Check engine light
Check engine light
Postby High & Dry [OP] » November 18th 2010, 5:56am
How do I reset the ECM to make a check engine light go out after making a repair?
High & Dry
Years of Membership: High & Dry has been a member for 6 full yearsHigh & Dry has been a member for 6 full yearsHigh & Dry has been a member for 6 full yearsHigh & Dry has been a member for 6 full yearsHigh & Dry has been a member for 6 full yearsHigh & Dry has been a member for 6 full years
Extra Info: AWD 6 inch lift
Re: Check engine light
Postby WoodButcher » November 18th 2010, 5:59am
Disconnect the battery.
WoodButcher
Firing on 6 Cylinders (L5)
Topics: 28
Images: 450
Alias (AKA): Bruce
Year: 1997
Extra Info: 4.3 RWD
Postby GaryZ » November 19th 2010, 3:17pm
The Gen 1 Astro is an 'ODB I' vehicle and disconnecting the battery for a few minutes should reset all Trouble Codes.
Codes on these models are read by counting the flashing 'Check Engine' light.
The Gen 2 is an 'OBD II' vehicle and a code reader is used to reset codes. Your local Autozone should do this for you.
I think codes up to p1000 are standardized by the Feds and the same on all vehicles 1996 and up.
BTW:
I decided to buy my own code reader (about $100) and have used it a lot. It's a good investment.
'98 Astro AWD, white with gray interior,
3.42:1 diffs, 235/70 x 15 tires,
195,000 miles on original engine and trans
'99 Kawasaki ZX11D
'85 Yamaha Venture Royale with 1300 engine & Vmax cams
GaryZ
Years of Membership: GaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full yearsGaryZ has been a member for 8 full years
Postby unrreal » November 19th 2010, 5:13pm
if the light has not gone out on its own after the repair and a few miles of driving then probably you didn't fix the problem, what was the code? and what did you repair?
unrreal
Years of Membership: unrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full yearsunrreal has been a member for 7 full years
Topics: 22
Images: 12
Year: 1999
Extra Info: 4.3L LS AWD
Postby High & Dry [OP] » November 23rd 2010, 4:49am
Had a crack in thr coil with spark leaking out everywhere. Replaced coil, engine runs fine, but light remain on. Only other possibility is that as it has got cold recently, my temp gauge seems to be low, around a quarter gauge. I dont have a reader, therefore I cant qoute a code.
Thanks
High & Dry
It is currently March 28th 2017, 8:41pm
Technical Information Forum
Date: Mar 10 '17
Time: 2:17am
Comments: 14
Date: Feb 28 '17
Time: 6:05pm
Comments: 14
Date: Feb 18 '17
Time: 10:24pm
Comments: 14
Date: Feb 18 '17
Time: 10:03pm
Comments: 14
Date: Feb 18 '17
Time: 5:30pm
