NITRO BMW 2-WAY ALARM
Postby djclent [OP] » November 11th 2010, 1:25am
I NEED HELP REALLY BAD IM TRYING TO INSTALL A NITRO 2-WAY ALARM AND I DNT UNDERSTAND THE WIRING PAGE 7 I REALLY NEED HELP VERY BAD PLEASE CAN SOMEONE HELP ME
https://mail.google.com/mail/?ui=2&ik=7 ... ion/pdf&zw
djclent
Years of Membership: djclent has been a member for 6 full yearsdjclent has been a member for 6 full yearsdjclent has been a member for 6 full yearsdjclent has been a member for 6 full yearsdjclent has been a member for 6 full yearsdjclent has been a member for 6 full years
Extra Info: v6 rwd
  • Factory alarm?
    by djcat » January 8th 2017, 11:49am in Mobile Electronics
    January 9th 2017, 10:55pm
  • Explain my alarm to me please
    by fourwheelwheelie » October 2nd 2016, 5:47pm in Mobile Electronics
    Last post by fourwheelwheelie View the latest post
    October 2nd 2016, 11:51pm
    41
    March 25th 2017, 5:04am
Re: NITRO BMW 2-WAY ALARM
Postby Phantom » November 11th 2010, 2:10am
If you post a diagram , then maybe someone can help you with your questions.
Phantom
Firing on 7 Cylinders (L4)
Postby djclent [OP] » November 11th 2010, 2:15am
DIAGRAM
HERE IT IS
djclent
Extra Info: v6 rwd
Postby webcat » November 11th 2010, 3:23am
You did'nt say what you dont understand about it , there's alot of stuff in that diagram!
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby djclent [OP] » November 11th 2010, 3:44am
In the diagram, I can't figure out how to hook up the alarm. can you tell me what wires connect to the wires in the ignition harness?
djclent
Extra Info: v6 rwd
Postby djclent [OP] » November 11th 2010, 3:52am
im completely lost because when i hook it up the car trys to turn over but never does and the doors wont lock and the alarm wont arm and disarm i kno im messing up really bad lol can u please help me
djclent
Extra Info: v6 rwd
Postby djclent [OP] » November 11th 2010, 4:25am
:banghead: :screaming: :confused: :crying: :shrug:
djclent
Extra Info: v6 rwd
Postby JaxSPL » November 11th 2010, 11:43am
1998 Chevy Astro alarm/remote start wiring
Constant 12V+ Red (2) Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 Brown Ignition Switch Harness
Ignition 3 White Transmission, Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White ECM behind Battery
Brake Switch White Brake Switch
Trunk Release Green Driver's Kick Panel or Dash Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Brown (+) In White Junction Connector at Firewall
Head Lamp Yellow (+) Light Switch
Factory Disarm Light Green Driver's Kick Panel
Door Trigger Purple (-) In White Junction Connector at Firewall
Door Lock Light Blue (+) Driver's Door Boot or at OEM Relays PASS
Door Unlock White (+) Kick Positive Trigger
Horn Wire Black (-) Steering Column
Windows Up LF=Dark Blue, RF=Blue/White
Windows Down LF=Brown, RF=Tan
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Section Moderator
Section Moderator
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full yearsJaxSPL has been a member for 7 full years
Topics: 46
Images: 9
Extra Info: 4.3L V6 SPL
Postby djclent [OP] » November 11th 2010, 5:15pm
so can you tell me what goes to what please thank you
djclent
Extra Info: v6 rwd
Postby Phantom » November 11th 2010, 6:16pm
Installs like these do take time , there are a variety of installs , when installing these type systems I use a DVD that has hundreds of vehicles to be installed on , If you can wait a week or so I can dig it out and find which is yours , but in the mean time you should probably take the info that JaxSPL has provided and write it down on paper then study both it and your wiring diagram and write out some sketch diagrams that use the combined info , start out with where the power connects and then the grounds and then 1 by 1 study where each wire on the unit goes and compare it to the wiring info on the van , it will take time but just go one at a time and you'll get there . :)
Phantom
Postby djclent [OP] » November 11th 2010, 6:27pm
im not trying to be lazy but i just cant get it i dnt kno why i tried everything but i will try the matching on paper but i hope someone can post a finished diagram of the alarm hooked up to the car wires so i could compare
djclent
Extra Info: v6 rwd
Postby djclent [OP] » November 11th 2010, 7:32pm
is this correct???????
----------6P-----------
green to orange
green #2 to brown and 86 relay
red to red
gray to yellow and 87a relay
black to body of car
white to yellow
white to brown
----------6p------------
white ?
brown?
yellow?
blue?
orange?
purple?
-----------8p-----------
white to speaker
brown n/a
yellow to 85 relay
blue to purple
orange to light blue????
purple ?
green ?
gray ?
where does the 30 go from the relay
car wiring
alarm wiring
djclent
Extra Info: v6 rwd
Postby djclent [OP] » November 12th 2010, 2:57pm
can some one please help me???????????????????
djclent
Extra Info: v6 rwd
Postby djclent [OP] » November 12th 2010, 2:58pm
pleeeeeeaaaaaaaaassssssssseeeeeee???????????????????????????
djclent
Extra Info: v6 rwd
Postby webcat » November 12th 2010, 5:07pm
webcat
Topics: 253
Postby djclent [OP] » November 13th 2010, 9:12pm
The second harness i believe goes to the Central Door Locking System. Where is that located ? a
And Parking Lights Brown (+) In White Junction Connector at Firewall
djclent
Extra Info: v6 rwd
Postby webcat » November 13th 2010, 10:01pm
djclent wrote:The second harness i believe goes to the Central Door Locking System. Where is that located ? a
drivers side door lock switch ,,, there is about 5 or 6 wires going to the drivers side door lock switch but you only need to find one white one and one blue one .
You can look on this Viper alarm schematic to get a idea how to wire your door locks
webcat
Topics: 253
Postby webcat » November 13th 2010, 10:08pm
This second harness has 6 wires coming out of it , you'll only need 2 of them ,, one for locking and the second one for unlocking ,, you need to find out which 2 you need!
webcat
Topics: 253
Postby webcat » November 13th 2010, 10:14pm
I noticed on the second harness there's a white wire and a blue and then 4 others ,,, you may be able to hook white to white and blue to blue
webcat
Topics: 253
Postby djclent [OP] » November 13th 2010, 10:17pm
Thanks so much, I'll give it a try. My mom is trying to help me ...... she's driving me nuts ! :confused: posting.php?mode=reply&f=32&t=9667#
djclent
Extra Info: v6 rwd
Return to Mobile Electronics
It is currently March 25th 2017, 5:04am
Mobile Electronics Forum
Moderators: JaxSPL, tedanderson
Date: Feb 26 '17
Time: 5:31pm
ironhead79
Date: Jan 24 '17
Time: 8:44pm
Comments: 36
Date: Jan 19 '17
Time: 5:29am
Comments: 22
Date: Jan 16 '17
Time: 6:16pm
Comments: 22
Date: Jan 16 '17
Time: 3:36am
