1995
Postby Matrixx » March 24th 2009, 4:46am
Hi Casey
The computer will automatically adjust yes. You should see an immediate change. Please keep us updated, thanks.:)
Matrixx
Postby Casey [OP] » March 25th 2009, 3:20am
After putting on 50 miles or so today, the SES light has yet to light up, so I'm pretty confident the EGR valve was the issue.
The engine still idles a bit low, though. I'm going to have to look everythign over again to make sure a vacuum line didn't get knocked off or come lose somewhere. It feels like there's a small vacuum leak, and we all known how fun those are to track down... :lol:
I've got an exhaust rattle, too, but that's a minor issue. I was a bit (pleasantly) surprised to see a 3"(?) muffler underneath after replacing the 2.25" muffler on my '90 a few months ago.
Casey
Topics: 24
Year: 1995
Postby Matrixx » March 25th 2009, 3:58am
Hi Casey
I'm glad to see the light hasn't come back on. Idle should be around 550-600 with accessories on and in gear.
I was surprised as well to see a beast of a muffler on mine just for a V6. I think it has to do with reducing the inherent V6 Rumble/Drone sound they give off plus it increases performance a bit as well. Thanks for the update.:)
Matrixx
Postby Casey [OP] » April 4th 2009, 2:05am
Ok, I'm an idiot. The low idle problem has been solved...by making sure the rear egde of the air box lid is properly located. I didn't slip the pins into the slots at the back edge of the lid after I had it off while replacing the EGR valve. It idles perfectly again.
Changed the trans fluid and filter and replaced a leaky heater valve, too.
Casey
Topics: 24
Year: 1995
It is currently June 28th 2017, 9:58am
Technical Information Forum
Date: Jun 09 '17
Time: 6:58pm
Date: Jun 09 '17
Time: 6:45pm
Nick
Date: Jun 09 '17
Time: 6:07pm
Comments: 0
Date: Jun 01 '17
Time: 4:14pm
Date: May 21 '17
Time: 7:47pm
