Hi All .. Got a quick question, Where is the blower motor resistor located on my 94' Astro? I found allot of posts about the resistor itself but none to aim me toward its exact location on my van. I was told it was on the inside passenger side under the dash on top of or near heater box. However I cant seem to find anything there and I suspect that its location is instead under the hood above the blower itself on the firewall. There is a small bracket with approx three small enclosed boxes mounted to it which I am assuming are relays and maybe the resistor I am in search of ( I Hope ). If this is the correct location should be a snap to replace .. fingers are crossed that I am right , lol
P.S. If needed I can take a pic of this bracket to post later today..also my van has no rear heat or AC if that matters on where its location is .. much thanks
