2005 astro no high speed on blower motor?
Postby halfpick [OP] » October 15th 2011, 1:23am
Earlier today I had no motor speeds...later I had LO,1,2...no high speed....How do I fix this?
halfpick
Years of Membership: halfpick has been a member for 6 full yearshalfpick has been a member for 6 full yearshalfpick has been a member for 6 full yearshalfpick has been a member for 6 full yearshalfpick has been a member for 6 full yearshalfpick has been a member for 6 full years
Alias (AKA): liftguy
Extra Info: cargo
  • Blower motor
    by Kayakfisher » March 6th 2017, 1:15pm in Climate Control
    Last post by Kayakfisher View the latest post
    March 9th 2017, 3:16pm
  • Wiring diagram and diagnostic chart for 94 blower motor
    by Colorado Tim » December 15th 2016, 5:20am in Climate Control
    January 23rd 2017, 4:06pm
    57
    March 26th 2017, 2:00pm
Re: 2005 astro no high speed on blower motor?
Postby Jasen » October 15th 2011, 4:06am
The switch is probably wearing out or could be corroded, but I don't think it's really something you'd take apart to clean and get it put back together very well.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Year: 1997
Postby phessler » October 15th 2011, 1:39pm
Sounds like the resistor module need to be replaced. Just follow the wires that go to the blower motor. Also make sure the connector to the resistor module is not melted.
phessler
Years of Membership: phessler has been a member for 6 full yearsphessler has been a member for 6 full yearsphessler has been a member for 6 full yearsphessler has been a member for 6 full yearsphessler has been a member for 6 full yearsphessler has been a member for 6 full years
Extra Info: RWD
Postby FLSafari » October 15th 2011, 3:11pm
I had a similar problem a couple of years back. I decided to disassemble the switch to see what i could do. There are several copper connectors inside which touch as the knob is turned. I simply eased them up a little to make them reconnect a little more. With a little care I fixed the problem. I notice that switches on the Astro/Safari are quite expensive, most are over $50.00 a pop. IMHO that's expensive. If I can avoid that with a zero cost fix i will.
FLSafari
Years of Membership: FLSafari has been a member for 5 full yearsFLSafari has been a member for 5 full yearsFLSafari has been a member for 5 full yearsFLSafari has been a member for 5 full yearsFLSafari has been a member for 5 full years
Topics: 7
Alias (AKA): Chris
Extra Info: LSE 4.3L V6 RWD
Postby Phantom » October 15th 2011, 3:34pm
To find the cause may take some investigating , switch could be worn , sometimes a few swipes on the copper contacts can fix, you can pull the switch out in about 10 minutes and inspect it , but on a 2005 switch may be fine that not very old of a switch , what is most common is the blower motor gets used a lot in van and the blower gets worn out , it starts to draw more current than it formerly did which puts more stress on the other components in the system , too much current will cause the resistor to blow in many cases . but the resistor only affect's the lower speeds , if you have lower speeds and no high speed it is often the wire plug connectors at either the resistor connector , the red wire location will show burnt spots in the terminal area and sometimes the plastic is melted , another plug connector is behind the battery a gray 5 wire connector , same red wire showing burnt areas , you need to remove the coolant overflow bottle to access the blower and or resistor , if you find any burnt areas on the plugs , it be best to change out the blower , or you will likely end up having the same problem again , the resistor costs more than the blower , you can get a blower at Advance auto parts for about 25 bucks comes with lifetime replacement warranty , resistor is about 40 or more , not hard to change ,
Phantom
Firing on 7 Cylinders (L4)
Postby halfpick [OP] » October 18th 2011, 3:48am
Is there some where I can search to show where these parts are located.
halfpick
Extra Info: cargo
Postby paintdrying » October 18th 2011, 3:55am
Turn the blower on and listen under the hood. The very far corner on the passenger side there will be this hard black plastic cover. You should be able to hear the motor running inside. I plan on doing mine and am going to just crack and cut the case. I may build a different mounting cover, I am hoping a can rig an old Cadillac blower motor in there . I want some heat that really blows. :bouncy:
paintdrying
Topics: 94
Extra Info: 108 000
Postby halfpick [OP] » October 18th 2011, 4:24am
I now have Lo.1.2 speeds only high speed not working.....Does it still go through the motor resistor?
halfpick
Extra Info: cargo
Postby RECox286 » October 18th 2011, 4:35am
Take a look at the resistor pack. The red wire will probably show some signs that it has been turned to toast, in which case you may be in for a connector (pigtail) and a resistor pack. There may be some
connector damage behind the battery, look for a grey 5 wire connector.
Good hunting
Bob
RECox286
Topics: 38
Alias (AKA): Uncle Bob
Year: 1993
Extra Info: RWD V6 [325K mi]
Postby halfpick [OP] » October 19th 2011, 3:58am
Thanks to all...I'll check it this weekend and let you know what I find...Should any good auto parts store have these parts? Maybe like PEP BOYS?
halfpick
Extra Info: cargo
Postby RECox286 » October 19th 2011, 4:07am
I would try NAPA, and believe it or not, E-Bay.
Good hunting
Bob
RECox286
Topics: 38
Year: 1993
Postby Phantom » October 19th 2011, 1:21pm
The blower motor and resistor are at most part stores , the wiring plug connector , might be there but doubt it due to the vast amount of different vehicles they would need to stock for , dealer will have them and online stores but can get costly , if you have the time to walk the salvage yards and inspect all the vans there you will find some very good ones , I pulled a few for myself so that I would have them if needed in the future
Phantom
Postby halfpick [OP] » November 1st 2011, 2:27pm
It was the resistor pack...also found connector was cooking alittle. checked with a meter still good,but had to move plug to an angle to get good connection...It works now, must be a design error???
halfpick
Extra Info: cargo
Postby Phantom » November 1st 2011, 3:42pm
halfpick wrote:It was the resistor pack...also found connector was cooking alittle. checked with a meter still good,but had to move plug to an angle to get good connection...It works now, must be a design error???
When the blower motor ages , it starts drawing more current/amperage because the brushes and internal parts of motor are worn , this increase in amperage draw causes the whole circuit to heat up to a higher point than what is usually seen when the circuit has new parts , As the name of the part Resistor pack indicates , it is made up of resistors ,,,the excessively high current passing through the resistors cause them to overheat , and ends up burning them out , it is the same reason the connector gets cooked . Chances are very likely that if you do not replace the motor that you will end up replacing the resistor again , sometimes it can be in as little time as a couple of months , maybe a little longer than that , The best thing you can do is replace the blower for 29 bucks with lifetime warranty , and replace that connector , before your resistor blows again , the moving of the plyg to an angle to get a good connection is most likely the connector red wire not making a full good electrical connection .....you may hit a hard bump or series of bumps this winter and your high speed stops working again ,,,
burnt resistor plug.jpg (75.53 KiB) Viewed 10357 times
Phantom
Postby Maxximum_44 » November 1st 2011, 6:47pm
http://www.benoitcloutier.com/BAGNOLES/GMCSafari2000/Pdf/AstroSafariBlowerResistor_EN.pdf Mine did not have 1,2 or 3 working. I changed the control switch to no avail, ordered ac delco resister, did the mod and whala! heat! A tip if I may: It's really tight in there, If you remove the passenger headlight you can seen in and maneuver around better and even use a Dremel tool.
03 - Astro - AWD - 4.36L V6 - Original - Motor/Trans-New Exhaust-
Maxximum_44
Years of Membership: Maxximum_44 has been a member for 6 full yearsMaxximum_44 has been a member for 6 full yearsMaxximum_44 has been a member for 6 full yearsMaxximum_44 has been a member for 6 full yearsMaxximum_44 has been a member for 6 full yearsMaxximum_44 has been a member for 6 full years
Topics: 12
Images: 9
Alias (AKA): Maxx
Year: 2003
Extra Info: LT 4.3L V6 AWD
Postby Big Dac With Fries » December 11th 2011, 6:59am
Where the hell are you guys finding these $30 blower motors with lifetime warrantys?
EDIT: Ebay, that's where.
Big Dac With Fries
Years of Membership: Big Dac With Fries has been a member for 6 full yearsBig Dac With Fries has been a member for 6 full yearsBig Dac With Fries has been a member for 6 full yearsBig Dac With Fries has been a member for 6 full yearsBig Dac With Fries has been a member for 6 full yearsBig Dac With Fries has been a member for 6 full years
Postby Phantom » December 11th 2011, 7:16am
Big Dac With Fries wrote:Where the hell are you guys finding these $30 blower motors with lifetime warrantys?
Advance auto is where I got mine
Phantom
Postby Big Dac With Fries » December 11th 2011, 6:11pm
I just learned how to do this on my boss' 2005 Astro. He lost speed 4 first, then the motor went altogether. My buddy who is a GM tech replaced the motor, but the resistor pack was shot as well.
My 1999 Safari is making a little noise when you use speeds 2-4... so I think I might replace the motor before it dies and takes out the resistor and plug with it.
Big Dac With Fries
Postby cookiemonster59 » February 10th 2012, 8:39pm
Not too sure about Astro Vans, but my '72 Trans Am had the same problem. Turns out the bottom three fan speeds (1-2 & 3) come off a resistor network that is inside the engine compartment, usually fasten to the air plenium chamber so that it is cooled by the air flowing thru there. However, the HIGH speed for the fan came right off the alternator, thru a 30 amp, in-line fuse. Replaced that fuse, and I had power to that ckt. again. However, I still had to replace the thermal cutout in the A/C circuit, and pull the fan out & clean the brushes & stator before it all worked right again. Happy to say it was all still working several years later when I sold the Trans AM to my brother-in-law (sniff-sniff). Pontiac is a GM product, and GM tends to repeat a lot of their technical stuff fm. brand to brand, and model to model, so hope this gives you a lead in to fixing your problem.
cookiemonster59
Years of Membership: cookiemonster59 has been a member for 5 full yearscookiemonster59 has been a member for 5 full yearscookiemonster59 has been a member for 5 full yearscookiemonster59 has been a member for 5 full yearscookiemonster59 has been a member for 5 full years
Topics: 5
Alias (AKA): 'Rick'/'CookieMonster59'
Year: 1999
Extra Info: V6 RWD
Return to Climate Control
It is currently March 26th 2017, 2:00pm
Climate Control Forum
99SLEG80AWD
in Climate Control
Comments: 18
Time: 2:24pm
Jawon
in Climate Control
Date: Mar 09 '17
Time: 8:50pm
in Climate Control
Comments: 13
Date: Mar 08 '17
Time: 8:24pm
Rookie162
in Climate Control
Comments: 34
Date: Feb 22 '17
Time: 2:07am
Rinny
in Climate Control
Comments: 31
Date: Jan 23 '17
Time: 2:40pm
Users browsing this forum: Google [Bot] and 2 guests
