sound deading roof/ trying to kill roof flex
Postby petergunz559 [OP] » August 3rd 2011, 1:14am
Hopes this is the right spot, A couple of months back I installed 2 18s in my 98 astro. Its sounded real good and hit really hard, now the roof sounds like poop. really bad, and the bass is covered through the rattles. I dampend the sides with spray foam and some fatmat. but sense I did that the roof sounds even worse. any strength the roof on a astro before? Im going outside in the heat in a bit to remove headliner. any tips n pics would be highly appreciated. thank you oh and if i remove the roof rack, would that make the roof weaker??
petergunz559
Years of Membership: petergunz559 has been a member for 1 full year
Alias (AKA): gunz
  • want to upgrade 2003 safari sound system
    by dale rex » February 2nd 2013, 7:50pm in Mobile Electronics
    Last post by 01Safari4.3 View the latest post
    March 14th 2013, 9:53pm
    80
    May 26th 2013, 3:41am
Re: sound deading roof/ trying to kill roof flex
Postby Phantom » August 3rd 2011, 1:46am
petergunz559 wrote:Hopes this is the right spot, A couple of months back I installed 2 18s in my 98 astro. Its sounded real good and hit really hard, now the roof sounds like poop. really bad, and the bass is covered through the rattles. I dampend the sides with spray foam and some fatmat. but sense I did that the roof sounds even worse. any strength the roof on a astro before? Im going outside in the heat in a bit to remove headliner. any tips n pics would be highly appreciated. thank you oh and if i remove the roof rack, would that make the roof weaker??
You need to use sound dampening material , something that absorbs noise and vibration, Depending how much power you are using it could be a big expensive task to get what you want , there is a tutorial on how Mr Singh did his van with like about 30 pics on how he built it ,,likely the most impressive van you'll see in any time soon ; the entire rear of van has like 18 large subs and can make a shirt DANCE , literally
This is his van , I am sure he can tell you anything you need to know , you can see/hear his system videos on you tube
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby petergunz559 [OP] » August 3rd 2011, 5:16am
Thank you!!!
petergunz559
Alias (AKA): gunz
Postby Mr Bones » August 3rd 2011, 5:40am
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Mr Bones has been a member for 2 full yearsMr Bones has been a member for 2 full years
Topics: 9
Alias (AKA): Papa Smurf
Extra Info: LS 4.3L V6 RWD
Postby JaxSPL » August 10th 2011, 2:43am
second skin audio sound deadener. Look at the sludge. It can be rolled or brushed on. It is thick and dries hard as hell. It's a little expensive, but well worth the price to get rid of the roof rattle (or any other rattle). If you're serious into audio, you'll want to get this stuff.
What I have found with my roof is the supports going across the width of the van came loose from the roof. Not sure how to get them back in place/shape to do any good.
You can also use, along with sludge, minimal expanding foam. Spray it along the supports, in between the roof and support. This will help out a lot and once you've gone over that with sludge.. you'll be hard pressed to hear a rattle from the roof in the areas you put it.
I Am Dennis / The Van Is Da Boom
Florida Sales Rep For GPI Subwoofers. PM For More Info
JaxSPL
Section Moderator
Section Moderator
Years of Membership: JaxSPL has been a member for 3 full yearsJaxSPL has been a member for 3 full yearsJaxSPL has been a member for 3 full years
Topics: 33
Extra Info: 4.3L V6 SPL
Postby paintdrying » August 10th 2011, 1:23pm
That second skin can also be sprayed on. They sell the gun for @30 dollars.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Return to Mobile Electronics
It is currently May 26th 2013, 3:41am
Mobile Electronics Forum
Moderators: tedanderson, JaxSPL
Comments: 13
Date: May 24 '13
Time: 2:02pm
Date: May 21 '13
Time: 12:06am
Attached by: aztec1987
aztec1987aztec1987 is online!
Comments: 21
Date: May 17 '13
Time: 5:26am
astroman97
Date: May 13 '13
Time: 3:55am
Attached by: Jasen
Date: May 01 '13
Time: 5:19am
Users browsing this forum: pei astropei astro is online! and 3 guests
