Anyone made a Double-Din fit?
Postby KSMatic [OP] » April 30th 2012, 11:52am
I have a 2003 GMC Safari and the slot where ther radio goes doesn't fit a double-din, at least from what I can see. Anyone tried to make a double-din fit without much modification? Do they sell kits like the whole dash plate to make it work? I'm trying to brain storm here, if not, I may just try to modify the whole piece and make it in to an ipad mold and relocate the AC controls somewhere else.
KSMatic
Years of Membership: KSMatic has been a member for 2 full yearsKSMatic has been a member for 2 full years
Alias (AKA): Kevin
Extra Info: V6
  • my double din attempt
    by astroman97 » May 13th 2013, 4:03am in Mobile Electronics
    Last post by TaxiVan View the latest post
    May 13th 2013, 10:38pm
    53
    May 25th 2013, 11:02am
Re: Anyone made a Double-Din fit?
Postby tedanderson » April 30th 2012, 10:46pm
Are you referring to the actual mounting area inside of the dash or the trim piece that surrounds the radio?
tedanderson
Firing on 5 Cylinders (L3)
Years of Membership: tedanderson has been a member for 3 full yearstedanderson has been a member for 3 full yearstedanderson has been a member for 3 full years
Topics: 62
Alias (AKA): 2Big4aMiniVan
Postby chevymaherchevymaher is online! » May 1st 2012, 12:23am
Here is a thread where they made one.
viewtopic.php?f=127&t=8968&p=133054&hilit=din#p133005
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby KSMatic [OP] » May 2nd 2012, 7:32am
tedanderson wrote:Are you referring to the actual mounting area inside of the dash or the trim piece that surrounds the radio?
I looked at the inside with the dash removed, it seems that I would have to relocate the A/C controllers in order for the double-din to work. Which also means that I would have to modify the dash as well for it to work.
This is how my dash looks like. Just debating if I want to go through the trouble of doing a double-din, or just get a single-din with a roll out LCD display.
Reason I want to change out my stock radio because my lights are out on it and it doesn't accept AUX stock and had to buy another module to do so.
KSMatic
Alias (AKA): Kevin
Extra Info: V6
Postby Chevymankevin » May 3rd 2012, 3:28am
You could always get a pop up display unit without moding the dash.
http://www.kalogeropoulos.gr/LH2Uploads/ItemsContent/4391/4_resize.jpg
:auto-gmcredsmiley: 95 Safari Daily driver 185K
83 Monte Non SS Its better than SS! Sunday driver/project
Chevymankevin
Years of Membership: Chevymankevin has been a member for 1 full year
Images: 31
Year: 1995
Extra Info: SLX CPI RWD
Postby Shad0wXCalibur » May 3rd 2012, 4:23am
Chevymankevin wrote:You could always get a pop up display unit without moding the dash.
Don't like those nearly as much as a one piece double din unit. I wish these vans could fit a double-din correctly without modding, also.
1987 Astro
2000 Safari
Shad0wXCalibur
Firing on 1 Cylinder (L2)
Years of Membership: Shad0wXCalibur has been a member for 1 full year
Topics: 35
Extra Info: Lifted 2wd
Postby KSMatic [OP] » May 3rd 2012, 4:30am
I thought of that but I liked the full piece without having it move out as it blocks my AC controller and etc..
KSMatic
Alias (AKA): Kevin
Extra Info: V6
Postby KSMatic [OP] » May 3rd 2012, 4:35am
Looks like this is my goal :) Found this pic so its possible
KSMatic
Alias (AKA): Kevin
Extra Info: V6
Postby Shad0wXCalibur » May 3rd 2012, 4:58am
Sweet. I like the way that looks.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 35
Postby paintdrying » May 3rd 2012, 5:11am
If you were to do this you could keep everything together'
http://whitetrashrepairs.com/white-tras ... o-install/
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby DGE73 » May 16th 2012, 2:04am
I have a 2 DIN head unit in mine. There is just enough room for everything. Watch out for deep 2 DINs, they won't fit flush without modifying the defrost duct.
2DIN
Needs a nicer trim plate
Use it to run my 2 screens
03 Astro RWD 165k 2DIN, 2 rear screens, tow pack, Timbrens, lock diff, YokoGeo ATS, No Dexcool
96 Safari RWD sold @ 210k, retired as Florida RV
94 Safari swb RWD scrap @ 240k
DGE73
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: DGE73 has been a member for 1 full year
Year: 2003
Extra Info: RWD with Tow Package
Postby jrsride2002 » May 16th 2012, 5:10am
DGE73 wrote:I have a 2 DIN head unit in mine. There is just enough room for everything. Watch out for deep 2 DINs, they won't fit flush without modifying the defrost duct.
DUDE!!!!!!!!!!!!!
HOW?!?! BUT.... WAIT!!???!!!?? I MEAN!!!!!!!!!....... DUDE!!!!!!!
That looks *****!!!!!!!
How did you do the trim around the unit?! Did you or a shop do it?! Looks AWESOME!!!!!!!!!!! :shock: :shock:
Which head unit? How deep is too deep? I haven't dug into it yet cause im just researching, but that looks freakin bad A$$!!!!!!! :bow:
Im looking to use a unit w/o a plate around the unit like there would be on a single DIN, and on top of that im designing it myself and doing the work myself. Lots of youtube videos to watch.. :shrug:
Hey with the after market unit, can you still use the secondary unit(behind driver for middle bench) Is that a topic already covered? Ive searched but maybe im just looking it up wrong...
Any and all info is much appreciated,
~Junior
E-Fan mod(Ford mystique/contour), 1" radiator swap , external trans AND oil coolers (2)Flex a lite 3826, three piece bed bench installed, firestone air bag helpers
jrsride2002
Years of Membership: jrsride2002 has been a member for 3 full yearsjrsride2002 has been a member for 3 full yearsjrsride2002 has been a member for 3 full years
Images: 13
Alias (AKA): Junior
Year: 2001
Extra Info: LS V6 RWD
Postby DGE73 » May 16th 2012, 9:59pm
I installed the Pioneer AVH-P3200BT using a single din install kit that I hacked up and bolted to it. Once I had that figured out it was easy. There is about 1/4" above the unit for cooling, just enough space behind to connect all the wires, and the bottom just clears the metal cross bar below the stereo. I just notched the stock beige trim panel above and below the stereo's face with a grinder and smoothed it with a mini file. It still comes out just like the factory stereo.
DGE73
Fueling (1/2 tank)
Fueling (1/2 tank)
Year: 2003
Postby draganjr » November 12th 2012, 7:25pm
I am having mine installed today! Will post pictures when I am done.
draganjr
Topics: 7
Alias (AKA): draganjr
Year: 2005
Postby draganjr » November 14th 2012, 1:55am
Here goes mine.
Sorry for the bad photos, my brother was driving my car and he took the photos.
draganjr
Topics: 7
Year: 2005
Postby mervchapman » November 14th 2012, 3:45am
I swapped the AC controls and my double DIN so that the Radio is up top. Check out the download/file.php?id=15312&mode=view for a pic.
mervchapman
Years of Membership: mervchapman has been a member for 3 full yearsmervchapman has been a member for 3 full yearsmervchapman has been a member for 3 full years
Topics: 10
Year: 2001
Extra Info: LT AWD 5.7L V8
Postby hugor » November 15th 2012, 10:57am
draganjr wrote:Here goes mine.
sounds great, how much does it cost? is there anything missing after installation of this unit?
hugor
Year: 2003
Extra Info: 4.3L
Postby grandnany88 » March 18th 2013, 6:44am
yeah i am also wana the same question dude...plzz explain me more..m still confuse. :confused:
grandnany88
Year: 1988
Return to Mobile Electronics
It is currently May 25th 2013, 11:02am
Mobile Electronics Forum
Moderators: tedanderson, JaxSPL
Comments: 13
Time: 2:02pm
Date: May 21 '13
Time: 12:06am
Attached by: aztec1987
aztec1987
Comments: 19
Date: May 17 '13
Time: 5:26am
astroman97
Date: May 13 '13
Time: 3:55am
Attached by: Jasen
Date: May 01 '13
Time: 5:19am
