Temp gauge not registering
Postby knelsonhfs [OP] » April 21st 2011, 8:01pm
Hi Guys
Back with another issue.
Have been trying to figure out why my temp gauge shows nothing when warm or hot.
I turn on the ingn. and the gauge maxes out then disappears (Bar graph style ((digital?))
I have replaced the water pump and t-stat as well as the temp sensor at the t-stat housing and still nothing
Radiator and heater core hoses all are hot
Good heat to the heater control box ( issues there but ill wait to post those :? _
I know there are 1 maybe 2 more temp sensors. One located on the drivers side of the block just below the valve cover and the other on the P side by the dip stick
Are either one on those responsible for sending that signal to the temp gauge?
does the computer send the signal is the gauge itself bad any ideas
thanks ya'll
1993 AWD Astro 4.3L W
188.5K
bad paint
bad tires
bad attitude
knelsonhfs
Years of Membership: knelsonhfs has been a member for 2 full yearsknelsonhfs has been a member for 2 full years
Alias (AKA): knelsonhfs
Extra Info: LT 4.3 AWD W
  • Temp gauge reads low. (I think)
    by thegreenmachine » January 28th 2013, 3:00pm in Climate Control
    Last post by vangogo View the latest post
    January 29th 2013, 6:29pm
    May 24th 2013, 11:14pm
Re: Temp gauge not registering
Postby paintdrying » April 21st 2011, 8:34pm
Not exactly sure on the astro, I would pull the wire off the one you suspect is the bad sensor and ground it to the block, if the gauge pegs you know it is the sensor. What I do is pull the sensor then go down to the parts store with my multi meter and compare the reading between the new sensor and the old. Then try and figure what the heck the readings actually read. Sounds like you need to replace the other sensor.
paintdrying
Years of Membership: paintdrying has been a member for 2 full yearspaintdrying has been a member for 2 full years
Topics: 94
Extra Info: 108 000
Postby RECox286 » April 21st 2011, 9:01pm
OK. Gages 101:
There are two temp sensors on the everlovin' 4.3. The sensor that you changed sends info to the computer. The other that sends info to the gage is on the drivers' side head in between spark plugs # 3 and 5.
Check to see if the wire is attached, or broken. You can check to see if the sender is bad by taking the wire off the sender, Key On Run, gage should show FULL COLD, then touch the sender wire to a good ground, and
the gage should show FULL HOT.
Happy hunting. Let us know what you find and how you make out.
Bob
RECox286
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Return to Climate Control
It is currently May 24th 2013, 11:14pm
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
