Installing rear a/c when not originally equipped
Postby Cumminsnut12 [OP] » July 12th 2016, 1:02am
I've got a 2000 Astro conversion van which did not originally come equipped with rear hvac. I also have a regular 2000 Astro for a parts vehicle which has rear a/c and everything is intact. What all is involved with installing the rear hvac onto my conversion Astro from the parts Astro.
Cumminsnut12
Year: 2002
  • Installing AC on 04 w/o it
    by juststartin » December 19th 2016, 8:09pm in Climate Control
    Last post by Lumpy View the latest post
    December 26th 2016, 10:43pm
  • Rear AC/ REAR heat switch swap
    by Rookie162 » January 28th 2017, 6:47pm in Climate Control
    January 29th 2017, 5:22am
    20
    February 24th 2017, 9:00am
Re: Installing rear a/c when not originally equipped
Postby chevymaher » July 12th 2016, 1:31am
If you got to ask and you got the van with it. Then just think the most horrible long involved ordeal known to man.
Topics: 81
Year: 1994
Postby redfury » July 12th 2016, 2:28am
Well, plumbing. If you are installing a factory system, integrating it from one van to the other is just going to be about TIME. And of course, how the outfitter dealt with the interior bits at the back of the van that you are going to want to put in it. Plumbing the A/C lines is probably going to be the most tedious part. Pull the system out of the donor van and reassess whether you want to reverse engineer it into the conversion van. All the holes are going to be stamped into the body or at least you will know the size and locations of them all. You have the best possible chance of making it happen...if you have the TIME.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Year: 1998
Extra Info: LT 5.7L 4wd
Return to Climate Control
It is currently February 24th 2017, 9:00am
Climate Control Forum
Rookie162
in Climate Control
Comments: 34
Date: Feb 22 '17
Time: 2:07am
Rinny
in Climate Control
Comments: 28
Date: Jan 23 '17
Time: 2:40pm
Comments: 29
Date: Dec 22 '16
Time: 2:51am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:21am
Colorado Tim
in Climate Control
Date: Dec 15 '16
Time: 5:18am
