Loud honkin' fan motor noise
Postby kus [OP] » November 11th 2011, 6:01am
So no sooner do I fix my vac leak and get the air flow working, there is this high pitched noise like air leakage under the passenger airbag duct. I'm on the road, pull over, reach down, it's the foam seal come loose somehow and sticking out and leaking air badly. I shove it back in. All good for a bit and plan to fix it when I get home, then bam, loud thrumming noise from the fan motor....I figure "**** it has sucked the foam into the motor".....but no, the seal is all there, i have reglued it and now I wonder if it is the white foam backing being thrummed by the air on the duct cover. I dropped it down to see, 4 screws and found nothing. But the noise is still coming from the motor housing.....Any guesses anyone? Air flow pressure and heat is still good. Could I have sucked a leaf or a seal into the fan...it sounds like an electic lawn mower, lounder at high speed of course but still plenty noticable when at low....very annoying and must fix....where to start :roll: grrrr
"Doing things the hard way since 1963"
kus
Years of Membership: kus has been a member for 1 full year
Extra Info: AWD LT 4.3L 3.73
Re: Loud honkin' fan motor noise
Postby Jasen » November 11th 2011, 6:19am
The fan motor is under the hood, and the HVAC rad is under the dash, so you can't suck anything back up that way. I think either you some how sucked something in through the cowl, but I think that's pretty hard to do, or maybe the squirrel cage is coming loose or you have a tine broken loose.
http://the-99percent.blogspot.com/
I'm a Journeyman woodworker,
Every projects a journey man.
Firing on 4 Cylinders (L7)
Years of Membership: Jasen has been a member for 3 full yearsJasen has been a member for 3 full yearsJasen has been a member for 3 full years
Topics: 249
Images: 68
Year: 1997
Postby JayDubya » December 23rd 2011, 1:56pm
or maybe a mouse got up in there and is now spinning inside of your motor squirrel cage.
'99 Astro Mark III conversion hack job
JayDubya
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: JayDubya has been a member for 3 full yearsJayDubya has been a member for 3 full yearsJayDubya has been a member for 3 full years
Extra Info: RWD Hightop conv
Postby kus [OP] » December 23rd 2011, 5:49pm
Tis one a dem "leave it alone" things.....after a few days of serious annoyance, it got quieter, then stopped altogether. I suspect that whatever got in there to obstruct settled or got blown away to somewhere else plugging one of the vents....who knows, just glad everything's working :dance:
kus
Postby JayDubya » December 31st 2011, 9:16am
Wow! That was one, tough mouse to get up & walk away from that high-speed ferris wheel ride.
JayDubya
Fueling (3/4 tank)
Fueling (3/4 tank)
Postby Big Dac With Fries » January 2nd 2012, 9:54pm
I had a similar noise that would come and go with warmer/cooler weather. Once the temperature dropped below a certain point, the noise was always there. May be time for a blower motor replacement.
Big Dac With Fries
Years of Membership: Big Dac With Fries has been a member for 2 full yearsBig Dac With Fries has been a member for 2 full years
Postby david3100 » June 19th 2012, 12:54am
I have a loud noise too. But, i know why. i saw a small plastic bag get sucked up from the floor and it thrashed around and now its a loud buzzzz. Hows the best way to extract the plastic bag? Thanks
david3100
Years of Membership: david3100 has been a member for 4 full yearsdavid3100 has been a member for 4 full yearsdavid3100 has been a member for 4 full yearsdavid3100 has been a member for 4 full years
Postby 88astroLT » June 19th 2012, 1:01am
My 97 has a noise under the passenger side airbag when in max a/c. I believe it is just recirculating the air like max a/c should. When i go into vent, defroster, or normal a/c the sound goes away.
88 Astro LT RWD 345k+ 3.43
97 Safari SLE RWD 113k+ 3.43 Limited Slip
88astroLT
Years of Membership: 88astroLT has been a member for 2 full years88astroLT has been a member for 2 full years
Topics: 16
Extra Info: LT 4.3L V6 RWD
Postby david3100 » June 21st 2012, 1:05am
I have a loud noise too. But, i know why. i saw a small plastic bag get sucked up from the floor on the passenger side and it thrashed around and now its a loud buzzzz. Hows the best way to extract the plastic bag? Thanks
david3100
Postby david3100 » June 24th 2012, 4:55pm
I removed the blower motor and the plastic bad was wrapped around the shaft of the blower motor. Unrapped, reinstalled. All ok. All screws were 5.5mm. Cutting through the acoustic rubber membrane took the most time. I used a liberated paring knife after a touch up on the grinding wheel. Recommend leaving the rubber uncut between the tabs at the two oclock position and fold it back for blower access. This was a 2003 so yours may be different. Also, as has been mentioned, when you first start this job there is one screw that is around the 9 oclock position that must be removed. All others are accessible once you peel back the membrane.hope this helps.
david3100
Return to Climate Control
It is currently May 23rd 2013, 2:35am
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
Users browsing this forum: Brady628Brady628 is online! and 6 guests
