pag oil
pag oil
Postby justinf89 [OP] » March 3rd 2011, 2:03am
I'm installing my new recon compressor this weekend and I'm not sure whether to use pag 46 or 150 oil. Everywhere I find on the internet says pag 150 for gm compressors but when I spoke to the guy I got it from, he says pag 46 is better for the seals. The compressor is a 4-seasons reman unit. Anybody know what oil I should use? Thanks!
justinf89
Years of Membership: justinf89 has been a member for 3 full yearsjustinf89 has been a member for 3 full yearsjustinf89 has been a member for 3 full years
Topics: 33
Extra Info: RWD
Re: pag oil
Postby kennyj » March 3rd 2011, 2:19am
The recommended oil for your compressor is pag 150.
Your compressor should have come pre-filled with oil, with instructions on how much to remove if necessary. Did you measure the oil from your old compressor?
kennyj
Firing on 8 Cylinders (L1)
Years of Membership: kennyj has been a member for 3 full yearskennyj has been a member for 3 full yearskennyj has been a member for 3 full years
Topics: 33
Alias (AKA): Kenny
Extra Info: RWD 183k miles
Re: pag oil
Postby chevymaher » March 3rd 2011, 2:46am
Just seems like a trick question.Compressor comes with lube.Refrigerant can be bought with lube in it.I went to college for this and my teacher was a hard case.All the tricks in the book trying to prepare you for any eventuality. just use what it calls for.I been doing this a long time and the only seal I ever had leak is front compressor seal they just wear out eventually.From friction of moving parts.Most of the time it acids inside from never servicing it.no one ever empties system replaces dryer and pulls vacuum to rid system of acids moisture and they still last 15-20 years.Sorry I just confused here. :confused:
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Re: pag oil
Postby justinf89 [OP] » March 3rd 2011, 2:53am
Forgot to mention compressor was shipped dry. I didn't measure the oil.
justinf89
Topics: 33
Extra Info: RWD
Re: pag oil
Postby Leeann_93 » March 3rd 2011, 2:55am
PAG 150.
When you remove your old compressor, pour out the oil into a measuring cup. Put that much oil into the new compressor.
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Re: pag oil
Postby justinf89 [OP] » March 3rd 2011, 3:02am
The compressor thats in it now never ran. I pulled it from my parts van and the seals leaked on it. Measuring its oil would be useless. I figured since I'm putting in a dry compressor and receiver, i'd put in about 8oz out of the 11oz spec'd for rear ac system.
justinf89
Topics: 33
Extra Info: RWD
Re: pag oil
Postby chevymaher » March 3rd 2011, 3:05am
The rest of the system will have it in it still so not knowing what was actually in old compressor hurts.3 oz should still be in accumulator.An oz (guess)Foating in rest of lines and such.8 oz is the total you should have in there.Hope that helps some.EDIT I read your next reply that sounds about right.I did not know when I wrote first part about rear air.
Topics: 50
Images: 92
Year: 1994
Re: pag oil
Postby kennyj » March 3rd 2011, 3:10am
8 ounces should be about right. Put half of your oil in the compressor, the other half in your new accumulator (receiver).
Did you get a new orifice tube? (about $3)
kennyj
Topics: 33
Alias (AKA): Kenny
Re: pag oil
Postby justinf89 [OP] » March 3rd 2011, 3:12am
The kit came with all three. Thanks for the help. I guess the 150 oil I got was the right one after all.
justinf89
Topics: 33
Extra Info: RWD
Return to Climate Control
It is currently May 20th 2013, 10:34am
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
