Blower intermittant (yes again)
Postby smokinjoesmokinjoe is online! [OP] » July 23rd 2012, 6:09pm
So I cant find my last thread but here is where I lay.....(not stand)
I got a 3 way GM type check valve at pep. I seem to be able to blow air through it in any direction which seems wrong.
I want to just replace all the vacuum lines from ball to chck valve to both connections but can find the connection point of the right angle hard plastic one that seems to go into the wiring harness.
I will remove my dog house if needed but would (of course) rather not.
Just took a 1000 mile trip and did like 10 roadside "fixes" on the valve. Changed hose from ball to valve, changed direction of valve and where each hose entered. STILL cuts out at hill loads on highway.
Is that diagram of vacuum the same for all yrs of van? Mines a 95
Many hours invested. Someone help(!)
Years of Membership: smokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full yearssmokinjoe has been a member for 4 full years
Topics: 77
Alias (AKA): smokinjoe
Year: 1995
Extra Info: RWD
  • blower motor
    by chris1990 » December 21st 2012, 5:21pm in Climate Control
    Last post by RECox286 View the latest post
    December 21st 2012, 7:23pm
  • Blower issue
    by fede » May 13th 2013, 5:20pm in Climate Control
    Last post by fede View the latest post
    May 19th 2013, 2:01am
    13
    May 24th 2013, 5:33am
Re: Blower intermittant (yes again)
Postby chevymaherchevymaher is online! » July 23rd 2012, 7:59pm
Yea same problem we had at Fartstone Reckon. Everybody kept complainin. That is your air leaving vent setting when you give it the gas. Thats why I went with the bubbler dealy. Valve cheaper and most important it actually works. That plastic line is hooked to the check valve still under the hood Reckon. If I was there I would point at it and look at ya silly. But I am not.
Firing on 1 Cylinder (L7)
Topics: 50
Images: 92
Year: 1994
Postby smokinjoesmokinjoe is online! [OP] » July 23rd 2012, 9:07pm
I have an aqarium one but then do I just put it inline + use a t-fitting? So tube from ball to one way, then to t-fitting and on to both connections?
Topics: 77
Year: 1995
Extra Info: RWD
Postby chevymaherchevymaher is online! » July 23rd 2012, 9:12pm
smokinjoe wrote:I have an aqarium one but then do I just put it inline + use a t-fitting? So tube from ball to one way, then to t-fitting and on to both connections?
Yes that will work.
Topics: 50
Images: 92
Year: 1994
Postby smokinjoesmokinjoe is online! [OP] » July 25th 2012, 4:44am
So that didnt work. My confusion is; where is the vacuum coming from and what is requiring the vacuum? So which way does the arrow point on the one way valve? To the ball or away from it?
Topics: 77
Year: 1995
Extra Info: RWD
Postby chevymaherchevymaher is online! » July 25th 2012, 7:17am
The vacuum is coming from the engine in the intake manifold. The arrow On the valve will point toward the engine vacuum source. Direction the air is actually traveling. Mine does not have the vacuum ball and I simply did not connect the second hose from the 3 way factory check valve. That hose on mine ran the gas tanks evaporative emissions equipment. Which sat on my floor and I eventually threw away.I ran a straight line from the intake to run this on mine. I have vacuum to MAP sensor and the dash to control the vents. My lines were rotted and I only hooked up what it needed. When I replaced them
Anyway I scoured my vacuum diagrams for the vans. Here are 3 images. First shows where the plastic line enters the wiring harness on mine.
Second is a different shot of basically the same thing on a W Vin with a vacuum ball.
3rd is another W Vin showing the plastic line entering the wiring at the distributor. Mine is definitely not there. All these diagrams are labeled as being the same year van. So there are obviously factory differences.
A question I have is this. Is your vacuum ball receiving vacuum from the engine. Is that line rotted and leaking?
All you need is vacuum from engine. A direct source hook the rubber line to it then the check valve, then to this control line where ever it is on your van.
Here is yet another vacuum diagram which is not helpful at all. They strive for this when they make them. Vacuum from engine to the vacuum ball. From there through the firewall. The beauty is they are not telling where it crosses the firewall.
Topics: 50
Images: 92
Year: 1994
Postby smokinjoesmokinjoe is online! [OP] » July 25th 2012, 3:49pm
So maher, you have no vacuum ball at all and no trouble with vent up hills?
You are right though. I should at least replace the lines to be sure I dont have leaks, just tricky finding the ends. I had to take the doghouse off to change my dist cap.
Topics: 77
Year: 1995
Extra Info: RWD
Postby chevymaherchevymaher is online! » July 25th 2012, 4:49pm
smokinjoe wrote:So maher, you have no vacuum ball at all and no trouble with vent up hills?
No mine stays where I put it. It stays on vent after being floored 0-100 no problem. (Disclaimer: on a closed course, do not try this at home. lol) And mine had no vacuum ball factory.
Topics: 50
Images: 92
Year: 1994
Postby bdar34 » August 1st 2012, 9:35pm
Hi All,
Am having the same problem with the loss of vacuum from vents when pressing the gas/going uphill and I have changed all 3 vacuum lines (From the manifold to the 3-way connector, from the vacuum ball to the connector and from the connector to the firewall). So not sure what to do next. Is the valve being discussed in this thread the same as the 3 way connector that everything connects into? Thanks!
bdar34
Year: 1997
Extra Info: V6
Return to Climate Control
It is currently May 24th 2013, 5:33am
Climate Control Forum
Attached by: chevymaher
in Climate Control
Comments: 154
Date: May 09 '13
Time: 2:01am
deleteitall
in Climate Control
Date: May 07 '13
Time: 6:42pm
Drummernaut
in Climate Control
Date: Apr 15 '13
Time: 12:08am
Attached by: tedanderson
tedanderson
in Climate Control
Date: Apr 02 '13
Time: 9:37pm
in Climate Control
Date: Mar 09 '13
Time: 2:19am
