Overflowing coolant
Overflowing coolant
Postby granto [OP] » May 23rd 2011, 5:08pm
So my van seems to be only pushing coolant in one direction. the radiators overflow tank is basically overflowing. It this a temp sensor or the thermostat? I'd assume some form of sensor. Its like the engine thinks its cold so its moving extra fluid to the tank and of course the engine isnt actually cold. I replaced the thermostat recently so I'd assume that wasnt it, but all ideas are welcome. Thanks Grant
granto
Years of Membership: granto has been a member for 2 full yearsgranto has been a member for 2 full years
Extra Info: 4.3L v6 awd
Re: Overflowing coolant
Postby Dirk » May 23rd 2011, 7:49pm
Is it overflowing as soon as you start the engine?
If so, did you make sure that there was no air left in the system after you changed the thermostat?
In the worst case you're looking at a blown cylinder head gasket.
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 3 full yearsDirk has been a member for 3 full yearsDirk has been a member for 3 full years
Extra Info: 4.3L 4BBL
Postby chevymaherchevymaher is online! » May 23rd 2011, 9:01pm
When the engine heats it always pushes fluid into that tank.now getting it back into the radiator a little trickier.if your system is not holding a vacuum as it cools it wont reverse direction and go back to the radiator.if the cap leaks or there a pinhole leak in the upper portions of the system it wont draw it back.It easier to draw air to stabilize pressure than draw a liquid uphill from that tank.I would check the rear heater hose at the quick disconnect fitting for a leak and the cap first.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby Phantom » May 23rd 2011, 10:39pm
The seal on the rad cap leaking can cause this , and also the overflow hose if cracked or split will prevent the coolant from being drawn back into the radiator , you should have the cooling system checked with a pressure tester to see how well it holds pressure ,
Phantom
Firing on 7 Cylinders (L4)
Years of Membership: Phantom has been a member for 2 full yearsPhantom has been a member for 2 full years
Postby granto [OP] » May 24th 2011, 5:25pm
Sounds like it could be the vacuum issue. I found a small leak in my radiator itself so that explains the fluid not getting pulled back into the tank from your description. I'll look into replacement of that and work from there. Thanks
granto
Postby tedanderson » May 24th 2011, 5:28pm
Change out your thermostat if it's been a while. That's about the cheapest/easiest repair and one of the few things that I'd do as a "part-changer" diagnosis.
tedanderson
Firing on 5 Cylinders (L3)
Years of Membership: tedanderson has been a member for 3 full yearstedanderson has been a member for 3 full yearstedanderson has been a member for 3 full years
Topics: 62
Alias (AKA): 2Big4aMiniVan
Postby granto [OP] » May 27th 2011, 10:55pm
I was going to order a new radiator for my van now that i've figured out that there is a small leak in it causing the vacuum issue. When i called to order it though they asked me which one it was. They tried to describe the differences, but his descriptions went basically nowhere. How do i find out which one to order? Its a 93 v6 4.3l safari awd is that helps. Thanks a ton!
granto
Postby Phantom » May 27th 2011, 11:20pm
Some have engine oil cooler on the drivers side and some do not have it , you can try using this link to see what code is shown for your van ,,just enter your VIN for the list of codes for your van build.
http://www.compnine.com/vid.php?vin=1gndm19w5xb126525
Here is a GM part selection for your year of van , the first listed one is L35 which is the 4.3L V6
RADIATOR (CORE SIZE 23 9/16 X 18 11/16 X 7/8)(CODE 3701)(TRANS OIL CLR) LM1 (L35,KPS)
RADIATOR (CORE SIZE 23 9/16 X 18 11/16 X 7/8)(CODE BY,EP,EH,EK,EL,EN,XM,XT)(TRANS OIL CLR) M1 (LB4, KPS)(EXC V08)
RADIATOR (CORE SIZE 23 9/16 X 18 11/16 X 7/8)(CODE AH,EJ,EM,EO,LT,XS,XW)(TRANS OIL CLR) LM1 (LB4, V08, KPS)
Phantom
Return to Climate Control
It is currently May 22nd 2013, 6:39pm
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
