You heard it correctly folks! This is the easiest and the absolutely cheapest way to install a sub woofer and amp.
I know, and knew while and before installing, that people will be on my case about the two wires I used. Just read through and find out my results!
Other than the sub and the amp (which I didn't really pay for anyways...bartered a detail gig for amp...borrowing sub from dad until I get a new HU to support bigger subs) the install was COMPLETELY FREE!!! It might not be completely free for you though...I just happened to have ALL of the materials lying around in my house and my friends house...this was done over the summer right before school started up again.
Here's what I used:
One old and useless extension cord (had one end popped off and friend's dad was throwing it away)...this is my power cord
4-5 feet of Cat5 cable...this was used for my RCAs
I would make a tool list but the tools you use will vary based upon how your needs.
First step: Deal with your RCA cable
If you don't have an RCA cable then FUCK IT! Make one! My friend is in IT and has a spool of Cat5...why not go to him? We used some solder-on RCA connectors he had in one of his parts drawers. We soldered the ends onto the cable. The cable is roughly 4 feet long and it the perfect size to hook the amp up underneath the driver's seat. There are 8 smaller cables that make up the cat5. We used 2 smaller cables for each connection on each plug...2 for '+' 2 for '-' for each port, left and right.
Second step: Deal with your power cable
Now that you have your RCA cable, time to make your power cable worthy of using. Get as much as you need of it and punch/drill a hole through your firewall. I already had a hole in the firewall. I have NO idea who made the hole, but FUCK IT! I USED THAT BITCH!
Disconnect your battery at this point.
Run the cable through your hole and keep it away from view. In the bay I ran it around the front of the battery, side then behind the battery. This was done to keep minimal slack within all of those moving parts! DO NOT FORGET YOUR GROMMET! This is VERY important. Otherwise you run the risk of vibrations and the tug and pull battle between your engine bay and cabin will tear your cable to shreds and send a nice "thank you" through the body and frame of your A/S. Avoid all of this with a grommet. Mine isn't installed in the picture but was definitely installed by the end of this whole thing.
Since the power cable came out near the column I just slid it underneath the carpet, to the driver's kick panel and right down to the step on the driver's side.
Now you have to hide the power cable in the rest of the van. Since I ran it on the left side of the vehicle I popped off the molding to the step and ran it through the existing bunch of wires. Run it all the way through the molding to end up right behind the driver's seat.
This is the cable starting to go through the cluster. To open the cluster, you have to push down and away on the top of the cluster, or kind of angle a flat head in towards you, pull towards you and tilt away…you'll get it once you see it! DO NOT open the holder like a door (that bitch don't got no hinges!), you HAVE to slide the cables into the cluster or else you risk breaking the holder. Then you'll have to deal with all those cables.
Third step:
Back to that RCA Cable
I went ahead and plugged the RCAs into the head unit and ran it through the back of the head unit and down towards the driver's pedals (shown in above picture). If you have problems with getting the cable through to where it's shown in the pic, take the doghouse off. You'll be able to simply reach in through the back of the stereo bracket and grab that fucking wire.
Same shit, different wire. Run the RCA cable down alongside the power cable and through the same cluster.
This is where the cables come out, right behind the driver's seat. The location is GREAT for installing the amp underneath the driver's seat. By the way, I didn't use a remote wire; I did something easier and more practical for my use. Find it below…
Forth step:
Go ahead now and plug your amp up, make sure your battery is still disconnected. Plug in the power, and the RCAs.
This is for your ground. Trust me, it is THE BEST place to ground the amp if under your seat. I mean its RIGHT THERE! I tested for continuity between the dirty nut, and the driver's doorjamb. Be sure the nut is free of dirt or oil…mine was COVERED in it. I used a wire brush and sand paper to polish up the contact side. Test for continuity one last time through the amp ground port and the doorjamb, if it passes…you're good to go!
I decided to install a switch on the amp. This way I can turn it on and off whenever I'd like to. Sometimes I don't want to blast my eardrums…other times I do…
And yes… that is the switch to a ceiling fan. You thought I was lying about this all being free, huh? Plus I'm keeping in tune with the whole "I drive a 1986" attitude! hahaha
And for the end results...The sound is amazing! The sub sounds great and the power is nice. I really need to upgrade my head unit though. I bought this older model (new in box though) cassette player for $8 off of some lady from Craigslist. People always, and people will, complain to me about using Cat5 cables, but honestly...its only 4 feet of cable. If I were running 100 feet, then I would have a problem. The power cable too, people might say its a bad idea. There are three smaller cables within the power cord and I used two for the power and all three for the ground. I calculated the amount of current I will be drawing, and the power cable is more than capable of meeting my needs. And that's just considering using 2/3 of the cable! Don't even mention using the entire thing!
So, you might not HAVE to do this the cheapest possible way, but...I do and just though I'd let you know how I did it. I'm very happy with the system. There is no feedback and people don't even know I cheaped out when they hear the quality.
Let me know what you think!!!
:feedback: :feedback: :feedback:
I needed a brewsky after this one... :cheers:
Here's what I used:
Third step:
Forth step:
