by astrobar [OP] » January 9th 2011, 11:15pm
by Phantom » January 9th 2011, 11:24pm
by JPDVAN » January 10th 2011, 12:32am
by astrobar [OP] » January 10th 2011, 2:00am
Phantom wrote:Try disconnecting the battery from the alarm , pull fuse , the manual should offer more tips.
Try starting with the wiring diagram and trace every wire one at a time to make sure that it does not cause a constant drain , a glove box light will run down a battery overnight , when you are sure that all is well with the wiring and think it is just the alarm , you may need to contact the company who makes it and ask them , and you might have a defective unit
by Phantom » January 10th 2011, 2:14am
by astrobar [OP] » January 11th 2011, 1:27am
Phantom wrote:I was referring to disconnecting the battery or fuse in order to find out if it is the alarm or maybe something else causing the drain ,
if you always had the alarm installed and did not have a drain problem , then maybe there is something that got pushed or a wire got chafed or is rubbing metal at the replacing of the battery , ,
is there any writing or markings anywhere on the unit that might be useful in identifying the model number ? might be able to find a diagram ,
what is it specifically doing that makes you think it is the alarm draining the battery, does it not stop sounding the siren? When you say it turned itself off , is that cause it drained the battery or does the battery still have power and how much and how are you determining all this ?
by JaxSPL » January 11th 2011, 3:16am
by 5customz » January 11th 2011, 4:09am
by JPDVAN » January 11th 2011, 5:07am
It is currently May 19th 2013, 2:45am
| Mobile Electronics Forum |
| Moderators: tedanderson, JaxSPL |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
