94 heater core change
Postby alexalexanders [OP] » December 22nd 2010, 2:25am
How hard is this to do? Is there a write up on this? A friend gave me a heater core that new had left over from his van, and mines needs flushed so i was just gonna replace it instead since i have a brand new one. Btw its the front heater core on a no rear air van.
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full yearsalexalexanders has been a member for 7 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
  • Rear heater core bypass
    by stev30h » January 22nd 2017, 7:26pm in Climate Control
    Last post by Lumpy View the latest post
    February 5th 2017, 6:14pm
  • evaporator core housing
    by pannebreaux » April 2nd 2017, 12:33pm in Climate Control
    Last post by Don1806 View the latest post
    April 19th 2017, 12:36am
    35
    May 23rd 2017, 9:49pm
Re: 94 heater core change
Postby Phantom » December 22nd 2010, 3:17am
Try the search function , I remember someone giving instruction on this , like a panel on the right side that comes down making it easy
Phantom
Firing on 7 Cylinders (L4)
Postby offroad safari » December 22nd 2010, 3:36am
i did it on my 90 safari, it took about 30 minutes. remove the glove box, remove the black cover near the passenger's footwell, unbolt the heater core, remove the hoses and pull out the heater core. then reverse the process. the bigger problem is getting the air pocket out of the heater core.
'90 AWD Shorty Safari
4" Overland Lift + countless mods
"It's a Safari thing.... Jeep people couldn't understand"
offroad safari
Years of Membership: offroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full yearsoffroad safari has been a member for 7 full years
Topics: 18
Alias (AKA): Witman40
Extra Info: AWD Shorty
Postby alexalexanders [OP] » December 22nd 2010, 4:01am
Uhhh...dumb question but what do you mean about air pocket?
2000 GMC Safari SLE
alexalexanders
Topics: 80
Postby offroad safari » December 22nd 2010, 4:12am
I have found that when the cooling system is drained or taken apart in this case, air tends to get trapped in the heater core because its the highest part of the cooling system.
offroad safari
Topics: 18
Postby gtkane » December 22nd 2010, 4:18am
If it just needs to be flushed, why don't you just flush it?
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full yearsgtkane has been a member for 9 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby alexalexanders [OP] » December 22nd 2010, 4:47am
gtkane wrote:If it just needs to be flushed, why don't you just flush it?
Well i havent decided for sure which ill do, i was thinkin if it was a super easy fix, id just throw the new heater core in but it seems that a flush would just be easier and to just keep the new core to replace later if it need/when it needs it.
2000 GMC Safari SLE
alexalexanders
Topics: 80
Postby fast68 » December 26th 2010, 8:38am
make sure heater control valve isnt stuck, under hoods in heater hose
or blend door isnt stuck or broken, inside heater box under dash
both will cause low or no heat
when engine is hot are both core hoses same temp, both hot?
if not then core is plugged or valve is stuck shut
if are both hot then core is not plugged and valve is not stuck shut
door in box stuck or control panel not changing positions, check vacuum source from engine to control panel assembly, black small hose line
fast68
Years of Membership: fast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full yearsfast68 has been a member for 8 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Return to Climate Control
It is currently May 23rd 2017, 9:49pm
Climate Control Forum
JawonJawon is online!
in Climate Control
Comments: 18
Date: Today
Time: 7:45pm
Rinny
in Climate Control
Date: May 19 '17
Time: 6:28pm
Attached by: GreatWhite
GreatWhite
in Climate Control
Date: May 19 '17
Time: 5:49pm
in Climate Control
Comments: 18
Date: May 18 '17
Time: 9:24pm
in Climate Control
Date: May 17 '17
Time: 10:18pm
Users browsing this forum: JawonJawon is online! and 3 guests
