'90 Safari - Missing heater ductwork?
Postby 98cirider [OP] » May 13th 2011, 4:08pm
I was browsing through my Service Manual and noticed a diagram (see first picture below) of some ductwork that comes from under the dash, down over the doghouse and into the cabin. My Safari does not have this, and never has to my knowledge.
In the last decade that i have been doing all my maintenance and repairs, I have wondered why there is an open section in the ducting under the dash, (see the second picture below). We've never gotten cold in the van, but we have lived in Phoenix for quite some time, so using the heater is rare.
Am I missing some ductwork? I mean, is there any possible reason it should have been removed?
Or did some chucklehead just forget to put it back in when the vehicle was serviced?
Thanks,
David
Image Image
1990 GMC Safari SL 4.3L, Z engine, (Original owner)
As of August 1, 2011: 237,050 miles
Purchased new from dealer with Explorer Conversion Package
98cirider
Years of Membership: 98cirider has been a member for 3 full years98cirider has been a member for 3 full years98cirider has been a member for 3 full years
Topics: 23
Alias (AKA): David
Extra Info: 4.3L RWD Shorty
  • Rear heater
    by Concealed45 » March 13th 2013, 2:24pm in Climate Control
    Last post by Concealed45 View the latest post
    March 14th 2013, 5:28am
  • Drippy heater valve
    by rtb » December 18th 2012, 11:56pm in Climate Control
    December 20th 2012, 9:36am
    35
    May 23rd 2013, 12:06pm
Re: '90 Safari - Missing heater ductwork?
Postby dross93ranger » May 13th 2011, 4:50pm
If you have the "rear heat" button on your dash then you are missing that duct work.
dross93ranger
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: dross93ranger has been a member for 2 full yearsdross93ranger has been a member for 2 full years
Topics: 24
Postby RECox286 » May 13th 2011, 6:28pm
The piece you refer to is easily damaged while trying to cram it back together the way it comes from the factory. I have had to modify two of these plastic pieces over the course of the last decade.
I may still have one in the 90 Safari that I use as a "parts shed", if you would like to have it, I will look and see if it's still there. Let me know.
Bob
RECox286
Green Status (L4)
Green Status (L4)
Years of Membership: RECox286 has been a member for 2 full yearsRECox286 has been a member for 2 full years
Topics: 28
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [323K mi]
Postby 98cirider [OP] » May 13th 2011, 7:24pm
dross93ranger wrote:If you have the "rear heat" button on your dash then you are missing that duct work.
My van does not have the rear heat or a button. It just seems odd that all that heated air would be pouring onto the top of the doghouse, without much of an opening to escape into the cabin.
David
98cirider
Topics: 23
Alias (AKA): David
Postby 98cirider [OP] » May 13th 2011, 7:29pm
RECox286 wrote:The piece you refer to is easily damaged while trying to cram it back together the way it comes from the factory. I have had to modify two of these plastic pieces over the course of the last decade.
Bob
Bob,
If you have one and would no mind letting it go, that would be great. Let me know what you'd like for it and the shipping.
Thanks,
David
98cirider
Topics: 23
Alias (AKA): David
Postby Leeann_93 » May 13th 2011, 9:56pm
Yup, some chucklehead forgot to put it back or damaged it and couldn't.
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Postby RECox286 » May 14th 2011, 12:03am
Hey David,
I took a look in the "shed" (a 90 Safari, no less) and guess what. I think you might have gotten lucky... There, close to the top o' the heap sat one slightly used and abused heat duct ! (smashed, repaired and
ready for installation. So, what's the address ? PM me.
Hey Leeann,
This here chucklehead did a trick on it trying to put 'er back in place, but Mr. Goodwrench (aka boB) straightened it out with a bit of tinwork on the "scoop". Ha.
Bob
BTW: So far the "shed" has given our posters: 1 ea I/P to South Carolina, 1 ea Seat Belt Bolt to Tennessee, and now a Heater Duct to Arizona. Not a bad record so far, now, if only someone
would want 1 ea slightly used and abused 90 Safari, with lots of holes where stuff used to be, maybe I could get my driveway back. (The price is right !)
RECox286
Green Status (L4)
Green Status (L4)
Topics: 28
Year: 1993
Return to Climate Control
It is currently May 23rd 2013, 12:06pm
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
Users browsing this forum: Google Adsense [Bot] and 2 guests
