by longyard [OP] » June 1st 2011, 1:06pm
by JebusKrist » June 2nd 2011, 7:56am
by longyard [OP] » June 2nd 2011, 1:17pm
JebusKrist wrote:I think you've got a problem with your power wires of which you should have three a red, yellow and orange the red being 12v ignition wire which should only supply power when the van is running or the key is turned to the ACCessories position, yellow is your battery also known as constant wire which should always provide 12v and is used to keep your settings/time, and finally orange being the headlight dimmer wire. I'd make sure the red and orange wires aren't switched around or some other funny business especially if the radio is aftermarket more than likely it would be orange is switched with red, keep in mind these are aftermarket color codes and wont match the factory wiring. Good luck
Edit Clarification and cross reference:
On your van the headlight dimmer wire in the dash would be Gray and connect to Orange on an aftermarket deck, 12v ignition is yellow on stock GM wiring and red on the aftermarket decks, and the 12v battery or constant wire is orange on stock GM wiring but yellow for aftermarket decks. I suspect you've got an aftermarket deck in which case for power you would need GM Gray wired to Orange, GM Yellow wired to Red and the GM Orange wire would go to Yellow.
by Phantom » June 2nd 2011, 1:32pm
by JebusKrist » June 3rd 2011, 6:27am
It is currently May 22nd 2013, 11:58am
| Mobile Electronics Forum |
| Moderators: tedanderson, JaxSPL |
| Previous topic Next topic |
| Recent Image Attachments | |||
| Sponsors |
