I have been asked about this a few times because of my signature, so I figured I should just do a simple thread about it.
The Strobes I have mounted around my van are from Tomar, they are high intensity strobe lights, non-LED.
I have Two mounted up front right next to the High Beam bulbs, Two are mounted in the Side Marker lights which were previously Empty, Two mounted next to the rear break light bulbs, and Two 3"x4" Rectangular Amber Box's(Strobe not Halogen) located in the rear hatch at the bottom right and left corners.
Switches(From top to bottom)
*Amber 3"x4" boxes in rear hatch corners
*Rear brake light Strobes
*Front Strobes(Two in with the bright location, and two in the unused corner markers)
*Flash Rate Controller (Pursuit/Takedown)
(there is actually a 5th switch located under the dash that controls the Intensity, but I barely ever flip that one so didn't see a need for it to be readily accessible)
Control Box for Front's and Rear Taillights
Wiring Running to box
See the control box is normally mounted under the passenger seat on the rear support bar.
You can't see them when they are off in the rear window.
But when they are on they are really visable. (Those are just the strobe's lighting up those tail lights, they flash so fast and bright it messes with my camera, I can't take video of it either as the frame rate is not high enough for the flash)
