More heat now - how? rad cap!
Postby Vinnie6 [OP] » February 25th 2011, 11:52pm
I wanted to make sure of something before I created this thread because I run the risk of being soundly ridiculed. However, after a week of testing, I am confident to declare something that sounds absurd. I replaced my radiator cap. I took off the aftermarket stopsign shaped metal 16 lb cap and put on a new original equipment ACDelco round black plastic 15 lb. radiator cap. My cabin heat has increased (quite a bit, actually) as a result! I cannot explain the correlation. I'll leave that to the experts. I would be very curious to know myself. But now I find myself sliding the heat blend knob a click or two off full hot even with the fan on low with it 20 degrees f outside. I invite others with heat problems to also try this $13 experiment and see if you have similar results.
Vinnie6
Years of Membership: Vinnie6 has been a member for 3 full yearsVinnie6 has been a member for 3 full yearsVinnie6 has been a member for 3 full years
Topics: 13
Extra Info: LS RWD
  • Can I add rear heat?
    by Ragenme » November 27th 2012, 6:51pm in Climate Control
    Last post by redfury View the latest post
    November 30th 2012, 5:08am
  • Heat/cooling issues
    by Bxsplicer » March 31st 2013, 10:36pm in Climate Control
    April 1st 2013, 2:30am
    39
    May 25th 2013, 12:19am
Re: More heat now - how? rad cap!
Postby chevymaherchevymaher is online! » February 26th 2011, 12:02am
Vinnie6 wrote:I wanted to make sure of something before I created this thread because I run the risk of being soundly ridiculed. However, after a week of testing, I am confident to declare something that sounds absurd. I replaced my radiator cap. I took off the aftermarket stopsign shaped metal 16 lb cap and put on a new original equipment ACDelco round black plastic 15 lb. radiator cap. My cabin heat has increased (quite a bit, actually) as a result! I cannot explain the correlation. I'll leave that to the experts. I would be very curious to know myself. But now I find myself sliding the heat blend knob a click or two off full hot even with the fan on low with it 20 degrees f outside. I invite others with heat problems to also try this $13 experiment and see if you have similar results.
Mine had a similar cap and radiator was always low.Put on stock cap now it not puking into overflow tank radiator stays full.Maybe it was air bubbles in heater core.Just a thought.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby fast68 » February 26th 2011, 4:12am
the rad cap function is very important
you gotta have that 15 or 16 psi pressure in the system
it will help cool the engine as well
water under pressure cools better
replace the cap every couple years and use a good one not a cheapo one
if you can squeeze rad hose when engine is hot then the cap is failed or you have a leak somewhere
1992 Astro EXT parting out! many new parts! new regulators, heater core, ECM, etc. text me 217 671 7792 parting: '91 S-10 2wd pickup , '70's chevy trucks, '54 ford truck dually, '69 fairlane, '80s toyota trucks,
fast68
Years of Membership: fast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full yearsfast68 has been a member for 4 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Return to Climate Control
It is currently May 25th 2013, 12:19am
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
