A/C leak
A/C leak
Postby visitor [OP] » May 19th 2011, 3:04am
Our A/C system has developed a leak. A day or two after recharging the system, when the compressor clicks on, it is immediately followed by a hissing sound near the rear evaporator.
There is no orifice tube in a line near the rear evaporator, is there?
Any "hissing" sound in the vicinty of the rear evaporator suggests there's is a leak there, no?
Thanks 8-)
'02 Astro LT AWD
"Anything can be an instrument... Small things. Things you wouldn't even notice. They pass from hand to hand. People don't pay attention...then one day there's an accounting. And after that nothing is the same" - Anton Chigurh
visitor
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: visitor has been a member for 5 full yearsvisitor has been a member for 5 full yearsvisitor has been a member for 5 full yearsvisitor has been a member for 5 full yearsvisitor has been a member for 5 full years
Extra Info: LT AWD
Re: A/C leak
Postby splatt222 » May 19th 2011, 5:29am
YOU NEED TO TURN VEHICLE ON, TURN AC ON FULL MAX PUT A CAN OF AC RECHARGE WITH AC DYE LEAK TEST INTO THE LOW SIDE PORT . WHEN IT HISSIS , PUT ANY BLACKLIGHT AROUND THAT PARTICULAR AREA . LOOK FOR A LEAK .USUALLY ,IT WILL BE A YELLOWISH, GLOWING COLOR . BY THE SYMPTOMS ,IT SOUNDS LIKE A SLOW LEAK . UNFORTUNATLY ,THERE ARE NO "PATCH" FIXES OUT THERE THAT I CAN STAND BEHIND . HOWEVER THERE IS A PRODUCT I'VE TRIED (AN ADDITIVE ) THAT WORKS . BUT WE ARE GETTING AHEAD OF OURSELVES . I PERSONALLY CANNOT REMEMBER WHERE THE TXV IS ON THE REAR AC OF THIS VEHICLE IS . HOUEVER I DO KNOW RULE OF THUMB ON ANY GM VEHICLE WITH REAR AC IT IS USUALLY LOCATED 4"- 6" BEFORE THE EVAPORATOR CORE QUICH DISCONNECT CONNECTOR , IN THE HIGH SIDE LINE BETWEEN THE HIGH SIDE LINE AND THE EVAPORATOR CORE. I HAVE NEVER HERD OF ONE HISSING BUT,,, I DON'T KNOW EVERYTHING !!! LET ME KNOW , PAT.
splatt222
Years of Membership: splatt222 has been a member for 2 full yearssplatt222 has been a member for 2 full years
Extra Info: awd conversion
Re: A/C leak
Postby throrope » May 19th 2011, 2:06pm
Years ago we had a leak at a rusted connection in the lines to the rear evaporator.
throrope
Years of Membership: throrope has been a member for 2 full yearsthrorope has been a member for 2 full years
Extra Info: LT 4.3L AWD
Re: A/C leak
Postby visitor [OP] » May 19th 2011, 11:58pm
that whole rear evaporator assembly is encased in a plastic housing that makes looking at the individual lines/components/connections kind of difficult
i'm thinking the best first step might be to disconnect the lines that go to the rear system to see if the system works & holds charge isolating only the front A/C - seems like a relatively simple initial appraoch, if i can find good way to adequately seal the ends of the front lines...
'02 Astro LT AWD
visitor
Fueling (7/8 tank)
Fueling (7/8 tank)
Extra Info: LT AWD
Re: A/C leak
Postby Leeann_93 » May 20th 2011, 1:59am
splatt222 wrote:YOU NEED TO TURN VEHICLE ON
I won' t quote forum rules, but please, please turn off caps lock. It's hard to read, plus it's considered shouting and rude online.
Thank you.
'02 Astro SL AWD vin X
Years of Membership: Leeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full yearsLeeann_93 has been a member for 4 full years
Topics: 17
Images: 3
Year: 2002
Extra Info: SL 4.3L AWD
Re: A/C leak
Postby Pie R Squared » May 26th 2011, 8:59pm
For the last 5 to 6 months I have been noticing a leak under the engine near the passenger side that I thought was brake or power steering fluid but now believe it to be PAG oil because the AC is very weak. Might anyone have any ideas where to look for the leak if I am getting a PAG oil drip under the engine closer to the passenger side? I have rear air, 83000 miles.
FYI: The GM Parts Giant web site www.gmpartsgiant.com has an excellent AC diagram and components list of the AC system for trouble shooting and AC Delco www.acdelcotechconnect.com has a good web site for replacement parts with GM and Delco part numbers that you can use to seach the web for parts.
Pie R Squared
Years of Membership: Pie R Squared has been a member for 4 full yearsPie R Squared has been a member for 4 full yearsPie R Squared has been a member for 4 full yearsPie R Squared has been a member for 4 full years
Extra Info: LT RWD
Re: A/C leak
Postby AstroWill » May 26th 2011, 9:39pm
Dye is about the best way to find the leak, highly recommend it.
Best Regards,
Will
1990(89Cargo) Provan Tiger GT Pop-up, Build Thread HERE: http://goo.gl/SNChE
2003 White AWD POS 260,000mi: http://goo.gl/9csvu
1999 RWD 150,000mi--SOLD!
Years of Membership: AstroWill has been a member for 4 full yearsAstroWill has been a member for 4 full yearsAstroWill has been a member for 4 full yearsAstroWill has been a member for 4 full years
Topics: 19
Alias (AKA): Will
Year: 2003
Extra Info: 4.3L V6 AWD
Re: A/C leak
Postby visitor [OP] » June 1st 2011, 2:04am
Found a corroded pipe where it crosses over (& touches) the steel coolant lines going to the rear heater core. Think I'll try wrapping epoxy/fiberglass patch aroung the aluminum pipe where the leak is for a simple, cheap fix...
'02 Astro LT AWD
visitor
Fueling (7/8 tank)
Fueling (7/8 tank)
Extra Info: LT AWD
Re: A/C leak
Postby chevymaherchevymaher is online! » June 1st 2011, 2:39am
visitor wrote:Found a corroded pipe where it crosses over (& touches) the steel coolant lines going to the rear heater core. Think I'll try wrapping epoxy/fiberglass patch aroung the aluminum pipe where the leak is for a simple, cheap fix...
Cut it with a tubing cutter and splice with a compression fitting.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Re: A/C leak
Postby visitor [OP] » June 2nd 2011, 3:12am
compression fitting's a great idea, but the breach is at a bend in the line Image
the 2 really rusted lines are the coolant lines to the rear heater core, one of which couldn't more graphically demonstrate how it "ate" into the A/C line
...so, tonight, i'm bypassing the rear heater hoses up front to avoid an inevitable coolant leak in those rusted lines.
tomorrow i'll head out to the local bone yard & find an end section of that A/C line to cut out far enough forward to have a straight section to use a compression fitting on...
'02 Astro LT AWD
visitor
Fueling (7/8 tank)
Fueling (7/8 tank)
Extra Info: LT AWD
Re: A/C leak
Postby AstroWill » June 2nd 2011, 3:52am
At first I seen you write about an epoxy/fiberglass patch, now it seems like you have the perfect plan.
Best Regards,
Will
Topics: 19
Alias (AKA): Will
Year: 2003
Re: A/C leak
Postby throrope » June 2nd 2011, 11:33pm
Before running off to the bone yard, do an internet search, and not only at parts houses. I bought an exact fit oil line from amazon.com for 5 bucks free shipping. Apparently a retailer had a stock of one and was looking to eliminate slow moving stock.
Also, don't take any short cuts on the AC lines. The pressure is more than any other line on the truck, refrigerant cost more than gas and problems are not very forgiving.
throrope
Re: A/C leak
Postby throrope » June 2nd 2011, 11:34pm
AstroWill wrote:At first I seen you write about an epoxy/fiberglass patch, now it seems like you have the perfect plan.
epoxy will never hold.
throrope
Re: A/C leak
Postby AstroWill » June 3rd 2011, 12:01am
Exactly, but now he has changed to a compression fitting, which will work perfectly.
Best Regards,
Will
Topics: 19
Alias (AKA): Will
Year: 2003
Re: A/C leak
Postby throrope » June 3rd 2011, 12:09am
:handgestures-thumbup:
throrope
Re: A/C leak
Postby visitor [OP] » June 5th 2011, 2:09am
:ty:
compression fitting went on well
time will tell...
'02 Astro LT AWD
visitor
Fueling (7/8 tank)
Fueling (7/8 tank)
Extra Info: LT AWD
Return to Climate Control
It is currently May 23rd 2013, 3:38pm
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
