miss fires no codes
miss fires no codes
Postby rusty 1 [OP] » October 10th 2010, 5:54am
hello all : miss fires scan tool snapon . no sodes miss is different cylinder miss fire /cycle jumps to 255 on scaner new plugs cap rotor coil wires .
rusty 1
Years of Membership: rusty 1 has been a member for 2 full yearsrusty 1 has been a member for 2 full years
Topics: 9
Extra Info: 4.3l
Re: miss fires no codes
Postby astroturf » October 10th 2010, 1:24pm
Have you pulled and inspected the Distributor Gear?
astroturf
Years of Membership: astroturf has been a member for 3 full yearsastroturf has been a member for 3 full yearsastroturf has been a member for 3 full years
Topics: 112
Extra Info: 2wd Passenger
Postby mkj54 » October 10th 2010, 1:37pm
[quote][hello all : miss fires scan tool snapon . no sodes miss is different cylinder miss fire /cycle jumps to 255 on scaner new plugs cap rotor coil wires ./quote]
Not sure what you said, In '89 I don't think they gave misfire codes.
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: mkj54 has been a member for 2 full yearsmkj54 has been a member for 2 full years
Postby Mr_Bowtie » October 10th 2010, 1:41pm
Did it mis fire before you did the tune up? Got good BLUE spark at the coil? If its misfiring constantly I would try pulling a spark plug wire off the dizzy one at a time see if you can pinpoint which cyclinder it is. :shrug:
'96 Astro AWD 206K miles!
31" tires LIFTED 4" total with tires! SOLD! :(
'01 Crown Vic P71(not stock) 14.7@94mph
'97 Blazer 4x4 128K
'08 Town and Country Touring (wife's)
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full yearsMr_Bowtie has been a member for 4 full years
Topics: 69
Images: 8
Year: 1996
Extra Info: Lifted AWD
Postby rusty 1 [OP] » October 11th 2010, 1:11am
this is on a1997 5.7l . scan tool reads different cyl. dist.gear was fine 1000 mls. ago .when the new motor was installed .
rusty 1
Topics: 9
Extra Info: 4.3l
Postby Phantom » October 11th 2010, 1:22am
Does your Snapon tester read live data? is it telling you which different cylinders are misfiring? Does the scan tool read pcm as a 5.7 V8 reading all 8 cylinders to provide info on which cylinder is misfiring? Has it been misfiring the whole time after the swap ?
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby rusty 1 [OP] » October 11th 2010, 3:44am
the scan tool read it to be a 95 .dont know about a miss before the swap ,engine blown when bought .scaner reads all cyl. info ,miss all cyl. miss cycle jumps to 255 per cycle this is not normal , new thing to me .today changed comp. found a 97 prom and comp. needs more test drive but still miss 20 miles on new comp .does it take drive time to learn? new comp. in my area junk cars are 150 -350$ scrap makes it hard to find parts they seem to head rite to the crusher.
rusty 1
Topics: 9
Extra Info: 4.3l
It is currently June 19th 2013, 1:05pm
Technical Information Forum
Moderator: webcat
sadglad
Date: Mar 21 '13
Time: 1:29am
Date: Feb 22 '13
Time: 4:30am
Date: Feb 22 '13
Time: 4:18am
Attached by: rynik
rynik
Date: Jan 06 '13
Time: 4:31pm
Attached by: rynik
rynik
Date: Jan 05 '13
Time: 10:05pm
