Blower Motor replacement help
Postby 2002astrovan [OP] » July 27th 2011, 7:18pm
Hello,
I am needing to replace the blower motor for my 02 astro. I have loacted it and I am sure that is the problem, but is there an easier way to remove the blower with out removing the whole plactic cover that it has? The plastic cover is big and it covers what looks like the whole AC system. I know I will have to remove the resivour tanks, but do I have to remove that cover? If someone can help please do so. Thanks!
2002astrovan
Years of Membership: 2002astrovan has been a member for 5 full years2002astrovan has been a member for 5 full years2002astrovan has been a member for 5 full years2002astrovan has been a member for 5 full years2002astrovan has been a member for 5 full years
  • Blower motor
    by Kayakfisher » March 6th 2017, 1:15pm in Climate Control
    Last post by Kayakfisher View the latest post
    March 9th 2017, 3:16pm
  • Area for debris to accumulate around blower motor?
    by 888 » May 11th 2017, 12:50pm in Climate Control
    Last post by 888 View the latest post
    May 21st 2017, 2:43pm
    11
    May 23rd 2017, 11:45pm
Re: Blower Motor replacement help
Postby Phantom » July 27th 2011, 11:54pm
After you remove the coolant bottle , to the far left is the blower motor , after you have unplugged in from the blower resistor , remove 5-6 small 9/32 or 7mm screws and it will come right out ,
Item 17 is the blower , it comes out with the cage blower blade #16
2002 AC blower .png (15.57 KiB) Viewed 6240 times
Phantom
Firing on 7 Cylinders (L4)
Postby rev_les » July 28th 2011, 4:38am
Follow the instructions molded into the blower motor housing, you have to carefully take a razor knife, and cut along the molded lines to allow access to the motor. I don't remember exactly, but i do remember it was a bit of a pain at first.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full yearsrev_les has been a member for 8 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Phantom » July 28th 2011, 3:37pm
Using the knife applies to the blower resistor , to enlarge the cavity the resistor fits in. The aftermarket resistors are shaped differently , using the original GM/Ac Delco resistor I did not have to do any cutting , I just test fit it and it was perfect , The resistor came with a paper template and instructions on where to put the knife , I have not yet seen a Gen2 that needed cutting only heard about it and have the template .
Let us know if you had to do any cutting .
under the blower mounting hole in the housing, and to the right you can see the slot where the resistor goes .
Phantom
Postby 2002astrovan [OP] » July 28th 2011, 5:44pm
Thanks for the replies! I am going to start on it now. I will let you guys know what I had to do once I am done. Check back in about 2hr or so, hopefully I will be done and have posted something by then.
2002astrovan
Postby 2002astrovan [OP] » July 28th 2011, 10:02pm
Ok this is what I did: I first removed the headlight(to give clerance for the coolant bottle to come out), then removed the coolant bottle, then you take a utility knife and cut along the mold lines. Once you have cut the all along the mold line the blower motor will be exposed. There is a screw holding the newly cut out cover, so you have to remove the scew. It is located at the far left (hardest screw to get to). After you take that screw off the cover will come off. There after, you will have 4 other screws to take off and the blower motor will come out. Reverse all steps to reinstall. So it did require cutting and I used a 7/32 socket for the screws of the blower, a knife, and a screw driver. This was for 2002 Chevy Astro Van. Hope this helpful to someone and again thanks for the replies.
2002astrovan
Postby Phantom » July 29th 2011, 5:00am
Thanks , interesting those extra steps :)
Phantom
Postby rev_les » July 30th 2011, 6:32am
Yepper, sounds like the same procedure as on my '99.
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby banner1124 » August 2nd 2011, 12:11pm
So what's the point of that cover that's around things? This is the first vehicle I've had where there was a cover to remove to get at the blower motor.
banner1124
Years of Membership: banner1124 has been a member for 5 full yearsbanner1124 has been a member for 5 full yearsbanner1124 has been a member for 5 full yearsbanner1124 has been a member for 5 full yearsbanner1124 has been a member for 5 full years
Topics: 5
Postby drmmhmd » August 2nd 2011, 4:12pm
2002astrovan wrote:Ok this is what I did: I first removed the headlight(to give clerance for the coolant bottle to come out), then removed the coolant bottle, then you take a utility knife and cut along the mold lines. Once you have cut the all along the mold line the blower motor will be exposed. There is a screw holding the newly cut out cover, so you have to remove the scew. It is located at the far left (hardest screw to get to). After you take that screw off the cover will come off. There after, you will have 4 other screws to take off and the blower motor will come out. Reverse all steps to reinstall. So it did require cutting and I used a 7/32 socket for the screws of the blower, a knife, and a screw driver. This was for 2002 Chevy Astro Van. Hope this helpful to someone and again thanks for the replies.
Was that the problem? did you check the relay in the neighbourhood,
drmmhmd
Years of Membership: drmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full yearsdrmmhmd has been a member for 5 full years
Extra Info: AWD 400 CID
Postby banner1124 » August 3rd 2011, 1:13pm
Also, once you take that cover off, does it go back on? Seems like a silly question but because there's cutting involved I wasn't sure
banner1124
Topics: 5
Return to Climate Control
It is currently May 23rd 2017, 11:45pm
Climate Control Forum
Comments: 21
Date: 19 minutes ago
Time: 11:25pm
Jawon
in Climate Control
Comments: 21
Date: Today
Time: 7:45pm
RinnyRinny is online!
in Climate Control
Date: May 19 '17
Time: 6:28pm
Attached by: GreatWhite
GreatWhite
in Climate Control
Date: May 19 '17
Time: 5:49pm
Jawon
in Climate Control
Comments: 21
Date: May 18 '17
Time: 9:24pm
